Grillé mais je le poste quand même …
Le manuel de fdisk n’est pas le dernier à éreinter fdisk.
$ man fdisk
[code]
BUGS
There are several *fdisk programs around. Each has its problems and
strengths. Try them in the order cfdisk, fdisk, sfdisk. (Indeed,
cfdisk is a beautiful program that has strict requirements on the par‐
tition tables it accepts, and produces high quality partition tables.
Use it if you can. fdisk is a buggy program that does fuzzy things -
usually it happens to produce reasonable results. Its single advantage
is that it has some support for BSD disk labels and other non-DOS par‐
tition tables. Avoid it if you can. sfdisk is for hackers only – the
user interface is terrible, but it is more correct than fdisk and more
powerful than both fdisk and cfdisk. Moreover, it can be used nonin‐
teractively.)
These days there also is parted. The cfdisk interface is nicer, but
parted does much more: it not only resizes partitions, but also the
filesystems that live in them.[/code]
Résumé pour les francophones, tout spécialement pour les rares sujets du royaume de Belgique flamands exclusivement francophones …
Dans la famille *fdisk, essayez dans l’ordre : cfdisk, fdisk, sfdisk.
fdisk est un programme à bugs sujet à d’étranges comportements, évitez-le si vous pouvez.
De nos jours nous disposons de parted qui est capable de davantage de prouesses.
