FPS bas (trop bas)
Ça expliquerais pourquoi malgré plusieurs pilotes mes jeux gèle, ça pourrais venir de mon processeur :/…
Non, tu tournes sur les drivers propriétaires. Je pense que c’est un souci entre compiz et les drivers fglrx mais c’est une supputation…
Par simple curiosité, reposte les Warnings de ton Xorg.conf :wink:
[quote=“buchs”]Par simple curiosité, reposte les Warnings de ton Xorg.conf :wink:
@+[/quote]
Kézako? :smt003
Ah ! J’avais pas compris, si on m’explique pas tous les truc aussi… (Non je dis pas que c’est votre faute ! :laughing: )
    [quote](WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(WW) The directory “/usr/X11R6/lib/X11/fonts/misc” does not exist.
(WW) The directory “/usr/share/fonts/X11/cyrillic” does not exist.
(WW) The directory “/usr/X11R6/lib/X11/fonts/cyrillic” does not exist.
(WW) The directory “/usr/X11R6/lib/X11/fonts/100dpi/” does not exist.
(WW) The directory “/usr/X11R6/lib/X11/fonts/75dpi/” does not exist.
(WW) The directory “/usr/X11R6/lib/X11/fonts/Type1” does not exist.
(WW) The directory “/usr/X11R6/lib/X11/fonts/100dpi” does not exist.
(WW) The directory “/usr/X11R6/lib/X11/fonts/75dpi” does not exist.
(WW) The directory “/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType” does not exist.
(WW) fglrx: No matching Device section for instance (BusID PCI:1:0:1) found
(WW) fglrx(0): board is an unknown third party board, chipset is supported
(WW) fglrx(0): Only one display is connnected,so single mode is enabled
(WW) AIGLX: 3D driver claims to not support visual 0x23
(WW) AIGLX: 3D driver claims to not support visual 0x24
(WW) AIGLX: 3D driver claims to not support visual 0x25
(WW) AIGLX: 3D driver claims to not support visual 0x26
(WW) AIGLX: 3D driver claims to not support visual 0x27
(WW) AIGLX: 3D driver claims to not support visual 0x28
(WW) AIGLX: 3D driver claims to not support visual 0x29
(WW) AIGLX: 3D driver claims to not support visual 0x2a
(WW) AIGLX: 3D driver claims to not support visual 0x2b
(WW) AIGLX: 3D driver claims to not support visual 0x2c
(WW) AIGLX: 3D driver claims to not support visual 0x2d
(WW) AIGLX: 3D driver claims to not support visual 0x2e
(WW) AIGLX: 3D driver claims to not support visual 0x2f
(WW) AIGLX: 3D driver claims to not support visual 0x30
(WW) AIGLX: 3D driver claims to not support visual 0x31
(WW) AIGLX: 3D driver claims to not support visual 0x32
(WW) AIGLX: 3D driver claims to not support visual 0x33
(WW) AIGLX: 3D driver claims to not support visual 0x34
(WW) AIGLX: 3D driver claims to not support visual 0x35
(WW) AIGLX: 3D driver claims to not support visual 0x36
(WW) AIGLX: 3D driver claims to not support visual 0x37
(WW) AIGLX: 3D driver claims to not support visual 0x38
(WW) AIGLX: 3D driver claims to not support visual 0x39
(WW) AIGLX: 3D driver claims to not support visual 0x3a
(WW) AIGLX: 3D driver claims to not support visual 0x3b
(WW) AIGLX: 3D driver claims to not support visual 0x3c
(WW) AIGLX: 3D driver claims to not support visual 0x3d
(WW) AIGLX: 3D driver claims to not support visual 0x3e
(WW) AIGLX: 3D driver claims to not support visual 0x3f
(WW) AIGLX: 3D driver claims to not support visual 0x40
(WW) AIGLX: 3D driver claims to not support visual 0x41
(WW) AIGLX: 3D driver claims to not support visual 0x42
(WW) AIGLX: 3D driver claims to not support visual 0x43
(WW) AIGLX: 3D driver claims to not support visual 0x44
(WW) AIGLX: 3D driver claims to not support visual 0x45
(WW) AIGLX: 3D driver claims to not support visual 0x46
(WW) AIGLX: 3D driver claims to not support visual 0x47
(WW) AIGLX: 3D driver claims to not support visual 0x48
(WW) AIGLX: 3D driver claims to not support visual 0x49
(WW) AIGLX: 3D driver claims to not support visual 0x4a
(WW) AIGLX: 3D driver claims to not support visual 0x4b
(WW) AIGLX: 3D driver claims to not support visual 0x4c
(WW) AIGLX: 3D driver claims to not support visual 0x4d
(WW) AIGLX: 3D driver claims to not support visual 0x4e
(WW) AIGLX: 3D driver claims to not support visual 0x4f
(WW) AIGLX: 3D driver claims to not support visual 0x50
(WW) AIGLX: 3D driver claims to not support visual 0x51
(WW) AIGLX: 3D driver claims to not support visual 0x52
(WW) AIGLX: 3D driver claims to not support visual 0x53
(WW) AIGLX: 3D driver claims to not support visual 0x54
(WW) AIGLX: 3D driver claims to not support visual 0x55
(WW) AIGLX: 3D driver claims to not support visual 0x56
(WW) AIGLX: 3D driver claims to not support visual 0x57
(WW) AIGLX: 3D driver claims to not support visual 0x58
(WW) AIGLX: 3D driver claims to not support visual 0x59
(WW) AIGLX: 3D driver claims to not support visual 0x5a
(WW) AIGLX: 3D driver claims to not support visual 0x5b
(WW) AIGLX: 3D driver claims to not support visual 0x5c
(WW) AIGLX: 3D driver claims to not support visual 0x5d
(WW) AIGLX: 3D driver claims to not support visual 0x5e
(WW) AIGLX: 3D driver claims to not support visual 0x5f
(WW) AIGLX: 3D driver claims to not support visual 0x60
(WW) AIGLX: 3D driver claims to not support visual 0x61
(WW) AIGLX: 3D driver claims to not support visual 0x62
(WW) AIGLX: 3D driver claims to not support visual 0x63
(WW) AIGLX: 3D driver claims to not support visual 0x64
(WW) AIGLX: 3D driver claims to not support visual 0x65
(WW) AIGLX: 3D driver claims to not support visual 0x66
(WW) AIGLX: 3D driver claims to not support visual 0x67
(WW) AIGLX: 3D driver claims to not support visual 0x68
(WW) AIGLX: 3D driver claims to not support visual 0x69
(WW) AIGLX: 3D driver claims to not support visual 0x6a
(WW) AIGLX: 3D driver claims to not support visual 0x6b
(WW) AIGLX: 3D driver claims to not support visual 0x6c
(WW) AIGLX: 3D driver claims to not support visual 0x6d
(WW) AIGLX: 3D driver claims to not support visual 0x6e
(WW) AIGLX: 3D driver claims to not support visual 0x6f
(WW) AIGLX: 3D driver claims to not support visual 0x70
(WW) AIGLX: 3D driver claims to not support visual 0x71
(WW) AIGLX: 3D driver claims to not support visual 0x72
Rien d’anormal si je puis dire :laughing:
Pour les FPS si bas, il me semble que j’avais le même problème quand j’avais une ATI mais pas au point de faire freezer le PC :neutral_face:
Effectivement, fglrx est en conflit avec AIGLX. Tu peux résoudre ce problème en ajoutant le texte suivant dans la section “ServerFlags” de ton xorg.conf :
 Option "AIGLX" "off"
Ahah… Zavez pas tout lu ! Le fps est remonté maintenant, mais ça gèle, c’est le seul problème.
Tu as encore des warnings et des erreurs dans ton /var/log/Xorg.0.log ?
Cf mon quote plus haut, on me la déjà demandé non?
Normalement, tu devrais en avoir beaucoup moins, si tu as désactivé AIGLX…
Et je fais comment ce que tu m’a demandé?
Facile : si tu n’as pas de section “ServerFlags” dans ton xorg.conf, il te suffit de la créer (et d’y signaler que tu ne veux pas d’AIGLX). Tu fais ça de la façon suivante :
Section "ServerFlags" Option "AIGLX" "off" EndSection
Tu mets ce texte au début ou à la fin de ton xorg.conf, ça n’a pas d’importance, pour autant que je sache. Chez moi, c’est au début.
Une fois que c’est fait, tu relances X (CTRL+ALT+Backspace) et tu vérifies que les warnings ne sont plus là. S’il en reste, poste les (et poste les éventuelles erreurs également).
[quote]Koshie:/home/koshie# grep WW /var/log/Xorg.0.log
Bon ben t’as déjà réglé ce problème là. Tes jeux rament toujours ?
J’ai déjà dis que non :/… Ils gèlent, vois ce post : viewtopic.php?f=3&t=10901
Encore maintenant, après avoir désactivé AIGLX ?
Diable, je viens de relire ton xorg.conf :
fglrx n’est pas compatible avec la sortie composite : tu devrais éditer ta section “Extensions” en conséquence, de la manière suivante :
Section "Extensions" Option "Composite" "disable" EndSection
Cela fait, relance X et fais tourner un jeu, histoire de voir si ça rame ou si ça plante toujours.
Avec un peu de chance, ça fera avancer le schimlblick.
Bon courage.
Jeu planter en une minute, en comptant le faite que j’ai chercher un serveur… :laughing:
Mais pourrions nous continuer sur l’autre post? Ce post concerne l’accélération graphique, tandis que l’autre concerne le gèle du PC.
Même si j’ai bien peur de n’être qu’assez peu utile, pourquoi pas ?
Pour info, c’est quel jeu, qui plante, exactement ?
