Freenx (et oui)
je possède un serveur dédié et je suis sous debian testing (lenny), j’ai installé Freenx je me connecte avec nxclient (version 1.5), j’ai un message d’erreur “Session failed”
Les logs:
[code]NXPROXY - Version 1.5.0
Copyright © 2001, 2005 NoMachine.
See http://www.nomachine.com/ for more information.
Info: Proxy running in client mode with pid ‘3952’.
Info: Connecting to remote host ‘AB.CD.EF.GH:5000’.
Info: Connection to remote proxy ‘IJ.KL.MN.OP.QR:5000’ established.
Info: Synchronizing local and remote caches.
Info: Handshaking with remote proxy completed.
Info: Using cache parameters 4/262144/16384KB/16384KB.
Info: Using adsl link parameters 8192/16/10/50.
Info: Using pack method ‘no-pack’ with session ‘unix-application’.
Info: Using ZLIB data compression level 3.
Info: Using ZLIB data threshold set to 32.
Info: Using ZLIB stream compression level 6.
Info: Using remote ZLIB data compression level 3.
Info: Using remote ZLIB stream compression level 6.
Info: No suitable cache file found.
Info: Using remote server ‘ST.UV.WX.XR:5000’.
Info: Forwarding multimedia connections to port ‘16000’.
Info: Starting X protocol compression.
Warning: Protocol mismatch in the authentication data.
Info: End of session requested by remote proxy.
Info: Shutting down the link and exiting.
Si vous pouvez m’aider :wink:
