Je connais un problème que je n’avais jamais eu jusque là. Je cherche à utiliser la dernière version de Freeplane (le successeur de Freemind) et obtient le message d’erreur suivant lorsque j’essaie de lancer en Konsole la commande “sh freeplane.sh”
Knopflerfish OSGi framework, version 4.1.10
Copyright 2003-2009 Knopflerfish. All Rights Reserved.
See http://www.knopflerfish.org for more information.
No restart xargs file /home/manu/Programmes/freeplane-1.0.37/restart.xargs, trying /home/manu/Programmes/freeplane-1.0.37/init.xargs instead.
Loading xargs file /home/manu/Programmes/freeplane-1.0.37/props.xargs
Loading xargs file /home/manu/Programmes/freeplane-1.0.37/init.xargs
Installed and started: reference:file:/home/manu/Programmes/freeplane-1.0.37/core/org.freeplane.core (id#1)
9 janv. 2010 17:36:37 org.freeplane.core.util.LogTool info
INFO: freeplane_version = 1.0.37 beta; freeplane_xml_version = 0.9.0
java_version = 1.6.0_12; os_name = Linux; os_version = 2.6.26-2-686
User properties not found, new file created
INFO: called ResourceController.setResourceController(...)
No protocol specified
java.lang.InternalError: Can't connect to X11 window server using ':0' as the value of the DISPLAY variable.
at sun.awt.X11GraphicsEnvironment.initDisplay(Native Method)
at sun.awt.X11GraphicsEnvironment.access$100(X11GraphicsEnvironment.java:52)
at sun.awt.X11GraphicsEnvironment$1.run(X11GraphicsEnvironment.java:155)
at java.security.AccessController.doPrivileged(Native Method)
at sun.awt.X11GraphicsEnvironment.<clinit>(X11GraphicsEnvironment.java:131)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Class.java:169)
at java.awt.GraphicsEnvironment.getLocalGraphicsEnvironment(GraphicsEnvironment.java:68)
at sun.awt.X11.XToolkit.<clinit>(XToolkit.java:89)
at java.awt.Toolkit$2.run(Toolkit.java:834)
at java.awt.Toolkit.getDefaultToolkit(Toolkit.java:826)
at javax.swing.ImageIcon.<init>(ImageIcon.java:148)
at javax.swing.ImageIcon.<init>(ImageIcon.java:167)
at org.freeplane.core.ui.AFreeplaneAction.<init>(AFreeplaneAction.java:101)
at org.freeplane.core.resources.ShowSelectionAsRectangleAction.<init>(ShowSelectionAsRectangleAction.java:40)
at org.freeplane.core.resources.ResourceController.init(ResourceController.java:222)
at org.freeplane.main.application.ApplicationResourceController.init(ApplicationResourceController.java:184)
at org.freeplane.main.application.FreeplaneStarter.createController(FreeplaneStarter.java:106)
at org.freeplane.main.osgi.Activator.startFramework(Activator.java:126)
at org.freeplane.main.osgi.Activator.start(Activator.java:68)
at org.knopflerfish.framework.BundleImpl.start0(BundleImpl.java:374)
at org.knopflerfish.framework.PermissionOps.callStart0(PermissionOps.java:215)
at org.knopflerfish.framework.BundleImpl.start(BundleImpl.java:321)
at org.knopflerfish.framework.StartLevelImpl.increaseStartLevel(StartLevelImpl.java:285)
at org.knopflerfish.framework.StartLevelImpl$1.run(StartLevelImpl.java:217)
at org.knopflerfish.framework.StartLevelImpl.run(StartLevelImpl.java:178)
at java.lang.Thread.run(Thread.java:619)
## DEBUG: errors - FrameworkErrorEvent bundle #1
## DEBUG: errors - FrameworkErrorEvent throwable:
org.osgi.framework.BundleException: BundleActivator start failed
at org.knopflerfish.framework.BundleImpl.start0(BundleImpl.java:419)
Caused by: java.lang.InternalError: Can't connect to X11 window server using ':0' as the value of the DISPLAY variable.
... 6 more
Nested bundle exception:
Framework launched
Auriez-vous une idée pour m’aider à résoudre ce problème de Java ? Pour information, voici ce que donne la commande suivante :
/usr/sbin/update-alternatives --config java
Le retour de commande :
[code]Il y a 6 alternatives fournissant « java ».
Sélection Alternative
1 /usr/bin/gij-4.3
2 /usr/lib/jvm/java-gcj/jre/bin/java
3 /usr/lib/jvm/java-6-openjdk/jre/bin/java
4 /usr/lib/jvm/java-6-sun/jre/bin/java 5 /usr/lib/jvm/java-1.5.0-sun/jre/bin/java 6 /usr/bin/jamvm
Appuyez sur Entrée pour conserver la valeur par défaut[*] ou choisissez le numéro sélectionné :[/code]
D’avance merci de votre aide !
