Freetuxtv-erreur-segmentation
J’ai voulu essayer freetuxtv et l’application s’est arrêtée; voici les messages laissés sur le terminal:[code]~$ freetuxtv
[FreetuxTV] INFO : Compiled with GTK3
[FreetuxTV] INFO : Compiled with LibVLC version 2.1.2
[FreetuxTV] INFO : Compiled with libnotify version 0.7.6
[FreetuxTV] INFO : Loading FreetuxTV 0.6.6
[FreetuxTV] INFO : Loading user interface from path /usr/share/freetuxtv/ui
[FreetuxTV] INFO : Initializing user interface
[GMMKeys] INFO : Initialize
[GMMKeys] INFO : Activating media player keys
[GMMKeys] INFO : Created dbus proxy for org.gnome.SettingsDaemon.MediaKeys; grabbing keys
[FreetuxTV] INFO : Using user configuration dir: /home/dominique/.config/FreetuxTV
[FreetuxTV] INFO : DBSync open database
[DBEvolution] INFO : Starting database evolution
[DBEvolution] INFO : Current database version is 0.6.0.2
[FreetuxTV] INFO : DBSync close database
[FreetuxTV] INFO : Loading config file /home/dominique/.config/FreetuxTV/config.ini
[FreetuxTV] INFO : Cannot load config file
[FreetuxTV] INFO : Creating media player widget
[FreetuxTV] INFO : Initializing LibVLC instance
[LibVLC-Gtk] INFO : Using instance vlc with 3 options [–no-xlib --ignore-config --no-video-title-show]
[FreetuxTV] MESSAGE : Synchronizing the tv channels list
[FreetuxTV] INFO : Loading the list of channels
[FreetuxTV] INFO : Loading the list of recordings
[FreetuxTV] INFO : Showing the main window, hide splashscreen
[FreetuxTV] INFO : Loading GtkBuilder object “dialogaddgroup” from /usr/share/freetuxtv/ui/addchannelsgroups.glade
** (freetuxtv:2266): CRITICAL **: gtk_builder_window_get_top_window: assertion ‘GTK_IS_WINDOW(pObject)’ failed
(freetuxtv:2266): Gtk-CRITICAL **: gtk_window_set_transient_for: assertion ‘GTK_IS_WINDOW (window)’ failed
(freetuxtv:2266): Gtk-CRITICAL **: gtk_window_set_position: assertion ‘GTK_IS_WINDOW (window)’ failed
(freetuxtv:2266): Gtk-CRITICAL **: gtk_tree_view_get_selection: assertion ‘GTK_IS_TREE_VIEW (tree_view)’ failed
(freetuxtv:2266): Gtk-CRITICAL **: gtk_tree_selection_set_mode: assertion ‘GTK_IS_TREE_SELECTION (selection)’ failed
(freetuxtv:2266): GLib-GObject-WARNING **: invalid (NULL) pointer instance
(freetuxtv:2266): GLib-GObject-CRITICAL **: g_signal_connect_data: assertion ‘G_TYPE_CHECK_INSTANCE (instance)’ failed
(freetuxtv:2266): Gtk-CRITICAL **: gtk_tree_store_clear: assertion ‘GTK_IS_TREE_STORE (tree_store)’ failed
Erreur de segmentation
J’ai lu que les erreurs de segmentation correspondaient à des dépassements de mémoire ou à des problèmes de pointeur; S’il y a quelque chose à faire, faites-moi part de vos suggestions.
Ciao.
Lis ce fil :
https://www.debian-fr.org/freetuxtv-t51634.html?hilit=freetuxtv#p512780
Freetuxtv n’est plus maintenu et je dois passer par Vlc en utilisant la commande:
dans Lecture>Lire>Réseau.
Merci pour les informations.
Ciao.
