bon alors voilà, je n’ai pas pu faire startx en tant que simple utilisateur, alors j’ai redémarré à la place, en tout cas, voilà ce qu’il ya /var/log/messages :
Apr 21 11:56:55 debian shutdown[3024]: shutting down for system reboot
Apr 21 11:57:00 debian kernel: Kernel logging (proc) stopped.
Apr 21 11:57:00 debian kernel: Kernel log daemon terminating.
Apr 21 11:57:01 debian exiting on signal 15
Apr 21 11:57:40 debian syslogd 1.4.1#20: restart.
Apr 21 11:57:40 debian kernel: klogd 1.4.1#20, log source = /proc/kmsg started.
Apr 21 11:57:40 debian kernel: Linux version 2.6.18-4-686 (Debian 2.6.18.dfsg.1-12) (waldi@debian.org) (gcc version 4.1.2 20061115 (prerelease) (Debian 4.1.1-21)) #1 SMP Mon Mar 26 17:17:36 UTC 2007
Apr 21 11:57:40 debian kernel: BIOS-provided physical RAM map:
Apr 21 11:57:40 debian kernel: BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
Apr 21 11:57:40 debian kernel: BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
Apr 21 11:57:40 debian kernel: BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
Apr 21 11:57:40 debian kernel: BIOS-e820: 0000000000100000 - 000000003fff0000 (usable)
Apr 21 11:57:40 debian kernel: BIOS-e820: 000000003fff0000 - 000000003fff3000 (ACPI NVS)
Apr 21 11:57:40 debian kernel: BIOS-e820: 000000003fff3000 - 0000000040000000 (ACPI data)
Apr 21 11:57:40 debian kernel: BIOS-e820: 00000000fec00000 - 0000000100000000 (reserved)
Apr 21 11:57:40 debian kernel: 127MB HIGHMEM available.
Apr 21 11:57:40 debian kernel: 896MB LOWMEM available.
Apr 21 11:57:40 debian kernel: found SMP MP-table at 000f51f0
Apr 21 11:57:40 debian kernel: DMI 2.3 present.
Apr 21 11:57:40 debian kernel: ACPI: PM-Timer IO Port: 0x1008
Apr 21 11:57:40 debian kernel: ACPI: LAPIC (acpi_id[0x00] lapic_id[0x00] enabled)
Apr 21 11:57:40 debian kernel: Processor #0 15:2 APIC version 20
Apr 21 11:57:40 debian kernel: ACPI: LAPIC (acpi_id[0x01] lapic_id[0x01] enabled)
Apr 21 11:57:40 debian kernel: Processor #1 15:2 APIC version 20
Apr 21 11:57:40 debian kernel: ACPI: LAPIC_NMI (acpi_id[0x00] dfl dfl lint[0x1])
Apr 21 11:57:40 debian kernel: ACPI: LAPIC_NMI (acpi_id[0x01] dfl dfl lint[0x1])
Apr 21 11:57:40 debian kernel: ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0])
Apr 21 11:57:40 debian kernel: IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-23
Apr 21 11:57:40 debian kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
Apr 21 11:57:40 debian kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
Apr 21 11:57:40 debian kernel: Enabling APIC mode: Flat. Using 1 I/O APICs
Apr 21 11:57:40 debian kernel: Using ACPI (MADT) for SMP configuration information
Apr 21 11:57:40 debian kernel: Allocating PCI resources starting at 50000000 (gap: 40000000:bec00000)
Apr 21 11:57:40 debian kernel: Detected 2813.741 MHz processor.
Apr 21 11:57:40 debian kernel: Built 1 zonelists. Total pages: 262128
Apr 21 11:57:40 debian kernel: Kernel command line: root=/dev/hda3 ro
Apr 21 11:57:40 debian kernel: Enabling fast FPU save and restore... done.
Apr 21 11:57:40 debian kernel: Enabling unmasked SIMD FPU exception support... done.
Apr 21 11:57:40 debian kernel: Initializing CPU#0
Apr 21 11:57:40 debian kernel: PID hash table entries: 4096 (order: 12, 16384 bytes)
Apr 21 11:57:40 debian kernel: Console: colour VGA+ 80x25
Apr 21 11:57:40 debian kernel: Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Apr 21 11:57:40 debian kernel: Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Apr 21 11:57:40 debian kernel: Memory: 1031756k/1048512k available (1544k kernel code, 16096k reserved, 577k data, 196k init, 131008k highmem)
Apr 21 11:57:40 debian kernel: Checking if this processor honours the WP bit even in supervisor mode... Ok.
Apr 21 11:57:40 debian kernel: Calibrating delay using timer specific routine.. 5631.43 BogoMIPS (lpj=11262879)
Apr 21 11:57:40 debian kernel: Security Framework v1.0.0 initialized
Apr 21 11:57:40 debian kernel: SELinux: Disabled at boot.
Apr 21 11:57:40 debian kernel: Capability LSM initialized
Apr 21 11:57:40 debian kernel: Mount-cache hash table entries: 512
Apr 21 11:57:40 debian kernel: CPU: Trace cache: 12K uops, L1 D cache: 8K
Apr 21 11:57:40 debian kernel: CPU: L2 cache: 512K
Apr 21 11:57:40 debian kernel: CPU: Physical Processor ID: 0
Apr 21 11:57:40 debian kernel: Intel machine check architecture supported.
Apr 21 11:57:40 debian kernel: Intel machine check reporting enabled on CPU#0.
Apr 21 11:57:40 debian kernel: CPU0: Intel P4/Xeon Extended MCE MSRs (12) available
Apr 21 11:57:40 debian kernel: CPU0: Thermal monitoring enabled
Apr 21 11:57:40 debian kernel: Compat vDSO mapped to ffffe000.
Apr 21 11:57:40 debian kernel: Checking 'hlt' instruction... OK.
Apr 21 11:57:40 debian kernel: SMP alternatives: switching to UP code
Apr 21 11:57:40 debian kernel: ACPI: Core revision 20060707
Apr 21 11:57:40 debian kernel: CPU0: Intel(R) Pentium(R) 4 CPU 2.80GHz stepping 09
Apr 21 11:57:40 debian kernel: SMP alternatives: switching to SMP code
Apr 21 11:57:40 debian kernel: Booting processor 1/1 eip 3000
Apr 21 11:57:40 debian kernel: Initializing CPU#1
Apr 21 11:57:40 debian kernel: Calibrating delay using timer specific routine.. 5627.46 BogoMIPS (lpj=11254931)
Apr 21 11:57:40 debian kernel: Intel machine check reporting enabled on CPU#1.
Apr 21 11:57:40 debian kernel: CPU1: Intel P4/Xeon Extended MCE MSRs (12) available
Apr 21 11:57:40 debian kernel: CPU1: Thermal monitoring enabled
Apr 21 11:57:40 debian kernel: CPU1: Intel(R) Pentium(R) 4 CPU 2.80GHz stepping 09
Apr 21 11:57:40 debian kernel: Total of 2 processors activated (11258.90 BogoMIPS).
Apr 21 11:57:40 debian kernel: ENABLING IO-APIC IRQs
Apr 21 11:57:40 debian kernel: ..TIMER: vector=0x31 apic1=0 pin1=2 apic2=-1 pin2=-1
Apr 21 11:57:40 debian kernel: checking TSC synchronization across 2 CPUs: passed.
Apr 21 11:57:40 debian kernel: Brought up 2 CPUs
Apr 21 11:57:40 debian kernel: migration_cost=15
Apr 21 11:57:40 debian kernel: checking if image is initramfs... it is
Apr 21 11:57:40 debian kernel: Freeing initrd memory: 4390k freed
Apr 21 11:57:40 debian kernel: NET: Registered protocol family 16
Apr 21 11:57:40 debian kernel: ACPI: bus type pci registered
Apr 21 11:57:40 debian kernel: PCI: PCI BIOS revision 2.10 entry at 0xfb4f0, last bus=3
Apr 21 11:57:40 debian kernel: PCI: Using configuration type 1
Apr 21 11:57:40 debian kernel: Setting up standard PCI resources
Apr 21 11:57:40 debian kernel: ACPI: Interpreter enabled
Apr 21 11:57:40 debian kernel: ACPI: Using IOAPIC for interrupt routing
Apr 21 11:57:40 debian kernel: ACPI: PCI Root Bridge [PCI0] (0000:00)
Apr 21 11:57:40 debian kernel: PCI quirk: region 1000-107f claimed by ICH4 ACPI/GPIO/TCO
Apr 21 11:57:40 debian kernel: PCI quirk: region 1080-10bf claimed by ICH4 GPIO
Apr 21 11:57:40 debian kernel: PCI: Ignoring BAR0-3 of IDE controller 0000:00:1f.1
Apr 21 11:57:40 debian kernel: PCI: Transparent bridge - 0000:00:1e.0
Apr 21 11:57:40 debian kernel: ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 9 10 *11 12 14 15)
Apr 21 11:57:40 debian kernel: ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 7 9 *10 11 12 14 15)
Apr 21 11:57:40 debian kernel: ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 *5 6 7 9 10 11 12 14 15)
Apr 21 11:57:40 debian kernel: ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 7 9 *10 11 12 14 15)
Apr 21 11:57:40 debian kernel: ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 7 9 10 11 12 14 15) *0, disabled.
Apr 21 11:57:40 debian kernel: ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 7 *9 10 11 12 14 15)
Apr 21 11:57:40 debian kernel: ACPI: PCI Interrupt Link [LNK0] (IRQs 3 4 5 6 7 9 10 11 12 14 15) *0, disabled.
Apr 21 11:57:40 debian kernel: ACPI: PCI Interrupt Link [LNK1] (IRQs 3 4 5 6 7 9 10 *11 12 14 15)
Apr 21 11:57:40 debian kernel: Linux Plug and Play Support v0.97 (c) Adam Belay
Apr 21 11:57:40 debian kernel: pnp: PnP ACPI init
Apr 21 11:57:40 debian kernel: pnp: PnP ACPI: found 15 devices
Apr 21 11:57:40 debian kernel: PnPBIOS: Disabled by ACPI PNP
Apr 21 11:57:40 debian kernel: PCI: Using ACPI for IRQ routing
Apr 21 11:57:40 debian kernel: PCI: If a device doesn't work, try "pci=routeirq". If it helps, post a report
Apr 21 11:57:40 debian kernel: PCI: Bridge: 0000:00:01.0
Apr 21 11:57:40 debian kernel: IO window: disabled.
Apr 21 11:57:40 debian kernel: MEM window: f8000000-faffffff
Apr 21 11:57:40 debian kernel: PREFETCH window: e0000000-efffffff
Apr 21 11:57:40 debian kernel: PCI: Bridge: 0000:00:03.0
Apr 21 11:57:40 debian kernel: IO window: a000-afff
Apr 21 11:57:40 debian kernel: MEM window: fb000000-fb0fffff
Apr 21 11:57:40 debian kernel: PREFETCH window: disabled.
Apr 21 11:57:40 debian kernel: PCI: Bridge: 0000:00:1e.0
Apr 21 11:57:40 debian kernel: MEM window: fb100000-fb1fffff
Apr 21 11:57:40 debian kernel: NET: Registered protocol family 2
Apr 21 11:57:40 debian kernel: IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
Apr 21 11:57:40 debian kernel: TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
Apr 21 11:57:40 debian kernel: TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
Apr 21 11:57:40 debian kernel: TCP: Hash tables configured (established 131072 bind 65536)
Apr 21 11:57:40 debian kernel: TCP reno registered
Apr 21 11:57:40 debian kernel: audit: initializing netlink socket (disabled)
Apr 21 11:57:40 debian kernel: audit(1177156646.968:1): initialized
Apr 21 11:57:40 debian kernel: highmem bounce pool size: 64 pages
Apr 21 11:57:40 debian kernel: VFS: Disk quotas dquot_6.5.1
Apr 21 11:57:40 debian kernel: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Apr 21 11:57:40 debian kernel: Initializing Cryptographic API
Apr 21 11:57:40 debian kernel: io scheduler noop registered
Apr 21 11:57:40 debian kernel: io scheduler anticipatory registered
Apr 21 11:57:40 debian kernel: io scheduler deadline registered
Apr 21 11:57:40 debian kernel: io scheduler cfq registered (default)
Apr 21 11:57:40 debian kernel: isapnp: Scanning for PnP cards...
Apr 21 11:57:40 debian kernel: isapnp: No Plug & Play device found
Apr 21 11:57:40 debian kernel: Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled
Apr 21 11:57:40 debian kernel: serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
Apr 21 11:57:40 debian kernel: serial8250: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
Apr 21 11:57:40 debian kernel: 00:09: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
Apr 21 11:57:40 debian kernel: 00:0a: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
Apr 21 11:57:40 debian kernel: RAMDISK driver initialized: 16 RAM disks of 8192K size 1024 blocksize
Apr 21 11:57:40 debian kernel: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
Apr 21 11:57:40 debian kernel: serio: i8042 AUX port at 0x60,0x64 irq 12
Apr 21 11:57:40 debian kernel: serio: i8042 KBD port at 0x60,0x64 irq 1
Apr 21 11:57:40 debian kernel: mice: PS/2 mouse device common for all mice
Apr 21 11:57:40 debian kernel: TCP bic registered
Apr 21 11:57:40 debian kernel: NET: Registered protocol family 17
Apr 21 11:57:40 debian kernel: NET: Registered protocol family 8
Apr 21 11:57:40 debian kernel: NET: Registered protocol family 20
Apr 21 11:57:40 debian kernel: Starting balanced_irq
Apr 21 11:57:40 debian kernel: Using IPI No-Shortcut mode
Apr 21 11:57:40 debian kernel: ACPI: (supports S0 S1 S4 S5)
Apr 21 11:57:40 debian kernel: Freeing unused kernel memory: 196k freed
Apr 21 11:57:40 debian kernel: Time: tsc clocksource has been installed.
Apr 21 11:57:40 debian kernel: input: AT Translated Set 2 keyboard as /class/input/input0
Apr 21 11:57:40 debian kernel: usbcore: registered new driver usbfs
Apr 21 11:57:40 debian kernel: usbcore: registered new driver hub
Apr 21 11:57:40 debian kernel: USB Universal Host Controller Interface driver v3.0
Apr 21 11:57:40 debian kernel: ACPI: PCI Interrupt 0000:00:1d.0[A] -> GSI 16 (level, low) -> IRQ 169
Apr 21 11:57:40 debian kernel: uhci_hcd 0000:00:1d.0: UHCI Host Controller
Apr 21 11:57:40 debian kernel: uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 1
Apr 21 11:57:40 debian kernel: uhci_hcd 0000:00:1d.0: irq 169, io base 0x0000b000
Apr 21 11:57:40 debian kernel: usb usb1: configuration #1 chosen from 1 choice
Apr 21 11:57:40 debian kernel: hub 1-0:1.0: USB hub found
Apr 21 11:57:40 debian kernel: hub 1-0:1.0: 2 ports detected
Apr 21 11:57:40 debian kernel: Intel(R) PRO/1000 Network Driver - version 7.1.9-k4-NAPI
Apr 21 11:57:40 debian kernel: Copyright (c) 1999-2006 Intel Corporation.
Apr 21 11:57:40 debian kernel: Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
Apr 21 11:57:40 debian kernel: ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
Apr 21 11:57:40 debian kernel: ACPI: PCI Interrupt 0000:00:1d.1[B] -> GSI 19 (level, low) -> IRQ 177
Apr 21 11:57:40 debian kernel: uhci_hcd 0000:00:1d.1: UHCI Host Controller
Apr 21 11:57:40 debian kernel: uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 2
Apr 21 11:57:40 debian kernel: uhci_hcd 0000:00:1d.1: irq 177, io base 0x0000b400
Apr 21 11:57:40 debian kernel: usb usb2: configuration #1 chosen from 1 choice
Apr 21 11:57:40 debian kernel: hub 2-0:1.0: USB hub found
Apr 21 11:57:40 debian kernel: hub 2-0:1.0: 2 ports detected
Apr 21 11:57:40 debian kernel: ACPI: PCI Interrupt 0000:00:1d.2[C] -> GSI 18 (level, low) -> IRQ 185
Apr 21 11:57:40 debian kernel: uhci_hcd 0000:00:1d.2: UHCI Host Controller
Apr 21 11:57:40 debian kernel: uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 3
Apr 21 11:57:40 debian kernel: uhci_hcd 0000:00:1d.2: irq 185, io base 0x0000b800
Apr 21 11:57:40 debian kernel: usb usb3: configuration #1 chosen from 1 choice
Apr 21 11:57:40 debian kernel: hub 3-0:1.0: USB hub found
Apr 21 11:57:40 debian kernel: hub 3-0:1.0: 2 ports detected
Apr 21 11:57:40 debian kernel: ACPI: PCI Interrupt 0000:00:1d.3[A] -> GSI 16 (level, low) -> IRQ 169
Apr 21 11:57:40 debian kernel: uhci_hcd 0000:00:1d.3: UHCI Host Controller
Apr 21 11:57:40 debian kernel: uhci_hcd 0000:00:1d.3: new USB bus registered, assigned bus number 4
Apr 21 11:57:40 debian kernel: uhci_hcd 0000:00:1d.3: irq 169, io base 0x0000bc00
Apr 21 11:57:40 debian kernel: usb usb4: configuration #1 chosen from 1 choice
Apr 21 11:57:40 debian kernel: hub 4-0:1.0: USB hub found
Apr 21 11:57:40 debian kernel: hub 4-0:1.0: 2 ports detected
Apr 21 11:57:40 debian kernel: usb 1-1: new full speed USB device using uhci_hcd and address 2
Apr 21 11:57:40 debian kernel: ACPI: PCI Interrupt 0000:02:01.0[A] -> GSI 18 (level, low) -> IRQ 185
Apr 21 11:57:40 debian kernel: usb 1-1: configuration #1 chosen from 1 choice
Apr 21 11:57:40 debian kernel: e1000: 0000:02:01.0: e1000_probe: (PCI:33MHz:32-bit) 00:0d:61:40:56:b7
Apr 21 11:57:40 debian kernel: e1000: eth0: e1000_probe: Intel(R) PRO/1000 Network Connection
Apr 21 11:57:40 debian kernel: ICH5: IDE controller at PCI slot 0000:00:1f.1
Apr 21 11:57:40 debian kernel: ACPI: PCI Interrupt 0000:00:1f.1[A] -> GSI 18 (level, low) -> IRQ 185
Apr 21 11:57:40 debian kernel: ICH5: chipset revision 2
Apr 21 11:57:40 debian kernel: ICH5: not 100%% native mode: will probe irqs later
Apr 21 11:57:40 debian kernel: ide0: BM-DMA at 0xf000-0xf007, BIOS settings: hda:DMA, hdb:DMA
Apr 21 11:57:40 debian kernel: ide1: BM-DMA at 0xf008-0xf00f, BIOS settings: hdc:DMA, hdd:DMA
Apr 21 11:57:40 debian kernel: hda: Maxtor 6L200P0, ATA DISK drive
Apr 21 11:57:40 debian kernel: hdb: Maxtor 6Y080L0, ATA DISK drive
Apr 21 11:57:40 debian kernel: ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
Apr 21 11:57:40 debian kernel: hdc: HL-DT-STDVD-ROM GDR8162B, ATAPI CD/DVD-ROM drive
Apr 21 11:57:40 debian kernel: hdd: CDRW5224, ATAPI CD/DVD-ROM drive
Apr 21 11:57:40 debian kernel: ide1 at 0x170-0x177,0x376 on irq 15
Apr 21 11:57:40 debian kernel: ACPI: PCI Interrupt 0000:00:1d.7[D] -> GSI 23 (level, low) -> IRQ 193
Apr 21 11:57:40 debian kernel: ehci_hcd 0000:00:1d.7: EHCI Host Controller
Apr 21 11:57:40 debian kernel: ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 5
Apr 21 11:57:40 debian kernel: ehci_hcd 0000:00:1d.7: irq 193, io mem 0xfb200000
Apr 21 11:57:40 debian kernel: ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
Apr 21 11:57:40 debian kernel: usb usb5: configuration #1 chosen from 1 choice
Apr 21 11:57:40 debian kernel: hub 5-0:1.0: USB hub found
Apr 21 11:57:40 debian kernel: hub 5-0:1.0: 8 ports detected
Apr 21 11:57:40 debian kernel: ACPI: PCI Interrupt 0000:03:05.0[A] -> GSI 21 (level, low) -> IRQ 201
Apr 21 11:57:40 debian kernel: ohci1394: fw-host0: OHCI-1394 1.1 (PCI): IRQ=[201] MMIO=[fb104000-fb1047ff] Max Packet=[2048] IR/IT contexts=[4/8]
Apr 21 11:57:40 debian kernel: hda: max request size: 512KiB
Apr 21 11:57:40 debian kernel: hda: 398297088 sectors (203928 MB) w/8192KiB Cache, CHS=24792/255/63, UDMA(100)
Apr 21 11:57:40 debian kernel: hda: cache flushes supported
Apr 21 11:57:40 debian kernel: hda: hda1 hda2 < hda5 hda6 hda7 > hda3
Apr 21 11:57:40 debian kernel: hdb: max request size: 128KiB
Apr 21 11:57:40 debian kernel: hdb: 160086528 sectors (81964 MB) w/2048KiB Cache, CHS=65535/16/63, UDMA(100)
Apr 21 11:57:40 debian kernel: hdb: cache flushes supported
Apr 21 11:57:40 debian kernel: hdb: hdb1 < hdb5 >
Apr 21 11:57:40 debian kernel: hdc: ATAPI 48X DVD-ROM drive, 256kB Cache, UDMA(33)
Apr 21 11:57:40 debian kernel: Uniform CD-ROM driver Revision: 3.20
Apr 21 11:57:40 debian kernel: hdd: ATAPI 52X CD-ROM CD-R/RW drive, 2048kB Cache, UDMA(33)
Apr 21 11:57:40 debian kernel: usb 1-1: USB disconnect, address 2
Apr 21 11:57:40 debian kernel: usb 1-1: new full speed USB device using uhci_hcd and address 3
Apr 21 11:57:40 debian kernel: Attempting manual resume
Apr 21 11:57:40 debian kernel: kjournald starting. Commit interval 5 seconds
Apr 21 11:57:40 debian kernel: EXT3-fs: mounted filesystem with ordered data mode.
Apr 21 11:57:40 debian kernel: eth1394: eth0: IEEE-1394 IPv4 over 1394 Ethernet (fw-host0)
Apr 21 11:57:40 debian kernel: pci_hotplug: PCI Hot Plug PCI Core version: 0.5
Apr 21 11:57:40 debian kernel: shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
Apr 21 11:57:40 debian kernel: Linux agpgart interface v0.101 (c) Dave Jones
Apr 21 11:57:40 debian kernel: agpgart: Detected an Intel 865 Chipset.
Apr 21 11:57:40 debian kernel: agpgart: AGP aperture is 128M @ 0xf0000000
Apr 21 11:57:40 debian kernel: Real Time Clock Driver v1.12ac
Apr 21 11:57:40 debian kernel: input: PC Speaker as /class/input/input1
Apr 21 11:57:40 debian kernel: ACPI: PCI Interrupt 0000:00:1f.3[B] -> GSI 17 (level, low) -> IRQ 209
Apr 21 11:57:40 debian kernel: Floppy drive(s): fd0 is 1.44M
Apr 21 11:57:40 debian kernel: FDC 0 is a post-1991 82077
Apr 21 11:57:40 debian kernel: parport: PnPBIOS parport detected.
Apr 21 11:57:40 debian kernel: parport0: PC-style at 0x378, irq 7 [PCSPP,TRISTATE]
Apr 21 11:57:40 debian kernel: ACPI: PCI Interrupt 0000:00:1f.5[B] -> GSI 17 (level, low) -> IRQ 209
Apr 21 11:57:40 debian kernel: logips2pp: Detected unknown logitech mouse model 101
Apr 21 11:57:40 debian kernel: intel8x0_measure_ac97_clock: measured 53645 usecs
Apr 21 11:57:40 debian kernel: intel8x0: clocking to 48000
Apr 21 11:57:40 debian kernel: input: ImExPS/2 Logitech Explorer Mouse as /class/input/input2
Apr 21 11:57:40 debian kernel: ts: Compaq touchscreen protocol output
Apr 21 11:57:40 debian kernel: Adding 2650684k swap on /dev/hda6. Priority:-1 extents:1 across:2650684k
Apr 21 11:57:40 debian kernel: EXT3 FS on hda3, internal journal
Apr 21 11:57:40 debian kernel: loop: loaded (max 8 devices)
Apr 21 11:57:40 debian kernel: SCSI subsystem initialized
Apr 21 11:57:40 debian kernel: ieee1394: sbp2: Driver forced to serialize I/O (serialize_io=1)
Apr 21 11:57:40 debian kernel: ieee1394: sbp2: Try serialize_io=0 for better performance
Apr 21 11:57:40 debian kernel: device-mapper: ioctl: 4.7.0-ioctl (2006-06-24) initialised: dm-devel@redhat.com
Apr 21 11:57:40 debian kernel: EXT3 FS on hda7, internal journal
Apr 21 11:57:40 debian kernel: NTFS driver 2.1.27 [Flags: R/W MODULE].
Apr 21 11:57:40 debian kernel: NTFS volume version 3.1.
Apr 21 11:57:40 debian kernel: e1000: eth1: e1000_watchdog: NIC Link is Up 100 Mbps Full Duplex
Apr 21 11:57:40 debian kernel: ACPI: Power Button (FF) [PWRF]
Apr 21 11:57:40 debian kernel: ACPI: Power Button (CM) [PWRB]
Apr 21 11:57:40 debian kernel: ACPI: Sleep Button (CM) [SLPB]
Apr 21 11:57:45 debian kernel: nvidia: module license 'NVIDIA' taints kernel.
Apr 21 11:57:45 debian kernel: ACPI: PCI Interrupt 0000:01:00.0[A] -> GSI 16 (level, low) -> IRQ 169
Apr 21 11:57:45 debian kernel: NVRM: loading NVIDIA Linux x86 Kernel Module 1.0-8776 Mon Oct 16 21:56:04 PDT 2006
Apr 21 11:57:46 debian kernel: agpgart: Found an AGP 3.0 compliant device at 0000:00:00.0.
Apr 21 11:57:46 debian kernel: agpgart: Putting AGP V3 device at 0000:00:00.0 into 8x mode
Apr 21 11:57:46 debian kernel: agpgart: Putting AGP V3 device at 0000:01:00.0 into 8x mode
Apr 21 11:57:56 debian gconfd (titib-2827): démarrage (version 2.16.1), pid 2827 utilisateur « titib »
Apr 21 11:57:56 debian gconfd (titib-2827): Adresse « xml:readonly:/etc/gconf/gconf.xml.mandatory » résolue vers une source de configuration en lecture seule à la position 0
Apr 21 11:57:56 debian gconfd (titib-2827): Adresse « xml:readwrite:/home/titib/.gconf » résolue vers une source de configuration accessible en écriture à la position 1
Apr 21 11:57:56 debian gconfd (titib-2827): Adresse « xml:readonly:/etc/gconf/gconf.xml.defaults » résolue vers une source de configuration en lecture seule à la position 2
Apr 21 11:57:56 debian gconfd (titib-2827): Adresse « xml:readonly:/var/lib/gconf/debian.defaults » résolue vers une source de configuration en lecture seule à la position 3
Apr 21 11:57:56 debian gconfd (titib-2827): Adresse « xml:readonly:/var/lib/gconf/defaults » résolue vers une source de configuration en lecture seule à la position 4
Apr 21 11:57:58 debian kernel: NET: Registered protocol family 10
Apr 21 11:57:58 debian kernel: lo: Disabled Privacy Extensions
Apr 21 11:57:58 debian kernel: IPv6 over IPv4 tunneling driver
Apr 21 11:57:59 debian gconfd (titib-2827): Adresse « xml:readwrite:/home/titib/.gconf » résolue vers une source de configuration accessible en écriture à la position 0
Apr 21 12:06:51 debian syslogd 1.4.1#20: restart.
Apr 21 12:06:51 debian kernel: klogd 1.4.1#20, log source = /proc/kmsg started.
Apr 21 12:06:51 debian kernel: Linux version 2.6.18-4-686 (Debian 2.6.18.dfsg.1-12) (waldi@debian.org) (gcc version 4.1.2 20061115 (prerelease) (Debian 4.1.1-21)) #1 SMP Mon Mar 26 17:17:36 UTC 2007
Apr 21 12:06:51 debian kernel: BIOS-provided physical RAM map:
Apr 21 12:06:51 debian kernel: BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
Apr 21 12:06:51 debian kernel: BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
Apr 21 12:06:51 debian kernel: BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
Apr 21 12:06:51 debian kernel: BIOS-e820: 0000000000100000 - 000000003fff0000 (usable)
Apr 21 12:06:51 debian kernel: BIOS-e820: 000000003fff0000 - 000000003fff3000 (ACPI NVS)
Apr 21 12:06:51 debian kernel: BIOS-e820: 000000003fff3000 - 0000000040000000 (ACPI data)
Apr 21 12:06:51 debian kernel: BIOS-e820: 00000000fec00000 - 0000000100000000 (reserved)
Apr 21 12:06:51 debian kernel: 127MB HIGHMEM available.
Apr 21 12:06:51 debian kernel: 896MB LOWMEM available.
Apr 21 12:06:51 debian kernel: found SMP MP-table at 000f51f0
Apr 21 12:06:51 debian kernel: DMI 2.3 present.
Apr 21 12:06:51 debian kernel: ACPI: PM-Timer IO Port: 0x1008
Apr 21 12:06:51 debian kernel: ACPI: LAPIC (acpi_id[0x00] lapic_id[0x00] enabled)
Apr 21 12:06:51 debian kernel: Processor #0 15:2 APIC version 20
Apr 21 12:06:51 debian kernel: ACPI: LAPIC (acpi_id[0x01] lapic_id[0x01] enabled)
Apr 21 12:06:51 debian kernel: Processor #1 15:2 APIC version 20
Apr 21 12:06:51 debian kernel: ACPI: LAPIC_NMI (acpi_id[0x00] dfl dfl lint[0x1])
Apr 21 12:06:51 debian kernel: ACPI: LAPIC_NMI (acpi_id[0x01] dfl dfl lint[0x1])
Apr 21 12:06:51 debian kernel: ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0])
Apr 21 12:06:51 debian kernel: IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-23
Apr 21 12:06:51 debian kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
Apr 21 12:06:51 debian kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
Apr 21 12:06:51 debian kernel: Enabling APIC mode: Flat. Using 1 I/O APICs
Apr 21 12:06:51 debian kernel: Using ACPI (MADT) for SMP configuration information
Apr 21 12:06:51 debian kernel: Allocating PCI resources starting at 50000000 (gap: 40000000:bec00000)
Apr 21 12:06:51 debian kernel: Detected 2813.624 MHz processor.
Apr 21 12:06:51 debian kernel: Built 1 zonelists. Total pages: 262128
Apr 21 12:06:51 debian kernel: Kernel command line: root=/dev/hda3 ro
Apr 21 12:06:51 debian kernel: Enabling fast FPU save and restore... done.
Apr 21 12:06:51 debian kernel: Enabling unmasked SIMD FPU exception support... done.
Apr 21 12:06:51 debian kernel: Initializing CPU#0
Apr 21 12:06:51 debian kernel: PID hash table entries: 4096 (order: 12, 16384 bytes)
Apr 21 12:06:51 debian kernel: Console: colour VGA+ 80x25
Apr 21 12:06:51 debian kernel: Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Apr 21 12:06:51 debian kernel: Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Apr 21 12:06:51 debian kernel: Memory: 1031756k/1048512k available (1544k kernel code, 16096k reserved, 577k data, 196k init, 131008k highmem)
Apr 21 12:06:51 debian kernel: Checking if this processor honours the WP bit even in supervisor mode... Ok.
Apr 21 12:06:51 debian kernel: Calibrating delay using timer specific routine.. 5631.39 BogoMIPS (lpj=11262796)
Apr 21 12:06:51 debian kernel: Security Framework v1.0.0 initialized
Apr 21 12:06:51 debian kernel: SELinux: Disabled at boot.
Apr 21 12:06:51 debian kernel: Capability LSM initialized
Apr 21 12:06:51 debian kernel: Mount-cache hash table entries: 512
Apr 21 12:06:51 debian kernel: CPU: Trace cache: 12K uops, L1 D cache: 8K
Apr 21 12:06:51 debian kernel: CPU: L2 cache: 512K
Apr 21 12:06:51 debian kernel: CPU: Physical Processor ID: 0
Apr 21 12:06:51 debian kernel: Intel machine check architecture supported.
Apr 21 12:06:51 debian kernel: Intel machine check reporting enabled on CPU#0.
Apr 21 12:06:51 debian kernel: CPU0: Intel P4/Xeon Extended MCE MSRs (12) available
Apr 21 12:06:51 debian kernel: CPU0: Thermal monitoring enabled
Apr 21 12:06:51 debian kernel: Compat vDSO mapped to ffffe000.
Apr 21 12:06:51 debian kernel: Checking 'hlt' instruction... OK.
Apr 21 12:06:51 debian kernel: SMP alternatives: switching to UP code
Apr 21 12:06:51 debian kernel: ACPI: Core revision 20060707
Apr 21 12:06:51 debian kernel: CPU0: Intel(R) Pentium(R) 4 CPU 2.80GHz stepping 09
Apr 21 12:06:51 debian kernel: SMP alternatives: switching to SMP code
Apr 21 12:06:51 debian kernel: Booting processor 1/1 eip 3000
Apr 21 12:06:51 debian kernel: Initializing CPU#1
Apr 21 12:06:51 debian kernel: Calibrating delay using timer specific routine.. 5627.43 BogoMIPS (lpj=11254872)
Apr 21 12:06:51 debian kernel: Intel machine check reporting enabled on CPU#1.
Apr 21 12:06:51 debian kernel: CPU1: Intel P4/Xeon Extended MCE MSRs (12) available
Apr 21 12:06:51 debian kernel: CPU1: Thermal monitoring enabled
Apr 21 12:06:51 debian kernel: CPU1: Intel(R) Pentium(R) 4 CPU 2.80GHz stepping 09
Apr 21 12:06:51 debian kernel: Total of 2 processors activated (11258.83 BogoMIPS).
Apr 21 12:06:51 debian kernel: ENABLING IO-APIC IRQs
Apr 21 12:06:51 debian kernel: ..TIMER: vector=0x31 apic1=0 pin1=2 apic2=-1 pin2=-1
Apr 21 12:06:51 debian kernel: checking TSC synchronization across 2 CPUs: passed.
Apr 21 12:06:51 debian kernel: Brought up 2 CPUs
Apr 21 12:06:51 debian kernel: migration_cost=189
Apr 21 12:06:51 debian kernel: checking if image is initramfs... it is
Apr 21 12:06:51 debian kernel: Freeing initrd memory: 4390k freed
Apr 21 12:06:51 debian kernel: NET: Registered protocol family 16
Apr 21 12:06:51 debian kernel: ACPI: bus type pci registered
Apr 21 12:06:51 debian kernel: PCI: PCI BIOS revision 2.10 entry at 0xfb4f0, last bus=3
Apr 21 12:06:51 debian kernel: PCI: Using configuration type 1
Apr 21 12:06:51 debian kernel: Setting up standard PCI resources
Apr 21 12:06:51 debian kernel: ACPI: Interpreter enabled
Apr 21 12:06:51 debian kernel: ACPI: Using IOAPIC for interrupt routing
Apr 21 12:06:51 debian kernel: ACPI: PCI Root Bridge [PCI0] (0000:00)
Apr 21 12:06:51 debian kernel: PCI quirk: region 1000-107f claimed by ICH4 ACPI/GPIO/TCO
Apr 21 12:06:51 debian kernel: PCI quirk: region 1080-10bf claimed by ICH4 GPIO
Apr 21 12:06:51 debian kernel: PCI: Ignoring BAR0-3 of IDE controller 0000:00:1f.1
Apr 21 12:06:51 debian kernel: PCI: Transparent bridge - 0000:00:1e.0
Apr 21 12:06:51 debian kernel: ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 9 10 *11 12 14 15)
Apr 21 12:06:51 debian kernel: ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 7 9 *10 11 12 14 15)
Apr 21 12:06:51 debian kernel: ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 *5 6 7 9 10 11 12 14 15)
Apr 21 12:06:51 debian kernel: ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 7 9 *10 11 12 14 15)
Apr 21 12:06:51 debian kernel: ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 7 9 10 11 12 14 15) *0, disabled.
Apr 21 12:06:51 debian kernel: ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 7 *9 10 11 12 14 15)
Apr 21 12:06:51 debian kernel: ACPI: PCI Interrupt Link [LNK0] (IRQs 3 4 5 6 7 9 10 11 12 14 15) *0, disabled.
Apr 21 12:06:51 debian kernel: ACPI: PCI Interrupt Link [LNK1] (IRQs 3 4 5 6 7 9 10 *11 12 14 15)
Apr 21 12:06:51 debian kernel: Linux Plug and Play Support v0.97 (c) Adam Belay
Apr 21 12:06:51 debian kernel: pnp: PnP ACPI init
Apr 21 12:06:51 debian kernel: pnp: PnP ACPI: found 15 devices
Apr 21 12:06:51 debian kernel: PnPBIOS: Disabled by ACPI PNP
Apr 21 12:06:51 debian kernel: PCI: Using ACPI for IRQ routing
Apr 21 12:06:51 debian kernel: PCI: If a device doesn't work, try "pci=routeirq". If it helps, post a report
Apr 21 12:06:51 debian kernel: PCI: Bridge: 0000:00:01.0
Apr 21 12:06:51 debian kernel: IO window: disabled.
Apr 21 12:06:51 debian kernel: MEM window: f8000000-faffffff
Apr 21 12:06:51 debian kernel: PREFETCH window: e0000000-efffffff
Apr 21 12:06:51 debian kernel: PCI: Bridge: 0000:00:03.0
Apr 21 12:06:51 debian kernel: IO window: a000-afff
Apr 21 12:06:51 debian kernel: MEM window: fb000000-fb0fffff
Apr 21 12:06:51 debian kernel: PREFETCH window: disabled.
Apr 21 12:06:51 debian kernel: PCI: Bridge: 0000:00:1e.0
Apr 21 12:06:51 debian kernel: MEM window: fb100000-fb1fffff
Apr 21 12:06:51 debian kernel: NET: Registered protocol family 2
Apr 21 12:06:51 debian kernel: IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
Apr 21 12:06:51 debian kernel: TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
Apr 21 12:06:51 debian kernel: TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
Apr 21 12:06:51 debian kernel: TCP: Hash tables configured (established 131072 bind 65536)
Apr 21 12:06:51 debian kernel: TCP reno registered
Apr 21 12:06:51 debian kernel: audit: initializing netlink socket (disabled)
Apr 21 12:06:51 debian kernel: audit(1177157198.024:1): initialized
Apr 21 12:06:51 debian kernel: highmem bounce pool size: 64 pages
Apr 21 12:06:51 debian kernel: VFS: Disk quotas dquot_6.5.1
Apr 21 12:06:51 debian kernel: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Apr 21 12:06:51 debian kernel: Initializing Cryptographic API
Apr 21 12:06:51 debian kernel: io scheduler noop registered
Apr 21 12:06:51 debian kernel: io scheduler anticipatory registered
Apr 21 12:06:51 debian kernel: io scheduler deadline registered
Apr 21 12:06:51 debian kernel: io scheduler cfq registered (default)
Apr 21 12:06:51 debian kernel: isapnp: Scanning for PnP cards...
Apr 21 12:06:51 debian kernel: isapnp: No Plug & Play device found
Apr 21 12:06:51 debian kernel: Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled
Apr 21 12:06:51 debian kernel: serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
Apr 21 12:06:51 debian kernel: serial8250: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
Apr 21 12:06:51 debian kernel: 00:09: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
Apr 21 12:06:51 debian kernel: 00:0a: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
Apr 21 12:06:51 debian kernel: RAMDISK driver initialized: 16 RAM disks of 8192K size 1024 blocksize
Apr 21 12:06:51 debian kernel: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
Apr 21 12:06:51 debian kernel: serio: i8042 AUX port at 0x60,0x64 irq 12
Apr 21 12:06:51 debian kernel: serio: i8042 KBD port at 0x60,0x64 irq 1
Apr 21 12:06:51 debian kernel: mice: PS/2 mouse device common for all mice
Apr 21 12:06:51 debian kernel: TCP bic registered
Apr 21 12:06:51 debian kernel: NET: Registered protocol family 17
Apr 21 12:06:51 debian kernel: NET: Registered protocol family 8
Apr 21 12:06:51 debian kernel: NET: Registered protocol family 20
Apr 21 12:06:51 debian kernel: Starting balanced_irq
Apr 21 12:06:51 debian kernel: Using IPI No-Shortcut mode
Apr 21 12:06:51 debian kernel: ACPI: (supports S0 S1 S4 S5)
Apr 21 12:06:51 debian kernel: Freeing unused kernel memory: 196k freed
Apr 21 12:06:51 debian kernel: Time: tsc clocksource has been installed.
Apr 21 12:06:51 debian kernel: input: AT Translated Set 2 keyboard as /class/input/input0
Apr 21 12:06:51 debian kernel: usbcore: registered new driver usbfs
Apr 21 12:06:51 debian kernel: usbcore: registered new driver hub
Apr 21 12:06:51 debian kernel: ACPI: PCI Interrupt 0000:00:1d.7[D] -> GSI 23 (level, low) -> IRQ 169
Apr 21 12:06:51 debian kernel: ehci_hcd 0000:00:1d.7: EHCI Host Controller
Apr 21 12:06:51 debian kernel: ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 1
Apr 21 12:06:51 debian kernel: ehci_hcd 0000:00:1d.7: irq 169, io mem 0xfb200000
Apr 21 12:06:51 debian kernel: ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
Apr 21 12:06:51 debian kernel: usb usb1: configuration #1 chosen from 1 choice
Apr 21 12:06:51 debian kernel: hub 1-0:1.0: USB hub found
Apr 21 12:06:51 debian kernel: hub 1-0:1.0: 8 ports detected
Apr 21 12:06:51 debian kernel: Intel(R) PRO/1000 Network Driver - version 7.1.9-k4-NAPI
Apr 21 12:06:51 debian kernel: Copyright (c) 1999-2006 Intel Corporation.
Apr 21 12:06:51 debian kernel: USB Universal Host Controller Interface driver v3.0
Apr 21 12:06:51 debian kernel: Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
Apr 21 12:06:51 debian kernel: ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
Apr 21 12:06:51 debian kernel: ACPI: PCI Interrupt 0000:00:1d.0[A] -> GSI 16 (level, low) -> IRQ 177
Apr 21 12:06:51 debian kernel: uhci_hcd 0000:00:1d.0: UHCI Host Controller
Apr 21 12:06:51 debian kernel: uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 2
Apr 21 12:06:51 debian kernel: uhci_hcd 0000:00:1d.0: irq 177, io base 0x0000b000
Apr 21 12:06:51 debian kernel: usb usb2: configuration #1 chosen from 1 choice
Apr 21 12:06:51 debian kernel: hub 2-0:1.0: USB hub found
Apr 21 12:06:51 debian kernel: hub 2-0:1.0: 2 ports detected
Apr 21 12:06:51 debian kernel: ACPI: PCI Interrupt 0000:00:1d.1[B] -> GSI 19 (level, low) -> IRQ 185
Apr 21 12:06:51 debian kernel: uhci_hcd 0000:00:1d.1: UHCI Host Controller
Apr 21 12:06:51 debian kernel: uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 3
Apr 21 12:06:51 debian kernel: uhci_hcd 0000:00:1d.1: irq 185, io base 0x0000b400
Apr 21 12:06:51 debian kernel: usb usb3: configuration #1 chosen from 1 choice
Apr 21 12:06:51 debian kernel: hub 3-0:1.0: USB hub found
Apr 21 12:06:51 debian kernel: hub 3-0:1.0: 2 ports detected
Apr 21 12:06:51 debian kernel: ACPI: PCI Interrupt 0000:00:1d.2[C] -> GSI 18 (level, low) -> IRQ 193
Apr 21 12:06:51 debian kernel: uhci_hcd 0000:00:1d.2: UHCI Host Controller
Apr 21 12:06:51 debian kernel: uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 4
Apr 21 12:06:51 debian kernel: uhci_hcd 0000:00:1d.2: irq 193, io base 0x0000b800
Apr 21 12:06:51 debian kernel: usb usb4: configuration #1 chosen from 1 choice
Apr 21 12:06:51 debian kernel: hub 4-0:1.0: USB hub found
Apr 21 12:06:51 debian kernel: hub 4-0:1.0: 2 ports detected
Apr 21 12:06:51 debian kernel: ACPI: PCI Interrupt 0000:00:1d.3[A] -> GSI 16 (level, low) -> IRQ 177
Apr 21 12:06:51 debian kernel: uhci_hcd 0000:00:1d.3: UHCI Host Controller
Apr 21 12:06:51 debian kernel: uhci_hcd 0000:00:1d.3: new USB bus registered, assigned bus number 5
Apr 21 12:06:51 debian kernel: uhci_hcd 0000:00:1d.3: irq 177, io base 0x0000bc00
Apr 21 12:06:51 debian kernel: usb usb5: configuration #1 chosen from 1 choice
Apr 21 12:06:51 debian kernel: hub 5-0:1.0: USB hub found
Apr 21 12:06:51 debian kernel: hub 5-0:1.0: 2 ports detected
Apr 21 12:06:51 debian kernel: usb 2-1: new full speed USB device using uhci_hcd and address 2
Apr 21 12:06:51 debian kernel: ACPI: PCI Interrupt 0000:02:01.0[A] -> GSI 18 (level, low) -> IRQ 193
Apr 21 12:06:51 debian kernel: usb 2-1: configuration #1 chosen from 1 choice
Apr 21 12:06:51 debian kernel: e1000: 0000:02:01.0: e1000_probe: (PCI:33MHz:32-bit) 00:0d:61:40:56:b7
Apr 21 12:06:51 debian kernel: e1000: eth0: e1000_probe: Intel(R) PRO/1000 Network Connection
Apr 21 12:06:51 debian kernel: ACPI: PCI Interrupt 0000:03:05.0[A] -> GSI 21 (level, low) -> IRQ 201
Apr 21 12:06:51 debian kernel: ohci1394: fw-host0: OHCI-1394 1.1 (PCI): IRQ=[201] MMIO=[fb104000-fb1047ff] Max Packet=[2048] IR/IT contexts=[4/8]
Apr 21 12:06:51 debian kernel: ICH5: IDE controller at PCI slot 0000:00:1f.1
Apr 21 12:06:51 debian kernel: ACPI: PCI Interrupt 0000:00:1f.1[A] -> GSI 18 (level, low) -> IRQ 193
Apr 21 12:06:51 debian kernel: ICH5: chipset revision 2
Apr 21 12:06:51 debian kernel: ICH5: not 100%% native mode: will probe irqs later
Apr 21 12:06:51 debian kernel: ide0: BM-DMA at 0xf000-0xf007, BIOS settings: hda:DMA, hdb:DMA
Apr 21 12:06:51 debian kernel: ide1: BM-DMA at 0xf008-0xf00f, BIOS settings: hdc:DMA, hdd:DMA
Apr 21 12:06:51 debian kernel: hda: Maxtor 6L200P0, ATA DISK drive
Apr 21 12:06:51 debian kernel: hdb: Maxtor 6Y080L0, ATA DISK drive
Apr 21 12:06:51 debian kernel: ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
Apr 21 12:06:51 debian kernel: hdc: HL-DT-STDVD-ROM GDR8162B, ATAPI CD/DVD-ROM drive
Apr 21 12:06:51 debian kernel: hdd: CDRW5224, ATAPI CD/DVD-ROM drive
Apr 21 12:06:51 debian kernel: ide1 at 0x170-0x177,0x376 on irq 15
Apr 21 12:06:51 debian kernel: hda: max request size: 512KiB
Apr 21 12:06:51 debian kernel: hda: 398297088 sectors (203928 MB) w/8192KiB Cache, CHS=24792/255/63, UDMA(100)
Apr 21 12:06:51 debian kernel: hda: cache flushes supported
Apr 21 12:06:51 debian kernel: hda: hda1 hda2 < hda5 hda6 hda7 > hda3
Apr 21 12:06:51 debian kernel: hdb: max request size: 128KiB
Apr 21 12:06:51 debian kernel: hdb: 160086528 sectors (81964 MB) w/2048KiB Cache, CHS=65535/16/63, UDMA(100)
Apr 21 12:06:51 debian kernel: hdb: cache flushes supported
Apr 21 12:06:51 debian kernel: hdb: hdb1 < hdb5 >
Apr 21 12:06:51 debian kernel: hdc: ATAPI 48X DVD-ROM drive, 256kB Cache, UDMA(33)
Apr 21 12:06:51 debian kernel: Uniform CD-ROM driver Revision: 3.20
Apr 21 12:06:51 debian kernel: hdd: ATAPI 52X CD-ROM CD-R/RW drive, 2048kB Cache, UDMA(33)
Apr 21 12:06:51 debian kernel: Attempting manual resume
Apr 21 12:06:51 debian kernel: EXT3-fs: INFO: recovery required on readonly filesystem.
Apr 21 12:06:51 debian kernel: EXT3-fs: write access will be enabled during recovery.
Apr 21 12:06:51 debian kernel: kjournald starting. Commit interval 5 seconds
Apr 21 12:06:51 debian kernel: EXT3-fs: recovery complete.
Apr 21 12:06:51 debian kernel: EXT3-fs: mounted filesystem with ordered data mode.
Apr 21 12:06:51 debian kernel: eth1394: eth0: IEEE-1394 IPv4 over 1394 Ethernet (fw-host0)
Apr 21 12:06:51 debian kernel: pci_hotplug: PCI Hot Plug PCI Core version: 0.5
Apr 21 12:06:51 debian kernel: shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
Apr 21 12:06:51 debian kernel: input: PC Speaker as /class/input/input1
Apr 21 12:06:51 debian kernel: Linux agpgart interface v0.101 (c) Dave Jones
Apr 21 12:06:51 debian kernel: agpgart: Detected an Intel 865 Chipset.
Apr 21 12:06:51 debian kernel: agpgart: AGP aperture is 128M @ 0xf0000000
Apr 21 12:06:51 debian kernel: ACPI: PCI Interrupt 0000:00:1f.3[B] -> GSI 17 (level, low) -> IRQ 209
Apr 21 12:06:51 debian kernel: Floppy drive(s): fd0 is 1.44M
Apr 21 12:06:51 debian kernel: parport: PnPBIOS parport detected.
Apr 21 12:06:51 debian kernel: parport0: PC-style at 0x378, irq 7 [PCSPP,TRISTATE]
Apr 21 12:06:51 debian kernel: FDC 0 is a post-1991 82077
Apr 21 12:06:51 debian kernel: Real Time Clock Driver v1.12ac
Apr 21 12:06:51 debian kernel: logips2pp: Detected unknown logitech mouse model 101
Apr 21 12:06:51 debian kernel: ACPI: PCI Interrupt 0000:00:1f.5[B] -> GSI 17 (level, low) -> IRQ 209
Apr 21 12:06:51 debian kernel: intel8x0_measure_ac97_clock: measured 57659 usecs
Apr 21 12:06:51 debian kernel: intel8x0: clocking to 48000
Apr 21 12:06:51 debian kernel: input: ImExPS/2 Logitech Explorer Mouse as /class/input/input2
Apr 21 12:06:51 debian kernel: ts: Compaq touchscreen protocol output
Apr 21 12:06:51 debian kernel: Adding 2650684k swap on /dev/hda6. Priority:-1 extents:1 across:2650684k
Apr 21 12:06:51 debian kernel: EXT3 FS on hda3, internal journal
Apr 21 12:06:51 debian kernel: loop: loaded (max 8 devices)
Apr 21 12:06:51 debian kernel: SCSI subsystem initialized
Apr 21 12:06:51 debian kernel: ieee1394: sbp2: Driver forced to serialize I/O (serialize_io=1)
Apr 21 12:06:51 debian kernel: ieee1394: sbp2: Try serialize_io=0 for better performance
Apr 21 12:06:51 debian kernel: device-mapper: ioctl: 4.7.0-ioctl (2006-06-24) initialised: dm-devel@redhat.com
Apr 21 12:06:51 debian kernel: EXT3 FS on hda7, internal journal
Apr 21 12:06:51 debian kernel: NTFS driver 2.1.27 [Flags: R/W MODULE].
Apr 21 12:06:51 debian kernel: NTFS volume version 3.1.
Apr 21 12:06:51 debian kernel: e1000: eth1: e1000_watchdog: NIC Link is Up 100 Mbps Full Duplex
Apr 21 12:06:51 debian kernel: ACPI: Power Button (FF) [PWRF]
Apr 21 12:06:51 debian kernel: ACPI: Power Button (CM) [PWRB]
Apr 21 12:06:51 debian kernel: ACPI: Sleep Button (CM) [SLPB]
Apr 21 12:06:56 debian kernel: nvidia: module license 'NVIDIA' taints kernel.
Apr 21 12:06:56 debian kernel: ACPI: PCI Interrupt 0000:01:00.0[A] -> GSI 16 (level, low) -> IRQ 177
Apr 21 12:06:56 debian kernel: NVRM: loading NVIDIA Linux x86 Kernel Module 1.0-8776 Mon Oct 16 21:56:04 PDT 2006
Apr 21 12:06:57 debian kernel: agpgart: Found an AGP 3.0 compliant device at 0000:00:00.0.
Apr 21 12:06:57 debian kernel: agpgart: Putting AGP V3 device at 0000:00:00.0 into 8x mode
Apr 21 12:06:57 debian kernel: agpgart: Putting AGP V3 device at 0000:01:00.0 into 8x mode
Apr 21 12:07:07 debian gconfd (titib-2824): démarrage (version 2.16.1), pid 2824 utilisateur « titib »
Apr 21 12:07:07 debian gconfd (titib-2824): Adresse « xml:readonly:/etc/gconf/gconf.xml.mandatory » résolue vers une source de configuration en lecture seule à la position 0
Apr 21 12:07:07 debian gconfd (titib-2824): Adresse « xml:readwrite:/home/titib/.gconf » résolue vers une source de configuration accessible en écriture à la position 1
Apr 21 12:07:07 debian gconfd (titib-2824): Adresse « xml:readonly:/etc/gconf/gconf.xml.defaults » résolue vers une source de configuration en lecture seule à la position 2
Apr 21 12:07:07 debian gconfd (titib-2824): Adresse « xml:readonly:/var/lib/gconf/debian.defaults » résolue vers une source de configuration en lecture seule à la position 3
Apr 21 12:07:07 debian gconfd (titib-2824): Adresse « xml:readonly:/var/lib/gconf/defaults » résolue vers une source de configuration en lecture seule à la position 4
Apr 21 12:07:09 debian kernel: NET: Registered protocol family 10
Apr 21 12:07:09 debian kernel: lo: Disabled Privacy Extensions
Apr 21 12:07:09 debian kernel: IPv6 over IPv4 tunneling driver
Apr 21 12:07:10 debian gconfd (titib-2824): Adresse « xml:readwrite:/home/titib/.gconf » résolue vers une source de configuration accessible en écriture à la position 0
