Freeze sur squeeze
bonjour
je vais faire court pour pouvoir poster entre deux freezes
j’ai changé ma carte graphique je ne sais pas enlever l’ancien driver
mon LSPCI
mais je dirais que je n’ai qu’une carte déclarée
et dans mon kern.log
j’ai souvent des trucs du genre
Apr 30 09:02:14 debian kernel: [ 487.609692] [drm] nouveau 0000:01:00.0: PFIFO_DMA_PUSHER - Ch 1
Apr 30 09:02:37 debian kernel: [ 508.175174] [drm] nouveau 0000:01:00.0: nouveau_channel_free: freeing fifo 1
Apr 30 09:02:37 debian kernel: [ 511.172005] [drm] nouveau 0000:01:00.0: Failed to idle channel 1.
Apr 30 09:02:39 debian kernel: [ 512.505630] [drm] nouveau 0000:01:00.0: Setting dpms mode 3 on vga encoder (output 0)
Apr 30 09:02:39 debian kernel: [ 512.515763] [drm] nouveau 0000:01:00.0: Setting dpms mode 0 on vga encoder (output 0)
Apr 30 09:02:39 debian kernel: [ 512.515770] [drm] nouveau 0000:01:00.0: Output VGA-1 is running on CRTC 0 using output @
Apr 30 09:02:39 debian kernel: [ 512.872666] [drm] nouveau 0000:01:00.0: Allocating FIFO number 1
Apr 30 09:02:39 debian kernel: [ 512.874451] [drm] nouveau 0000:01:00.0: nouveau_channel_alloc: initialised FIFO 1
Apr 30 09:03:32 debian kernel: [ 565.964950] FAT: utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive!
Apr 30 09:03:39 debian kernel: [ 572.468641] FAT: utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive!
Apr 30 09:03:39 debian kernel: [ 573.120483] kjournald starting. Commit interval 5 seconds
Apr 30 09:03:39 debian kernel: [ 573.120535] EXT3-fs warning: maximal mount count reached, running e2fsck is recommended
Apr 30 09:03:39 debian kernel: [ 573.120903] EXT3 FS on sdb5, internal journal
Apr 30 09:03:39 debian kernel: [ 573.120908] EXT3-fs: recovery complete.
Apr 30 09:03:39 debian kernel: [ 573.121200] EXT3-fs: mounted filesystem with ordered data mode.
est ce que ca suffit pour faire un diagnostic ?
merci pour vos réponses
LSCPI
00:00.0 Host bridge: VIA Technologies, Inc. VT8377 [KT400/KT600 AGP] Host Bridge
00:01.0 PCI bridge: VIA Technologies, Inc. VT8235 PCI Bridge
00:10.0 USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev 80)
00:10.1 USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev 80)
00:10.2 USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev 80)
00:10.3 USB Controller: VIA Technologies, Inc. USB 2.0 (rev 82)
00:11.0 ISA bridge: VIA Technologies, Inc. VT8235 ISA Bridge
00:11.1 IDE interface: VIA Technologies, Inc. VT82C586A/B/VT82C686/A/B/VT823x/A/C PIPC Bus Master IDE (rev 06)
00:11.5 Multimedia audio controller: VIA Technologies, Inc. VT8233/A/8235/8237 AC97 Audio Controller (rev 50)
00:12.0 Ethernet controller: VIA Technologies, Inc. VT6102 [Rhine-II] (rev 74)
01:00.0 VGA compatible controller: nVidia Corporation NV5M64 [RIVA TNT2 Model 64/Model 64 Pro] (rev 15)
Sur le wiki, le mode d’emploi des cartes graphiques :slightly_smiling:
merci beaucoup
je ne connaissais pas le wiki
on en apprend tous les jours
[quote=“menthol34”]merci beaucoup
on en apprend tous les jours[/quote]
Et pourtant tu es inscrit depuis 2007 :slightly_smiling:
j’ai regardé le wiki mais pardonnez moi je n’ai toujours aucune idée sur la façon de proceder
d’habitude je procederais de la facon suivante : je trouve une autre carte video et je refais l’install
sinon je ne sais pas faire !!
Commence par changer ton titre la faute à SQUEEZE me pique les yeux ensuite pour tes messages le plus inquiétant c’est avant tout les locales utf8 sur du fat ( c’est pas le top :confused: ), pour le fichier ext3 tu pourrais peut-être lui faire une vérification.
Pour ce qui est de ta carte graphique, c’est quoi ?
En résumé ça fais combien de temps que t’a installé et utilisé ta Debian :083
On va dire que c’ est Debian 6.0 donc apt-get install nvidia-kernel-dkms puis apt-get install nvidia-xconfig puis nvidia-xconfig en root pour le total
ps: en fin de compte rien à ajouter :083
bonjour
je vous tiens au courant
j’ai changé le nom du topic (facile)
j’ai fait un truc du genre e2fsck sur ma partition ext3 (bien)
j’ai tenté de fameux : dpkg-reconfigure locales qui n’a eu d’effet que de me passer les menus de l’interface graphique en anglais ou d’empecher l’affichage des menus mais pas du fond d’ecran sans jamais enlever les warnings du kern.log
voila voili
merci pour vos encouragements
En anglais il faut simplement changer les charset pas tous.
Pour ta carte graphique d’avant c’était quoi ?
bonjour
merci pour les réponses
la carte graphique d’avant : je crois que je n’ai jamais regardé
Détectée et acceptée sans chercher par mes installations linux je n’ai jamais cherché a savoir.
maintenant la carte qui fait defaut c’est :
innovision TNT2 M64 W/32MB qui sort en NV18 avec hardinfo
en plus d’avoir des freezes je perds aussi la carte réseau ? ? ? mais le symptome me parait tellement dingue que j’ai du mal à l’imputer au changement de carte graphique
bonjour
un petit message pour vous remercier et pour vous dire que je me suis dégonflé !!
:laughing: :laughing:
les réinstallations et les bidouillages dans le systeme ne conduisait à rien et je n’aurais trouvé sans doute que plus tard mais j’ai perdu patience
je me suis donc fait un dual boot XP/Vista !!
Bon j’en avais besoin
Mais ca freeze plus !!
merci pour le coup de main
