[quote=“laguespa”]
Est-ce que cela signifie que le dernier fsck a été exécuté aujourd’hui à 14h38 ? [/quote]
Oui, en principe au démarrage (recouper $ last , $ uptime …)
fsck -C -R -A -a
-C comme completion : barre affichée
-C [ fd ]
Display completion/progress bars for those filesystem checkers (currently only for ext2
and ext3) which support them. Fsck will manage the filesystem checkers so that only
one of them will display a progress bar at a time. GUI front-ends may specify a file
descriptor fd, in which case the progress bar information will be sent to that file
descriptor.
-R comme Root : exclure le montage de la racine malgré -A
-R When checking all filesystems with the -A flag, skip the root filesystem. (This is
useful in case the root filesystem has already been mounted read-write.)
-A comme All
[code] -A Walk through the /etc/fstab file and try to check all filesystems in one run. This
option is typically used from the /etc/rc system initialization file, instead of multi‐
ple commands for checking a single filesystem.
The root filesystem will be checked first ...[/code]
-a comme automatique : réparation sans confirmation
-a Automatically repair the filesystem without any questions (use this option with cau‐
tion). Note that e2fsck(8) supports -a for backward compatibility only. This option
is mapped to e2fsck's -p option which is safe to use, unlike the -a option that some
filesystem checkers support.
-1
Il semblerait que e2fsprogs soit la cause du max count à -1.
forums.debian.net/viewtopic.php? … 22#p508686
e2fsprogs.sourceforge.net/e2fsprogs-release.html
[quote]
E2fsprogs 1.42 (November 29, 2011)[/quote]
2011 ? …Vive le progrès !
