voici le resultat de :
ll /dev/disk/by-uuid
[quote]lrwxrwxrwx 1 root root 10 janv. 22 19:59 05f73161-37f8-421c-8baa-464a18c841cb -> …/…/hda3
lrwxrwxrwx 1 root root 10 janv. 22 19:59 20254cfa-eb65-4920-ab45-bf249bb1a7dd -> …/…/sda1
lrwxrwxrwx 1 root root 10 janv. 22 19:59 32e3621a-26de-4972-b07a-b574e309d2da -> …/…/hda1
lrwxrwxrwx 1 root root 10 janv. 22 19:59 836b8e7b-c01d-46de-be73-d9da342f1510 -> …/…/sda2
blkid
[quote]/dev/hda1: UUID=“32e3621a-26de-4972-b07a-b574e309d2da” TYPE=“ext3”
/dev/hda3: UUID=“05f73161-37f8-421c-8baa-464a18c841cb” SEC_TYPE=“ext2” TYPE=“ext3”
/dev/sda1: UUID=“20254cfa-eb65-4920-ab45-bf249bb1a7dd” TYPE=“ext3”
/dev/sda2: UUID=“836b8e7b-c01d-46de-be73-d9da342f1510” TYPE=“ext3”
fstab
[quote]proc /proc proc defaults 0 0
/ was on /dev/hda1 during installation
UUID=32e3621a-26de-4972-b07a-b574e309d2da / ext3 errors=remount-ro 0 1
/home was on /dev/hda3 during installation
UUID=05f73161-37f8-421c-8baa-464a18c841cb /home ext3 defaults 0 2
swap was on /dev/hda2 during installation
UUID=22e7e47a-8169-4e41-bf54-efe436f7bafb none swap sw 0 0
/dev/hdc /media/cdrom0 udf,iso9660 user,noauto 0 0
/dev/fd0 /media/floppy0 auto rw,user,noauto 0 0
UUID=20254cfa-eb65-4920-ab45-bf249bb1a7dd /media/Videos ext3 nouser,defaults,errors=remount-ro,atime,auto,rw,dev,exec,suid 0 1
UUID=836b8e7b-c01d-46de-be73-d9da342f1510 /media/Applis ext3 nouser,defaults,errors=remount-ro,atime,auto,rw,dev,exec,suid 0 1
none /cgroup cgroup rw 0 0
et enfin remplacement des UUID du disque externe par /dev/sda1 (2)
et j’ai le même problème :
/var/log/fsck/checkfs
[quote]Log of fsck -C -R -A -a
Sat Jan 23 11:57:50 2010
fsck from util-linux-ng 2.16.2
fsck.ext3: No such file or directory while trying to open /dev/sda1
/dev/sda1:
The superblock could not be read or does not describe a correct ext2
filesystem. If the device is valid and it really contains an ext2
filesystem (and not swap or ufs or something else), then the superblock
is corrupt, and you might try running e2fsck with an alternate superblock:
e2fsck -b 8193
fsck.ext3: No such file or directory while trying to open /dev/sda2
/dev/sda2:
e2fsck -b 8193
/dev/hda3: clean, 67251/855120 files, 559904/3417828 blocks (check in 4 mounts)
fsck died with exit status 8
donc cela vient d’un problème de detection de mon DD avant fsck
Si quelqu’un a une idée.
En attendant je vais me pencher sur le module shpchp
