J’ai installer debian hier et j’ai installé gcc mais lorsque je tape gcc fichier.c cela me marque “gcc bash command not found” je réinstalle donc gcc et là même résultats. Dans ma signature il y a ma config et voici le résultats des commandes demandés dans avant de poster :
$ lspci
00:00.0 Host bridge: VIA Technologies, Inc. VT8363/8365 [KT133/KM133] (rev 80)
00:01.0 PCI bridge: VIA Technologies, Inc. VT8363/8365 [KT133/KM133 AGP]
00:08.0 CardBus bridge: O2 Micro, Inc. OZ601/6912/711E0 CardBus/SmartCardBus Controller
00:11.0 ISA bridge: VIA Technologies, Inc. VT8231 [PCI-to-ISA Bridge] (rev 10)
00:11.1 IDE interface: VIA Technologies, Inc. VT82C586A/B/VT82C686/A/B/VT823x/A/C PIPC Bus Master IDE (rev 06)
00:11.2 USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev 1e)
00:11.3 USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev 1e)
00:11.4 Bridge: VIA Technologies, Inc. VT8235 ACPI (rev 10)
00:11.5 Multimedia audio controller: VIA Technologies, Inc. VT82C686 AC97 Audio Controller (rev 40)
00:11.6 Communication controller: VIA Technologies, Inc. AC’97 Modem Controller (rev 20)
00:12.0 Ethernet controller: VIA Technologies, Inc. VT6102 [Rhine-II] (rev 51)
01:00.0 VGA compatible controller: S3 Inc. VT8636A [ProSavage KN133] AGP4X VGA Controller (TwisterK) (rev 01)
$ lsusb
Bus 002 Device 009: ID 13fe:1f00 Kingston Technology Company Inc. DataTraveler 2.0 4GB Flash Drive
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 002: ID 062a:0000 Creative Labs Optical mouse
Bus 001 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
dmidecode 2.9
SMBIOS 2.3 present.
56 structures occupying 1879 bytes.
Table at 0x000D8010.
Handle 0x0000, DMI type 0, 20 bytes
BIOS Information
Vendor: Phoenix Technologies LTD
Version: 6.00
Release Date: 04/27/2002
Address: 0xE4E00
Runtime Size: 111104 bytes
ROM Size: 512 kB
Characteristics:
ISA is supported
PCI is supported
PC Card (PCMCIA) is supported
PNP is supported
APM is supported
BIOS is upgradeable
BIOS shadowing is allowed
ESCD support is available
USB legacy is supported
Smart battery is supported
BIOS boot specification is supported
Handle 0x0001, DMI type 1, 25 bytes
System Information
Manufacturer: Samsung Electronics Corporation
Product Name: SENSA10
Version: 04HE
Serial Number: A5229BAT400511
UUID: 40DA1555-E01D-B211-8000-FC7A82E359F6
Wake-up Type: Power Switch
Handle 0x0002, DMI type 2, 8 bytes
Base Board Information
Version: 04HE
Serial Number: None
Handle 0x0003, DMI type 3, 17 bytes
Chassis Information
Type: Notebook
Lock: Not Present
Version: N/A
Serial Number: None
Asset Tag: No Asset Tag
Boot-up State: Safe
Power Supply State: Safe
Thermal State: Safe
Security Status: None
OEM Information: 0x00001234
Handle 0x0004, DMI type 4, 35 bytes
Processor Information
Socket Designation: Socket462
Type: Central Processor
Family: Duron
Manufacturer: AuthenticAMD
ID: 71 06 00 00 FF F9 83 03
Signature: Family 6, Model 7, Stepping 1
Flags:
FPU (Floating-point unit on-chip)
VME (Virtual mode extension)
DE (Debugging extension)
PSE (Page size extension)
TSC (Time stamp counter)
MSR (Model specific registers)
PAE (Physical address extension)
MCE (Machine check exception)
CX8 (CMPXCHG8 instruction supported)
SEP (Fast system call)
MTRR (Memory type range registers)
PGE (Page global enable)
MCA (Machine check architecture)
CMOV (Conditional move instruction supported)
PAT (Page attribute table)
PSE-36 (36-bit page size extension)
MMX (MMX technology supported)
FXSR (Fast floating-point save and restore)
SSE (Streaming SIMD extensions)
Version: AMD Duron™
Voltage: 3.3 V
External Clock: Unknown
Max Speed: 1333 MHz
Current Speed: 1100 MHz
Status: Populated, Enabled
Upgrade: ZIF Socket
L1 Cache Handle: 0x0008
L2 Cache Handle: 0x0009
L3 Cache Handle: Not Provided
Serial Number: Not Specified
Asset Tag: Not Specified
Part Number: Not Specified
Handle 0x0005, DMI type 5, 22 bytes
Memory Controller Information
Error Detecting Method: 64-bit ECC
Error Correcting Capabilities:
Other
Supported Interleave: Two-way Interleave
Current Interleave: Two-way Interleave
Maximum Memory Module Size: 512 MB
Maximum Total Memory Size: 1536 MB
Supported Speeds:
70 ns
60 ns
Supported Memory Types:
FPM
EDO
ECC
DIMM
Memory Module Voltage: 3.3 V
Associated Memory Slots: 3
0x0001
0x0002
0x0003
Enabled Error Correcting Capabilities:
None
Handle 0x0006, DMI type 6, 12 bytes
Memory Module Information
Socket Designation: DIM 1
Bank Connections: 0 1
Current Speed: 60 ns
Type: DIMM SDRAM
Installed Size: 256 MB (Double-bank Connection)
Enabled Size: 256 MB (Double-bank Connection)
Error Status: OK
Handle 0x0007, DMI type 6, 12 bytes
Socket Designation: DIM 2
Bank Connections: 2 3
Type: DIMM SDRAM
Installed Size: Not Installed
Enabled Size: Not Installed
Error Status: OK
Handle 0x0008, DMI type 7, 19 bytes
Cache Information
Socket Designation: L1 Cache
Configuration: Enabled, Socketed, Level 1
Operational Mode: Write Back
Installed Size: 16 KB
Maximum Size: 16 KB
Supported SRAM Types:
Burst
Pipeline Burst
Asynchronous
Installed SRAM Type: Asynchronous
Speed: Unknown
Error Correction Type: Unknown
System Type: Unknown
Associativity: Unknown
Handle 0x0009, DMI type 7, 19 bytes
Cache Information
Socket Designation: L2 Cache
Configuration: Enabled, Socketed, Level 2
Operational Mode: Write Through
Installed Size: 64 KB
Maximum Size: 512 KB
Burst
Pipeline Burst
Synchronous
Installed SRAM Type: Synchronous
Speed: Unknown
Handle 0x000A, DMI type 8, 9 bytes
Port Connector Information
Internal Reference Designator: Primary IDE
Internal Connector Type: On Board IDE
External Reference Designator: Not Specified
External Connector Type: None
Port Type: Other
Handle 0x000B, DMI type 8, 9 bytes
Internal Reference Designator: Secondary IDE
Port Type: Other
Handle 0x000C, DMI type 8, 9 bytes
Internal Reference Designator: FLOPPY
Internal Connector Type: On Board Floppy
Port Type: Other
Handle 0x000D, DMI type 8, 9 bytes
Internal Reference Designator: Not Specified
Internal Connector Type: None
External Reference Designator: COM1
External Connector Type: DB-9 male
Port Type: Serial Port XT/AT Compatible
Handle 0x000E, DMI type 8, 9 bytes
External Reference Designator: COM2
Handle 0x000F, DMI type 8, 9 bytes
External Reference Designator: IR
External Connector Type: Infrared
Port Type: Other
Handle 0x0010, DMI type 8, 9 bytes
External Reference Designator: Printer
External Connector Type: DB-25 female
Port Type: Parallel Port ECP/EPP
Handle 0x0011, DMI type 8, 9 bytes
External Reference Designator: KBD
External Connector Type: PS/2
Port Type: Keyboard Port
Handle 0x0012, DMI type 8, 9 bytes
External Reference Designator: Mouse
Port Type: Mouse Port
Handle 0x0013, DMI type 8, 9 bytes
Internal Reference Designator: CD_IN
Internal Connector Type: On Board Sound Input From CD-ROM
Port Type: Other
Handle 0x0014, DMI type 8, 9 bytes
External Reference Designator: Game Port
External Connector Type: DB-15 female
Port Type: Joystick Port
Handle 0x0015, DMI type 8, 9 bytes
External Reference Designator: MIC_IN
External Connector Type: RJ-11
Port Type: MIDI Port
Handle 0x0016, DMI type 8, 9 bytes
External Reference Designator: LINE_IN
Handle 0x0017, DMI type 8, 9 bytes
External Reference Designator: LINE_OUT
Handle 0x0018, DMI type 8, 9 bytes
Internal Reference Designator: FC
Internal Connector Type: Other
Handle 0x0019, DMI type 8, 9 bytes
Internal Reference Designator: USB1
Port Type: USB
Handle 0x001A, DMI type 8, 9 bytes
Internal Reference Designator: USB2
Port Type: USB
Handle 0x001B, DMI type 9, 13 bytes
System Slot Information
Designation: PCI Slot 1
Type: 32-bit PCI
Current Usage: Unknown
Length: Long
Characteristics:
5.0 V is provided
PME signal is supported
Handle 0x001C, DMI type 9, 13 bytes
Designation: PCI Slot 2
Type: 32-bit PCI
Length: Long
Characteristics:
5.0 V is provided
Handle 0x001D, DMI type 9, 13 bytes
Designation: PCI Slot 3
Type: 32-bit PCI
Length: Long
Characteristics:
5.0 V is provided
Handle 0x001E, DMI type 10, 6 bytes
On Board Device Information
Type: Sound
Status: Disabled
Description: VIA 8231 Sound
Handle 0x001F, DMI type 11, 5 bytes
OEM Strings
String 1: AAB
String 2: 2002/09
Handle 0x0020, DMI type 12, 5 bytes
System Configuration Options
Option 1: Intel CPU Voltage
Option 2: CPU TYPE VR1 VR2 Vcore VIO
Option 3: P54C VRE 9-10 5-6,7-8 3.4-3.6V 3.4-3.6V
Option 4: P54C STD 7-8 5-6,7-8 3.3V 3.3V
Option 5: P55C MMX 3-4 1-2,3-4 2.8V 3.4V
Option 6:
Option 7: CPU Clock Rate
Option 8: FRACTION FREQ1 FREQ2
Option 9: 1.5x 1-2 1-2
Option 10: 2x 2-3 1-2
Option 11: 2.5x 2-3 2-3
Option 12: 3x 1-2 2-3
Option 13:
Option 14: Bus FREQ Clk1 Clk2 Clk3
Option 15: 50MHz 2-3 2-3 2-3
Option 16: 60MHz 1-2 2-3 2-3
Option 17: 66MHz 2-3 1-2 2-3
Handle 0x0021, DMI type 16, 15 bytes
Physical Memory Array
Use: System Memory
Error Correction Type: None
Maximum Capacity: 1536 MB
Error Information Handle: Not Provided
Number Of Devices: 3
Handle 0x0022, DMI type 17, 27 bytes
Memory Device
Array Handle: 0x0021
Error Information Handle: No Error
Total Width: 72 bits
Data Width: 64 bits
Form Factor: DIMM
Set: 1
Locator: M1
Bank Locator: Bank 0
Type: DRAM
Type Detail: Synchronous
Speed: Unknown
Manufacturer: Not Specified
Handle 0x0023, DMI type 17, 27 bytes
Memory Device
Total Width: Unknown
Data Width: Unknown
Size: No Module Installed
Form Factor: DIMM
Set: 1
Locator: M2
Bank Locator: Bank 1
Type: DRAM
Speed: Unknown
Handle 0x0024, DMI type 19, 15 bytes
Memory Array Mapped Address
Starting Address: 0x00000000000
Ending Address: 0x0000FFFFFFF
Range Size: 256 MB
Physical Array Handle: 0x0021
Partition Width: 0
Handle 0x0025, DMI type 20, 19 bytes
Memory Device Mapped Address
Range Size: 256 MB
Physical Device Handle: 0x0022
Memory Array Mapped Address Handle: 0x0001
Partition Row Position: 1
Handle 0x0026, DMI type 23, 13 bytes
System Reset
Status: Enabled
Watchdog Timer: Present
Boot Option: Do Not Reboot
Boot Option On Limit: Do Not Reboot
Reset Count: Unknown
Reset Limit: Unknown
Timer Interval: Unknown
Timeout: Unknown
Handle 0x0027, DMI type 24, 5 bytes
Hardware Security
Power-On Password Status: Enabled
Keyboard Password Status: Unknown
Administrator Password Status: Not Implemented
Front Panel Reset Status: Unknown
Handle 0x0028, DMI type 25, 9 bytes
System Power Controls
Next Scheduled Power-on: 12-31 23:59:59
Handle 0x0029, DMI type 26, 20 bytes
Voltage Probe
Description: Voltage Probe
Status: OK
Maximum Value: Unknown
Minimum Value: Unknown
Resolution: Unknown
Tolerance: Unknown
Accuracy: Unknown
OEM-specific Information: 0x00000000
Handle 0x002A, DMI type 27, 12 bytes
Cooling Device
Temperature Probe Handle: 0x002B
Type: Fan
Status: OK
Handle 0x002B, DMI type 28, 20 bytes
Temperature Probe
Description: Temperature Probe
Status: OK
Minimum Value Unknown
Resolution: Unknown
Tolerance: Unknown
Accuracy: Unknown
Handle 0x002C, DMI type 29, 20 bytes
Electrical Current Probe
Description: Electrical Current Probe
Status: OK
Resolution: Unknown
Tolerance: Unknown
Accuracy: Unknown
Handle 0x002D, DMI type 30, 6 bytes
Out-of-band Remote Access
Manufacturer Name: Intel
Inbound Connection: Enabled
Outbound Connection: Disabled
Handle 0x002E, DMI type 32, 20 bytes
System Boot Information
Status:
Handle 0x002F, DMI type 33, 31 bytes
64-bit Memory Error Information
Type: OK
Granularity: Unknown
Operation: Unknown
Vendor Syndrome: Unknown
Memory Array Address: 0x0000000080000000
Device Address: 0x0000000080000000
Resolution: Unknown
Handle 0x0030, DMI type 34, 11 bytes
Management Device
Description: Management Device 1
Type: LM80
Address: 0x12345678
Address Type: Memory
Handle 0x0031, DMI type 34, 11 bytes
Management Device
Description: Management Device 2
Type: LM81
Address: 0x11112222
Address Type: SMBus
Handle 0x0032, DMI type 35, 11 bytes
Management Device Component
Description: Management Device Component 1
Management Device Handle: 0x0030
Component Handle: 0x0029
Threshold Handle: 0x0034
Handle 0x0033, DMI type 35, 11 bytes
Description: Management Device Component 2
Management Device Handle: 0x0031
Component Handle: 0xFFFF
Threshold Handle: 0x0035
Handle 0x0034, DMI type 36, 16 bytes
Management Device Threshold Data
Lower Non-critical Threshold: 1000
Upper Non-critical Threshold: 1000
Lower Critical Threshold: 1000
Upper Critical Threshold: 1000
Lower Non-recoverable Threshold: 1000
Upper Non-recoverable Threshold: 1000
Handle 0x0035, DMI type 36, 16 bytes
Handle 0x0036, DMI type 126, 4 bytes
Inactive
Handle 0x0037, DMI type 127, 4 bytes
End Of Table
Merci par avance
