Gdm et mise en veille de l'écran
Je viens d’installer une debian etch et j’ai un petit soucis.
En effet, l’écran ne s’éteint jamais. C’est pas très écolo…
Pourtant, j’ai à priori configuré mon xorg.conf correctement :
Section "Files"
        FontPath        "/usr/share/fonts/X11/misc"
        FontPath        "/usr/X11R6/lib/X11/fonts/misc"
        FontPath        "/usr/share/fonts/X11/cyrillic"
        FontPath        "/usr/X11R6/lib/X11/fonts/cyrillic"
        FontPath        "/usr/share/fonts/X11/100dpi/:unscaled"
        FontPath        "/usr/X11R6/lib/X11/fonts/100dpi/:unscaled"
        FontPath        "/usr/share/fonts/X11/75dpi/:unscaled"
        FontPath        "/usr/X11R6/lib/X11/fonts/75dpi/:unscaled"
        FontPath        "/usr/share/fonts/X11/Type1"
        FontPath        "/usr/X11R6/lib/X11/fonts/Type1"
        FontPath        "/usr/share/fonts/X11/100dpi"
        FontPath        "/usr/X11R6/lib/X11/fonts/100dpi"
        FontPath        "/usr/share/fonts/X11/75dpi"
        FontPath        "/usr/X11R6/lib/X11/fonts/75dpi"
        # path to defoma fonts
        FontPath        "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType"
EndSection
Section "Module"
        Load    "i2c"
        Load    "bitmap"
        Load    "ddc"
        Load    "dri"
        Load    "extmod"
        Load    "freetype"
        Load    "glx"
        Load    "int10"
        Load    "vbe"
EndSection
Section "InputDevice"
        Identifier      "Generic Keyboard"
        Driver          "kbd"
        Option          "CoreKeyboard"
        Option          "XkbRules"      "xorg"
        Option          "XkbModel"      "pc105"
        Option          "XkbLayout"     "fr"
        Option          "XkbVariant"    "latin9"
EndSection
        Identifier      "Configured Mouse"
        Driver          "mouse"
        Option          "CorePointer"
        Option          "Device"                "/dev/input/mice"
        Option          "Protocol"              "ImPS/2"
        Option          "Emulate3Buttons"       "true"
EndSection
Section "Device"
        Identifier      "Generic-video-card"
        Driver          "vesa"
EndSection
Section "Monitor"
        Identifier      "Sony-SDM-S51"
        HorizSync       28-60
        VertRefresh     48-75
        Option          "DPMS" "On"
EndSection
Section "ServerFlags"
        Option          "BlankTime"   "10"
        Option          "StandbyTime" "20"
        Option          "SuspendTime" "30"
        Option          "OffTime"     "40"
EndSection
Section "Screen"
        Identifier      "Default Screen"
        Device          "Generic-video-card"
        Monitor         "Sony-SDM-S51"
        DefaultDepth    16
        SubSection "Display"
                Depth           1
                Modes           "1024x768" "800x600" "640x480"
        EndSubSection
                Depth           4
        EndSubSection
                Depth           8
        EndSubSection
                Depth           15
        EndSubSection
                Depth           16
        EndSubSection
                Depth           24
        EndSubSection
EndSection
Section "ServerLayout"
        Identifier      "Default Layout"
        Screen          "Default Screen"
        InputDevice     "Generic Keyboard"
        InputDevice     "Configured Mouse"
        InputDevice     "Generic Mouse"
EndSection
Section "DRI"
        Mode    0666
EndSection
La commande xset q retourne
Standby: 0 Suspend: 0 Off: 0 DPMS is enabled Monitor is On
J’ai donc l’impression que xset prend le pas sur xorg.
Or cette machine est destinée à plusieurs utilisateurs, il faudrait donc que j’ai une configuration “standard” pour tous.
De plus, il serait chouette que l’écran s’éteigne aussi lors qu’on est sur la bannière de login (j’utilise gdm, au fait).
Savez vous comment je pourrais économiser de l’énergie :wink: ?
tu as essayé de mettre tes options dans le serverlayout ?
tien c’est marrant moi c’est le contraire sa s’etin tout le temps quand je veux que sa reste allumer. j’ai tout fois trouve que le screensaver jouai un role, je l’ai supprimer mai s an’a rien fait, donc je suppose que c’est aux niveaux de la consol (tty) que sa ce règle mai j’ai pas trouver de piste pour le moment.
pour régler la mise en veille de ton écran tu dois pouvoir passer par xscreensaver non ? (ou je suis en train de dire une énormité ?)
Merci beaucoup de vos réponses :smiley:
C’est fait.
Section "ServerLayout" Identifier "Default Layout" Screen "Default Screen" InputDevice "Generic Keyboard" InputDevice "Configured Mouse" InputDevice "Generic Mouse" Option "BlankTime" "1" Option "StandbyTime" "2" Option "SuspendTime" "3" Option "OffTime" "4" EndSection
Hélas, ça ne change rien. Pas de mise en veille.
Je vais chercher de ce côté.
xscreensaver et gnome-screensaver sont installés. Ils gèrent l’économiseur d’écran une fois l’utilisateur connecté, mais en revanche sur l’écran de connexion pas de mise en veille.
oui c’est vrai je suis bete …
Meuh non voyons :wink:
Ce qui est bizarre, c’est qu’avec la sarge, je ne m’étais même pas posé la question, vu que par défaut gdm éteignait l’écran au bout de quelques minutes. Du coup je me demande si je n’ai pas oublié un paquet…
Bah si un peu qd meme ^^
Et je suppose que le menu de conf auquel tu as acces depuis la page de login ne t’aide pas (me souviens plus de son contenu exact). Sinon pour le paquet d’un côté ca serait étonnant en même temps y’a des chances … je jetterais un oeil a google en rentrant a la maison ce soir.
