Je suis sous debian etch.
Noyau: 2.6.18-4-686
Chip graphique: 00:05.0 VGA compatible controller: nVidia Corporation MCP51 PCI-X GeForce Go 6100 (rev a2)
J’essaie de faire fonctionner la sortie TV en twinview (avec adaptateur S-video -> composite), en vain.
Mon xorg.conf et une partie du log en diront plus:
[code]# Dernière modif : 29 août 2007, 18:31:03
Section "Files"
FontPath "/usr/share/fonts/X11/misc"
FontPath "/usr/share/fonts/X11/100dpi/:unscaled"
FontPath "/usr/share/fonts/X11/Type1"
FontPath “/usr/share/fonts/X11/100dpi”
# path to defoma fonts
FontPath "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType"
EndSection
Section "Module"
Load "bitmap"
Load "ddc"
Load "dri"
Load "extmod"
Load "freetype"
Load "glx"
Load "int10"
Load "vbe"
EndSection
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "kbd"
Option "CoreKeyboard"
Option “XkbRules” "xorg"
Option “XkbModel” "pc105"
Option “XkbLayout” "fr"
Option “XkbVariant” "latin9"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
Option "CorePointer"
Option “Device” "/dev/input/mice"
Option “Protocol” "ImPS/2"
EndSection
Section "Device"
Identifier "nVidia Corporation MCP51 PCI-X GeForce Go 6100"
Driver "nvidia"
BusID "PCI:0:5:0"
Option “ConnectedMonitor” "DFP-0"
Option "TwinView"
Option “TVStandard” "PAL-N"
Option “MetaModes” "1280x800, 1024x768; 800x600, 800x600; 640x480, 640x480;"
EndSection
Section "Monitor"
Identifier "Generic Monitor"
Option "DPMS"
HorizSync 28-51
VertRefresh 43-60
EndSection
Section "Monitor"
Identifier "TV"
Option "DPMS"
HorizSync 30-50
VertRefresh 60
EndSection
Section "Screen"
Identifier "Default Screen"
Device "nVidia Corporation MCP51 PCI-X GeForce Go 6100"
Monitor "Generic Monitor"
DefaultDepth 24
SubSection "Display"
Depth 24
Modes “1280x800” “1024x768” “800x600” "640x480"
EndSubSection
EndSection
Section "ServerLayout"
Identifier "Default Layout"
Screen "Default Screen"
InputDevice "Generic Keyboard"
InputDevice "Configured Mouse"
EndSection
Section "DRI"
Mode 0666
EndSection[/code]
code NVIDIA(0): TwinView requested, but only 1 display devices found.
(II) NVIDIA(0): Assigned Display Device: DFP-0
(WW) NVIDIA(0): Invalid display device in Mode Description “1024x768”
(WW) NVIDIA(0): Not using mode description “1024x768”; unable to map to
(WW) NVIDIA(0): display device
(WW) NVIDIA(0): Invalid display device in Mode Description “800x600”
(WW) NVIDIA(0): Not using mode description “800x600”; unable to map to display
(WW) NVIDIA(0): device
(WW) NVIDIA(0): Invalid display device in Mode Description “640x480”
(WW) NVIDIA(0): Not using mode description “640x480”; unable to map to display
La TV est pourtant bien reliée (fonctionne quand X n’est pas lancé).
Avez-vous des idées quant à l’origine du problème ?
Par avance, merci.
