--> cat /tmp/trace execve("/usr/bin/glxinfo", ["glxinfo"], [/* 29 vars */]) = 0 brk(0) = 0x8e57000 access("/etc/ld.so.nohwcap", F_OK) = -1 ENOENT (No such file or directory) mmap2(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xb7f95000 access("/etc/ld.so.preload", R_OK) = -1 ENOENT (No such file or directory) open("/etc/ld.so.cache", O_RDONLY) = 3 fstat64(3, {st_mode=S_IFREG|0644, st_size=77560, ...}) = 0 mmap2(NULL, 77560, PROT_READ, MAP_PRIVATE, 3, 0) = 0xb7f82000 close(3) = 0 access("/etc/ld.so.nohwcap", F_OK) = -1 ENOENT (No such file or directory) open("/usr/lib/libGL.so.1", O_RDONLY) = 3 read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\3003\2\0004\0\0\0D"..., 512) = 512 fstat64(3, {st_mode=S_IFREG|0644, st_size=483332, ...}) = 0 mmap2(NULL, 503216, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0xb7f07000 mmap2(0xb7f7c000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x74) = 0xb7f7c000 mmap2(0xb7f7e000, 15792, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0xb7f7e000 close(3) = 0 access("/etc/ld.so.nohwcap", F_OK) = -1 ENOENT (No such file or directory) open("/lib/i686/cmov/libc.so.6", O_RDONLY) = 3 read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\260e\1\0004\0\0\0\4"..., 512) = 512 fstat64(3, {st_mode=S_IFREG|0755, st_size=1413540, ...}) = 0 mmap2(NULL, 1418864, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0xb7dac000 mmap2(0xb7f01000, 12288, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x155) = 0xb7f01000 mmap2(0xb7f04000, 9840, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0xb7f04000 close(3) = 0 access("/etc/ld.so.nohwcap", F_OK) = -1 ENOENT (No such file or directory) open("/usr/lib/libX11.so.6", O_RDONLY) = 3 read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\0e\1\0004\0\0\0\234"..., 512) = 512 fstat64(3, {st_mode=S_IFREG|0644, st_size=974508, ...}) = 0 mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xb7dab000 mmap2(NULL, 978580, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0xb7cbc000 mmap2(0xb7da7000, 16384, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xea) = 0xb7da7000 close(3) = 0 access("/etc/ld.so.nohwcap", F_OK) = -1 ENOENT (No such file or directory) open("/lib/i686/cmov/libpthread.so.0", O_RDONLY) = 3 read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0000H\0\0004\0\0\0\330"..., 512) = 512 fstat64(3, {st_mode=S_IFREG|0755, st_size=116414, ...}) = 0 mmap2(NULL, 98784, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0xb7ca3000 mmap2(0xb7cb8000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x14) = 0xb7cb8000 mmap2(0xb7cba000, 4576, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0xb7cba000 close(3) = 0 access("/etc/ld.so.nohwcap", F_OK) = -1 ENOENT (No such file or directory) open("/usr/lib/libXext.so.6", O_RDONLY) = 3 read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0@*\0\0004\0\0\0\f"..., 512) = 512 fstat64(3, {st_mode=S_IFREG|0644, st_size=53788, ...}) = 0 mmap2(NULL, 56956, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0xb7c95000 mmap2(0xb7ca2000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xc) = 0xb7ca2000 close(3) = 0 access("/etc/ld.so.nohwcap", F_OK) = -1 ENOENT (No such file or directory) open("/lib/libgcc_s.so.1", O_RDONLY) = 3 read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\220\34\0\0004\0\0\0\324"..., 512) = 512 fstat64(3, {st_mode=S_IFREG|0644, st_size=49676, ...}) = 0 mmap2(NULL, 52808, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0xb7c88000 mmap2(0xb7c94000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xb) = 0xb7c94000 close(3) = 0 access("/etc/ld.so.nohwcap", F_OK) = -1 ENOENT (No such file or directory) open("/usr/lib/libxcb-xlib.so.0", O_RDONLY) = 3 read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\200\6\0\0004\0\0\0d"..., 512) = 512 fstat64(3, {st_mode=S_IFREG|0644, st_size=4172, ...}) = 0 mmap2(NULL, 7056, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0xb7c86000 mmap2(0xb7c87000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0) = 0xb7c87000 close(3) = 0 access("/etc/ld.so.nohwcap", F_OK) = -1 ENOENT (No such file or directory) open("/usr/lib/libxcb.so.1", O_RDONLY) = 3 read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\340~\0\0004\0\0\0\210"..., 512) = 512 fstat64(3, {st_mode=S_IFREG|0644, st_size=94872, ...}) = 0 mmap2(NULL, 97776, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0xb7c6e000 mmap2(0xb7c85000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x16) = 0xb7c85000 close(3) = 0 access("/etc/ld.so.nohwcap", F_OK) = -1 ENOENT (No such file or directory) open("/lib/i686/cmov/libdl.so.2", O_RDONLY) = 3 read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\n\0\0004\0\0\0H"…, 512) = 512
mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xb7c6d000
fstat64(3, {st_mode=S_IFREG|0644, st_size=9680, …}) = 0
mmap2(NULL, 12412, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0xb7c69000
mmap2(0xb7c6b000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1) = 0xb7c6b000
close(3) = 0
open("/usr/lib/libXau.so.6", O_RDONLY) = 3
read(3, “\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\220\t\0\0004\0\0\0\20”…, 512) = 512
fstat64(3, {st_mode=S_IFREG|0644, st_size=7160, …}) = 0
mmap2(NULL, 10060, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0xb7c66000
mmap2(0xb7c68000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1) = 0xb7c68000
close(3) = 0
open("/usr/lib/libXdmcp.so.6", O_RDONLY) = 3
read(3, “\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\200\17\0\0004\0\0\0\214”…, 512) = 512
fstat64(3, {st_mode=S_IFREG|0644, st_size=16756, …}) = 0
mmap2(NULL, 19644, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0xb7c61000
mmap2(0xb7c65000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x3) = 0xb7c65000
close(3) = 0
mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xb7c60000
set_thread_area({entry_number:-1 -> 6, base_addr:0xb7c60ac0, limit:1048575, seg_32bit:1, contents:0, read_exec_only:0, limit_in_pages:1, seg_not_present:0, useable:1}) = 0
mprotect(0xb7f01000, 4096, PROT_READ) = 0
mprotect(0xb7f07000, 479232, PROT_READ|PROT_WRITE) = 0
mprotect(0xb7f07000, 479232, PROT_READ|PROT_EXEC) = 0
munmap(0xb7f82000, 77560) = 0
set_tid_address(0xb7c60b08) = 15519
set_robust_list(0xb7c60b10, 0xc) = 0
futex(0xbfab2e00, FUTEX_WAKE_PRIVATE, 1) = 0
rt_sigaction(SIGRTMIN, {0xb7ca72e0, [], SA_SIGINFO}, NULL,
= 0
rt_sigaction(SIGRT_1, {0xb7ca7720, [], SA_RESTART|SA_SIGINFO}, NULL,
= 0
rt_sigprocmask(SIG_UNBLOCK, [RTMIN RT_1], NULL,
= 0
getrlimit(RLIMIT_STACK, {rlim_cur=81921024, rlim_max=RLIM_INFINITY}) = 0
uname({sys=“Linux”, node=“Lunaire”, …}) = 0
brk(0) = 0x8e57000
brk(0x8e78000) = 0x8e78000
socket(PF_FILE, SOCK_STREAM, 0) = 3
connect(3, {sa_family=AF_FILE, path="/tmp/.X11-unix/X0"…}, 110) = 0
getpeername(3, {sa_family=AF_FILE, path="/tmp/.X11-unix/X0"…}, [20]) = 0
access("/tmp/.gdm6F40LU", R_OK) = 0
open("/tmp/.gdm6F40LU", O_RDONLY) = 4
fstat64(4, {st_mode=S_IFREG|0600, st_size=118, …}) = 0
mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xb7f94000
read(4, “\1\0\0\7Lunaire\0\0010\0\22MIT-MAGIC-COOKIE-”…, 4096) = 118
read(4, “”…, 4096) = 0
close(4) = 0
munmap(0xb7f94000, 4096) = 0
fcntl64(3, F_GETFL) = 0x2 (flags O_RDWR)
fcntl64(3, F_SETFL, O_RDWR|O_NONBLOCK) = 0
fcntl64(3, F_SETFD, FD_CLOEXEC) = 0
select(4, [3], [3], NULL, NULL) = 1 (out [3])
writev(3, [{“l\0\v\0\0\0\22\0\20\0”…, 10}, {"\0\0"…, 2}, {“MIT-MAGIC-COOKIE-1”…, 18}, {"\0\0"…, 2}, {"/\7\4\244\302Ty\35\1\266\371\367\fn\355["…, 16}, {""…, 0}], 6) = 48
read(3, “\1\0\v\0\0\0\231\0”…,
= 8
read(3, “\320\270\236\0\0\0\0\2\377\377\37\0\0\1\0\0\24\0\377\377\1\7\0\0 \10\3774\342\36\10T”…, 612) = 612
writev(3, [{“7\0\5\0\0\0\0\2i\0\0\0\10\0\0\0\377\377\377\0b\0\5\0\f\0\0\0BIG-R”…, 40}], 1) = 40
select(4, [3], [], NULL, NULL) = 1 (in [3])
read(3, “\1\327\2\0\0\0\0\0\1\202\0\0\1\0\0\0\206J\25\10\\326 \10\224u\337\277\320\315\222\t”…, 4096) = 32
writev(3, [{"\202\0\1\0"…, 4}], 1) = 4
read(3, “\1\343\3\0\0\0\0\0\377\377?\0\1\0\0\0\\326 \10\224u\337\277\320\315\222\t\304”\36\10"…, 4096) = 32
writev(3, [{"\24\0\6\0i\0\0\0\27\0\0\0\37\0\0\0\0\0\0\0\0\341\365\5"…, 24}], 1) = 24
read(3, "\1\10\4\0.\0\0\0\37\0\0\0\0\0\0\0\270\0\0\0\206J\25\10\\326 \10\224u\337\277"…, 4096) = 216
read(3, 0x8e5788c, 4096) = -1 EAGAIN (Resource temporarily unavailable)
writev(3, [{“b\0\5\0\t\0\0\0XKEYBOARD\0\0\0”…, 20}], 1) = 20
read(3, “\1\330\5\0\0\0\0\0\1\225o\260\1\0\0\0\206J\25\10\\326 \10\224u\337\277\320\315\222\t”…, 4096) = 32
writev(3, [{"\225\0\2\0\1\0\0\0"…, 8}], 1) = 8
read(3, “\1\1\6\0\0\0\0\0\1\0\0\0\270u\337\277\313\330\33\10\260\343\330\10\210U\7\tp\351\247\10”…, 4096) = 32
fstat64(1, {st_mode=S_IFCHR|0620, st_rdev=makedev(136, 3), …}) = 0
write(1, “name of display: :0.0\n”…, 22) = 22
writev(3, [{“b\0\3\0\3\0\0\0GLX\0”…, 12}], 1) = 12
read(3, “\1\330\7\0\0\0\0\0\1\217M\232\1\0\0\0\206J\25\10\\326 \10\224u\337\277\320\315\222\t”…, 4096) = 32
writev(3, [{"\217\7\3\0\1\0\0\0\4\0\0\0"…, 12}], 1) = 12
read(3, “\1!\10\0\0\0\0\0\1\0\0\0\2\0\0\0\210U\7\tXu\337\277,\354\277\267\0\0\0\0”…, 4096) = 32
writev(3, [{“b\7\5\0\v\0\0\0XFree86-DRI\0”…, 20}], 1) = 20
read(3, “\1\330\t\0\0\0\0\0\1\221\0\250\1\0\0\0\206J\25\10\\326 \10\224u\337\277\320\315\222\t”…, 4096) = 32
writev(3, [{"\221\0\1\0"…, 4}], 1) = 4
read(3, “\1\0\n\0\0\0\0\0\4\0\1\0\0\0\0\0Tu\337\277\33\0\0\0\350t\337\277\304”\36\10"…, 4096) = 32
writev(3, [{"\221\1\2\0\0\0\0\0"…, 8}], 1) = 8
read(3, “\1t\v\0\0\0\0\0\1u\337\277<\224\344\267\1\0\0\0Tu\337\277\33\0\0\0\350t\337\277”…, 4096) = 32
writev(3, [{"\221\4\2\0\0\0\0\0"…, 8}], 1) = 8
read(3, “\1u\f\0\1\0\0\0\5\0\0\0\3\0\0\0\0\0\0\0\4\0\0\0HJ\25\10$\326 \10r”…, 4096) = 36
futex(0xb7c6c070, FUTEX_WAKE_PRIVATE, 2147483647) = 0
geteuid32() = 1000
getuid32() = 1000
open("/usr/lib/dri/r300_dri.so", O_RDONLY) = 4
read(4, “\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\0\312\1\0004\0\0\0\314”…, 512) = 512
fstat64(4, {st_mode=S_IFREG|0644, st_size=2191068, …}) = 0
mmap2(NULL, 2234736, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 4, 0) = 0xb7a3e000
mmap2(0xb7c41000, 81920, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 4, 0x203) = 0xb7c41000
mmap2(0xb7c55000, 43376, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0xb7c55000
close(4) = 0
open("/etc/ld.so.cache", O_RDONLY) = 4
fstat64(4, {st_mode=S_IFREG|0644, st_size=77560, …}) = 0
mmap2(NULL, 77560, PROT_READ, MAP_PRIVATE, 4, 0) = 0xb7a2b000
close(4) = 0
open("/lib/i686/cmov/libm.so.6", O_RDONLY) = 4
read(4, “\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0@4\0\0004\0\0\0P”…, 512) = 512
fstat64(4, {st_mode=S_IFREG|0644, st_size=149328, …}) = 0
mmap2(NULL, 151680, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 4, 0) = 0xb7a05000
mmap2(0xb7a29000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 4, 0x23) = 0xb7a29000
close(4) = 0
open("/usr/lib/libexpat.so.1", O_RDONLY) = 4
read(4, “\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0000!\0\0004\0\0\0\234”…, 512) = 512
fstat64(4, {st_mode=S_IFREG|0644, st_size=151468, …}) = 0
mmap2(NULL, 154332, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 4, 0) = 0xb79df000
mmap2(0xb7a03000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 4, 0x23) = 0xb7a03000
close(4) = 0
open("/usr/lib/libdrm.so.2", O_RDONLY) = 4
read(4, “\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0` \0\0004\0\0\0\350”…, 512) = 512
fstat64(4, {st_mode=S_IFREG|0644, st_size=27088, …}) = 0
mmap2(NULL, 31272, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 4, 0) = 0xb7f8c000
mmap2(0xb7f93000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 4, 0x6) = 0xb7f93000
close(4) = 0
munmap(0xb7a2b000, 77560) = 0
munmap(0xb7a3e000, 2234736) = 0
munmap(0xb7a05000, 151680) = 0
munmap(0xb79df000, 154332) = 0
munmap(0xb7f8c000, 31272) = 0
writev(3, [{"\217\23\3\0\0\0\0\0\2\0\0\0"…, 12}], 1) = 12
read(3, “\0012\r\0\1\0\0\0\30\36A\t\4\0\0\0\204!\304\267\1\0\0\0\210U\7\tXu\337\2771”…, 4096) = 36
writev(3, [{"\217\23\3\0\0\0\0\0\3\0\0\0"…, 12}], 1) = 12
read(3, “\0012\16\0E\0\0\0\30\36A\t\22\1\0\0\204!\304\267\1\0\0\0\210U\7\tXu\337\277G”…, 4096) = 308
writev(3, [{"\217\21\4\0\4\0\1\0\3\0\0\0\0\0\0\0"…, 16}], 1) = 16
read(3, “\1\0\17\0\270\3\0\0\21\0\0\0\34\0\0\0\30\36A\t8u\337\277\340\22\377\267\250K\331\10\v”…, 4096) = 3840
futex(0xb7f7dbec, FUTEX_WAKE_PRIVATE, 2147483647) = 0
mmap2(NULL, 262144, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xb7c20000
writev(3, [{"\217\24\f\3\1\0\0\0\4\0\0\0\36\f\0\0GL_ARB_depth_text"…, 3224}], 1) = 3224
read(3, “\1\0\24\0\0\0\0\0\1\0\0\0\0 \277\267(\3\5\0\1\0\0\0<9\277\267\204!\304\267”…, 4096) = 32
futex(0xb7f805d4, FUTEX_WAKE_PRIVATE, 2147483647) = 0
writev(3, [{"\217\201\3\0\1\0\0\0\3\37\0\0"…, 12}], 1) = 12
read(3, “\1\0\25\0m\1\0\0\0\0\0\0\261\5\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0G”…, 4096) = 1492
writev(3, [{"\217\201\3\0\1\0\0\0\2\37\0\0"…, 12}], 1) = 12
read(3, “\1\0\26\0\4\0\0\0\0\0\0\0\17\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0001”…, 4096) = 48
writev(3, [{"\217u\3\0\1\0\0\0\342\204\0\0"…, 12}], 1) = 12
read(3, “\1\0\27\0\0\0\0\0\0\0\0\0\1\0\0\0\10\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0”…, 4096) = 32
writev(3, [{"\217\21\5\0\33\5\0\0\1\0\0\0 \206\0\0\255\210\0\0"…, 20}], 1) = 20
read(3, “\1\0\30\0\0\0\0\0\0\0\0\0\1\0\0\0\20\0\0\0\271\271\271\0\0\0\0\0\0\0\0\0”…, 4096) = 32
writev(3, [{"\217\23\3\0\0\0\0\0\1\0\0\0"…, 12}], 1) = 12
read(3, “\0012\31\0\1\0\0\0\30\36A\t\4\0\0\0\204!\304\267\1\0\0\0\210U\7\tXu\337\277S”…, 4096) = 36
writev(3, [{"\217\201\3\0\1\0\0\0\0\37\0\0"…, 12}], 1) = 12
read(3, “\1\0\32\0\5\0\0\0\0\0\0\0\21\0\0\0\20\0\0\0\271\271\271\0\0\0\0\0\0\0\0\0D”…, 4096) = 52
writev(3, [{"\217\201\3\0\1\0\0\0\1\37\0\0"…, 12}], 1) = 12
read(3, “\1\0\33\0\f\0\0\0\0\0\0\0/\0\0\0\20\0\0\0\271\271\271\0\0\0\0\0\0\0\0\0M”…, 4096) = 80
write(1, “display: :0 screen: 0\n”…, 23) = 23
writev(3, [{"\217\6\2\0\3\0\0\2"…, 8}], 1) = 8
read(3, “\0012\34\0\0\0\0\0\0\36A\t\0\20\0\0\204!\304\267\1\0\0\0\210U\7\tXu\337\277”…, 4096) = 32
write(1, “direct rendering: No (If you want”…, 84) = 84
write(1, “server glx vendor string: SGI\n”…, 30) = 30
write(1, “server glx version string: 1.2\n”…, 31) = 31
write(1, “server glx extensions:\n”…, 23) = 23
write(1, " GLX_ARB_multisample, GLX_EXT_"…, 79) = 79
write(1, " GLX_EXT_visual_info, GLX_EXT_"…, 75) = 75
write(1, " GLX_OML_swap_method, GLX_SGI_"…, 75) = 75
write(1, " GLX_SGIS_multisample, GLX_SGI"…, 74) = 74
write(1, “client glx vendor string: SGI\n”…, 30) = 30
write(1, “client glx version string: 1.4\n”…, 31) = 31
write(1, “client glx extensions:\n”…, 23) = 23
write(1, " GLX_ARB_get_proc_address, GLX"…, 76) = 76
write(1, " GLX_MESA_swap_control, GLX_ME"…, 76) = 76
write(1, " GLX_OML_sync_control, GLX_SGI"…, 76) = 76
write(1, " GLX_SGI_video_sync, GLX_SGIS_"…, 66) = 66
write(1, " GLX_SGIX_pbuffer, GLX_SGIX_vi"…, 53) = 53
write(1, " GLX_EXT_texture_from_pixmap\n"…, 32) = 32
write(1, “GLX version: 1.2\n”…, 17) = 17
write(1, “GLX extensions:\n”…, 16) = 16
write(1, " GLX_EXT_visual_info, GLX_EXT_"…, 70) = 70
write(1, " GLX_SGI_make_current_read, GL"…, 76) = 76
write(1, " GLX_SGIX_fbconfig, GLX_SGIX_v"…, 54) = 54
write(1, “OpenGL vendor string: DRI R300 Pr”…, 39) = 39
write(1, “OpenGL renderer string: Mesa DRI “…, 71) = 71
write(1, “OpenGL version string: 1.3 Mesa 7”…, 38) = 38
write(1, “OpenGL extensions:\n”…, 19) = 19
write(1, " GL_ARB_fragment_program, GL_A”…, 66) = 66
write(1, " GL_ARB_multitexture, GL_ARB_t”…, 55) = 55
write(1, " GL_ARB_texture_compression, G"…, 58) = 58
write(1, " GL_ARB_texture_env_add, GL_AR"…, 57) = 57
write(1, " GL_ARB_texture_env_crossbar, “…, 59) = 59
write(1, " GL_ARB_texture_mirrored_repea”…, 63) = 63
write(1, " GL_ARB_transpose_matrix, GL_A"…, 72) = 72
write(1, " GL_EXT_abgr, GL_EXT_bgra, GL_"…, 51) = 51
write(1, " GL_EXT_blend_equation_separat"…, 65) = 65
write(1, " GL_EXT_blend_minmax, GL_EXT_b"…, 74) = 74
write(1, " GL_EXT_copy_texture, GL_EXT_d"…, 80) = 80
write(1, " GL_EXT_packed_pixels, GL_EXT_"…, 73) = 73
write(1, " GL_EXT_secondary_color, GL_EX"…, 61) = 61
write(1, " GL_EXT_stencil_two_side, GL_E"…, 70) = 70
write(1, " GL_EXT_texture, GL_EXT_textur"…, 66) = 66
write(1, " GL_EXT_texture_env_add, GL_EX"…, 57) = 57
write(1, " GL_EXT_texture_env_dot3, GL_E"…, 55) = 55
write(1, " GL_EXT_texture_mirror_clamp, “…, 57) = 57
write(1, " GL_EXT_texture_rectangle, GL_”…, 76) = 76
write(1, " GL_ATI_texture_env_combine3, “…, 62) = 62
write(1, " GL_ATIX_texture_env_combine3,”…, 67) = 67
write(1, " GL_INGR_blend_func_separate, “…, 78) = 78
write(1, " GL_NV_blend_square, GL_NV_lig”…, 76) = 76
write(1, " GL_NV_texture_rectangle, GL_N"…, 73) = 73
write(1, " GL_SGI_color_table, GL_SGIS_g"…, 80) = 80
write(1, " GL_SGIS_texture_edge_clamp, G"…, 78) = 78
write(1, “\n”…, 1) = 1
write(1, " visual x bf lv rg d st color"…, 70) = 70
write(1, " id dep cl sp sz l ci b ro r g"…, 70) = 70
write(1, “---------------------------------”…, 71) = 71
write(1, “0x23 24 tc 0 32 0 r y . 8 8”…, 71) = 71
write(1, “0x24 24 tc 0 32 0 r y . 8 8”…, 71) = 71
write(1, “0x25 24 tc 0 32 0 r y . 8 8”…, 71) = 71
write(1, “0x26 24 tc 0 32 0 r y . 8 8”…, 71) = 71
write(1, “0x27 24 tc 0 32 0 r . . 8 8”…, 71) = 71
write(1, “0x28 24 tc 0 32 0 r . . 8 8”…, 71) = 71
write(1, “0x29 24 tc 0 32 0 r . . 8 8”…, 71) = 71
write(1, “0x2a 24 tc 0 32 0 r . . 8 8”…, 71) = 71
write(1, “0x2b 24 dc 0 32 0 r y . 8 8”…, 71) = 71
write(1, “0x2c 24 dc 0 32 0 r y . 8 8”…, 71) = 71
write(1, “0x2d 24 dc 0 32 0 r y . 8 8”…, 71) = 71
write(1, “0x2e 24 dc 0 32 0 r y . 8 8”…, 71) = 71
write(1, “0x2f 24 dc 0 32 0 r . . 8 8”…, 71) = 71
write(1, “0x30 24 dc 0 32 0 r . . 8 8”…, 71) = 71
write(1, “0x31 24 dc 0 32 0 r . . 8 8”…, 71) = 71
write(1, “0x32 24 dc 0 32 0 r . . 8 8”…, 71) = 71
write(1, “0x67 32 tc 0 32 0 r . . 8 8”…, 71) = 71
writev(3, [{"\217\4\2\0\3\0\0\2\4\4\2\0\2\0\0\2<\4\2\0\0\0\0\2+\4\1\0"…, 28}], 1) = 28
read(3, “\21\30\36\0\2\0\0\2\2\0\0\2 \245\0\t\304”\36\10(\245\0\t\1\0\0\0\233\301\7\10\1"…, 4096) = 64
munmap(0xb7c20000, 262144) = 0
close(3) = 0
— SIGSEGV (Segmentation fault) @ 0 (0) —
+++ killed by SIGSEGV +++
