Bonjour à tous
Je suis en train d’installé debian, mais je n’arrive pas à installer le gnome classic.
Comme sous ubuntu ?
Comment faire ?
Cordialement
salut,
il faut installer le paquet gnome-session-fallback
https://packages.debian.org/jessie/gnome/gnome-session-fallback
sudo apt-get install gnome-session-fallback
ca fait du monde dans un environnement xfce
@debian:~$ sudo apt-get install gnome-session-fallback
[sudo] password for :
accountsservice alacarte apache2-bin apg bluez-obexd bogofilter
bogofilter-bdb bogofilter-common cheese-common cracklib-runtime
dleyna-server evolution evolution-common evolution-data-server
evolution-data-server-common evolution-plugins freepats gir1.2-gconf-2.0
gir1.2-gmenu-3.0 gir1.2-panelapplet-4.0 gkbd-capplet gnome-applets
gnome-applets-data gnome-bluetooth gnome-control-center
gnome-control-center-data gnome-flashback gnome-flashback-common gnome-media
gnome-menus gnome-online-accounts gnome-panel gnome-panel-data
gnome-power-manager gnome-screensaver gnome-session-bin gnome-session-common
gnome-session-flashback gnome-system-monitor gnome-user-share
gstreamer0.10-gconf gstreamer0.10-plugins-good gstreamer0.10-pulseaudio
gstreamer0.10-x gstreamer1.0-clutter gstreamer1.0-plugins-bad
libaccountsservice0 libapache2-mod-dnssd libapr1 libaprutil1
libaprutil1-dbd-sqlite3 libaprutil1-ldap libatkmm-1.6-1
libboost-thread1.55.0 libcairomm-1.0-1 libcamel-1.2-49 libchamplain-0.12-0
libchamplain-gtk-0.12-0 libcheese-gtk23 libcheese7 libcolord-gtk1
libcpufreq0 libcrack2 libdleyna-connector-dbus-1.0-1 libdleyna-core-1.0-3
libebackend-1.2-7 libebook-1.2-14 libebook-contacts-1.2-0 libecal-1.2-16
libedata-book-1.2-20 libedata-cal-1.2-23 libedataserver-1.2-18 libevolution
libfftw3-double3 libfluidsynth1 libgdata-common libgdata19 libgee-0.8-2
libglibmm-2.4-1c2a libgme0 libgmime-2.6-0 libgnome-bluetooth13
libgnome-menu-3-0 libgnomekbd-common libgnomekbd8 libgoa-backend-1.0-1
libgrilo-0.2-1 libgsl0ldbl libgssdp-1.0-3 libgstreamer-plugins-bad1.0-0
libgtkglext1 libgtkhtml-4.0-0 libgtkhtml-4.0-common libgtkhtml-editor-4.0-0
libgtkmm-3.0-1 libgtkspell3-3-0 libgucharmap-2-90-7 libgupnp-1.0-4
libgupnp-av-1.0-2 libgupnp-dlna-2.0-3 libibus-1.0-5 liblua5.1-0
libmetacity-private2 libmimic0 libmjpegutils-2.1-0 libmms0
libmpeg2encpp-2.1-0 libmpg123-0 libmplex2-2.1-0 libnss-myhostname liboauth0
libofa0 libopenal-data libopenal1 libopencv-calib3d2.4 libopencv-contrib2.4
libopencv-core2.4 libopencv-features2d2.4 libopencv-flann2.4
libopencv-highgui2.4 libopencv-imgproc2.4 libopencv-legacy2.4
libopencv-ml2.4 libopencv-objdetect2.4 libopencv-video2.4
libpanel-applet-4-0 libpangomm-1.4-1 libphonenumber6 libprotobuf9 libpst4
libpwquality-common libpwquality1 libquvi-scripts libquvi7
librygel-core-2.4-2 librygel-renderer-2.4-2 librygel-server-2.4-2 libsbc1
libsoundtouch0 libspandsp2 libtbb2 libtelepathy-glib0 libtotem-plparser18
libvo-aacenc0 libvo-amrwbenc0 libwildmidi-config libwildmidi1 libytnef0
libzbar0 mesa-utils metacity metacity-common mousetweaks realmd rygel
xwayland
Paquets suggérés :
apache2-doc apache2-suexec-pristine apache2-suexec-custom db5.3-util
doc-base evolution-ews evolution-plugins-experimental
evolution-data-server-dbg tomboy gstreamer1.0-pulseaudio
libcanberra-gtk-module frei0r-plugins libfftw3-bin libfftw3-dev
grilo-plugins-0.2 gsl-ref-psdoc gsl-doc-pdf gsl-doc-info gsl-ref-html
rygel-mediathek rygel-playbin rygel-preferences rygel-tracker
gnome-session-fallback gnome-session-flashback gnome-system-monitor
gnome-user-share gstreamer0.10-gconf gstreamer0.10-plugins-good
gstreamer0.10-pulseaudio gstreamer0.10-x gstreamer1.0-clutter
gstreamer1.0-plugins-bad libaccountsservice0 libapache2-mod-dnssd libapr1
libaprutil1 libaprutil1-dbd-sqlite3 libaprutil1-ldap libatkmm-1.6-1
xwayland
0 mis à jour, 157 nouvellement installés, 0 à enlever et 0 non mis à jour.
Il est nécessaire de prendre 99,2 Mo dans les archives.
Après cette opération, 300 Mo d'espace disque supplémentaires seront utilisés.
Merci je vais tester cela je l’avais installé via Usb, mais sa me demandé d’inséré le Dvd d’installation.
Du coup je viens de le graver via dvd on va voir
PS : pas de problème une fois installé pour lui mettre virtualbox etc ?
Re,
Donc impeccable j’ai installé le Gnome classic par contre sa ne me plait toujours pas
Je recherche le même style que Red hat version 6
Qu’elle theme c’est sur debian ? C’est bien le gnome classic ?
Ou bien des versions antérieurs de Debian ?
Cordialement
