Ce matin mise à jour
Start-Date: 2026-10-21 07:20:04
Commandline: apt full-upgrade -y -o Dpkg::Options::=–force-confdef -o Dpkg::Options::=–force-confold
Install: gnome-extensions-app:amd64 (51~alpha-3, automatic), gir1.2-mutter-51:amd64 (51.0-3, automatic), gir1.2-gly-2:amd64 (2.2.3+ds-1, automatic), gir1.2-gnomeqr-4.0:amd64 (51.0-1, automatic), libmutter-51-0:amd64 (51.0-3, automatic)
Upgrade: gnome-shell-extension-light-style:amd64 (50.2-2, 51.0-2), gnome-shell-extension-launch-new-instance:amd64 (50.2-2, 51.0-2), python3-setuptools-whl:amd64 (84.0.0-2, 84.2.0-1), gnome-sound-recorder:amd64 (43~beta-5, 43~beta-6), libctf-nobfd0:amd64 (2.47-6, 2.47.50.20261020-1), gnome-shell-extension-workspace-indicator:amd64 (50.2-2, 51.0-2), mutter-common-bin:amd64 (50.5-1, 51.0-3), gir1.2-notify-0.7:amd64 (0.8.8-1+b1, 0.8.9-1), libgweather-4-common:amd64 (4.4.4-5, 4.6.0-1), gir1.2-freedesktop:amd64 (1.86.0-7, 1.86.0-8), libusageenvironment3:amd64 (2026.10.13-1, 2026.10.17-1), gnome-shell-extension-native-window-placement:amd64 (50.2-2, 51.0-2), libgdm1:amd64 (51.0-2, 51.1-1), libbinutils:amd64 (2.47-6, 2.47.50.20261020-1), xdg-desktop-portal-gnome:amd64 (50.0-1, 51.0-2), gnome-shell-extension-auto-move-windows:amd64 (50.2-2, 51.0-2), gnome-shell-extension-window-list:amd64 (50.2-2, 51.0-2), libavdevice63:amd64 (7:9.0.2-3, 7:9.0.2-4), gnome-shell-extension-apps-menu:amd64 (50.2-2, 51.0-2), binutils-x86-64-linux-gnu:amd64 (2.47-6, 2.47.50.20261020-1), ffmpeg:amd64 (7:9.0.2-3, 7:9.0.2-4), libsvtav1enc4:amd64 (4.2.0+dfsg-1, 4.2.0+dfsg-2), libmspack0t64:amd64 (0.11-1.1+b2, 0.11-2), mutter-common:amd64 (50.5-1, 51.0-3), gnome-shell-extensions:amd64 (50.2-2, 51.0-2), gnome-shell:amd64 (50.5-1, 51.0-3), gnome-shell-extension-status-icons:amd64 (50.2-2, 51.0-2), libgroupsock33:amd64 (2026.10.13-1, 2026.10.17-1), gnome-classic:amd64 (50.2-2, 51.0-2), libnotify-bin:amd64 (0.8.8-1+b1, 0.8.9-1), libgirepository-1.0-1:amd64 (1.86.0-7, 1.86.0-8), gdm3:amd64 (51.0-2, 51.1-1), libswscale10:amd64 (7:9.0.2-3, 7:9.0.2-4), libavcodec63:amd64 (7:9.0.2-3, 7:9.0.2-4), libnotify4:amd64 (0.8.8-1+b1, 0.8.9-1), gnome-shell-extension-places-menu:amd64 (50.2-2, 51.0-2), libavfilter12:amd64 (7:9.0.2-3, 7:9.0.2-4), libctf0:amd64 (2.47-6, 2.47.50.20261020-1), libbasicusageenvironment2:amd64 (2026.10.13-1, 2026.10.17-1), python3-pil.imagetk:amd64 (12.3.0-1+b1, 13.0.0-1), libavutil61:amd64 (7:9.0.2-3, 7:9.0.2-4), gnome-shell-extension-screenshot-window-sizer:amd64 (50.2-2, 51.0-2), gnome-shell-common:amd64 (50.5-1, 51.0-3), gir1.2-gdm-1.0:amd64 (51.0-2, 51.1-1), binutils-common:amd64 (2.47-6, 2.47.50.20261020-1), ca-certificates:amd64 (20260816, 20260816+nmu1), python3-pil:amd64 (12.3.0-1+b1, 13.0.0-1), liblivemedia120:amd64 (2026.10.13-1, 2026.10.17-1), gnome-shell-extension-windows-navigator:amd64 (50.2-2, 51.0-2), libsframe3:amd64 (2.47-6, 2.47.50.20261020-1), gnome-shell-extension-drive-menu:amd64 (50.2-2, 51.0-2), libswresample7:amd64 (7:9.0.2-3, 7:9.0.2-4), libgprofng0:amd64 (2.47-6, 2.47.50.20261020-1), gnome-shell-extension-system-monitor:amd64 (50.2-2, 51.0-2), libavformat63:amd64 (7:9.0.2-3, 7:9.0.2-4), ffplay:amd64 (7:9.0.2-3, 7:9.0.2-4), gir1.2-gweather-4.0:amd64 (4.4.4-5, 4.6.0-1), python3-setuptools:amd64 (84.0.0-2, 84.2.0-1), gnome-shell-extensions-common:amd64 (50.2-2, 51.0-2), gnome-shell-extension-prefs:amd64 (50.5-1, 51~alpha-3), xterm:amd64 (411-1, 412-1), gnome-shell-extension-user-theme:amd64 (50.2-2, 51.0-2), libgweather-4-0t64:amd64 (4.4.4-5, 4.6.0-1), binutils:amd64 (2.47-6, 2.47.50.20261020-1), intel-media-va-driver:amd64 (26.2.4+dfsg1-1, 26.3.5+dfsg1-1)
End-Date: 2026-10-21 07:20:38
Start-Date: 2026-10-21 07:20:40
Commandline: apt-get purge --autoremove -y
Purge: python3-autocommand:amd64 (2.2.2-4), libmutter-18-0:amd64 (50.5-1), gir1.2-mutter-18:amd64 (50.5-1)
End-Date: 2026-10-21 07:20:41
Depuis impossible d’ouvrir la session gnome.
Je garde mon sang froid et je commute sur une session terminal avec ctrl+alt+f2 et je me me connecte avec mon user habituel en mode texte.
Après quelques recherche sur Internet via mon smartphone, rien de probant mais ça me donne l’idée d’installer lightdm
La session graphique lightdm apparait bien cette fois mais part en boucle sur la session gnome, refus d’affichage de mon bureau gnome!
j’ai alors l’idée d’installer lxde et là, ouf merci le bureau lxde fonctionne.
Quel est le problème avec gdm et gnome-shell 51?
apt policy gnome-shell
gnome-shell:
Installé : 51.0-3
Candidat : 51.0-3
Table de version :
*** 51.0-3 500
100 /var/lib/dpkg/status
50.5-1 500
500 https://cdn-aws.deb.debian.org/debian forky/main amd64 Packages
48.7-0+deb13u2 500
500 https://cdn-aws.deb.debian.org/debian trixie/main amd64 Packages
43.9-0+deb12u2 500
500 https://cdn-aws.deb.debian.org/debian-security bookworm-security/main amd64 Packages
500 https://cdn-aws.deb.debian.org/debian bookworm/main amd64 Packages
seul message dans le log
systemd[1730]: Failed to start org.gnome.Shell@user.service - GNOME Shell.
ça fait léger comme info
