Hello
Tout est dans le titre ou presque.
Si j’utilise le truc d’installation de google (j’ai rien vu dans le gestionnaire de paquet) sa donne
GoogleEarthLinux.bin'
Verifying archive integrity... All good.
Uncompressing Google Earth for GNU/Linux 4.2.205.5730..............................................................
setup.data/bin/Linux/amd64/setup.gtk2: error while loading shared libraries: libxml2.so.2: cannot open shared object file: No such file or directory
setup.data/bin/Linux/amd64/setup.gtk: error while loading shared libraries: libSM.so.6: cannot open shared object file: No such file or directory
The setup program seems to have failed on amd64
Fatal error, installer failed to run at all!
dpkg -l |grep libxml2
ii libxml-libxml-perl 1.69.ds-1 Perl module for using the GNOME libxml2 library
ii libxml2 2.6.32.dfsg-5 GNOME XML library
ii libxml2-dbg 2.6.32.dfsg-5 Debugging symbols for the GNOME XML library
ii libxml2-dev 2.6.32.dfsg-5 Development files for the GNOME XML library
ii libxml2-utils 2.6.32.dfsg-5 XML utilities
ii python-libxml2 2.6.32.dfsg-5 Python bindings for the GNOME XML library
Il faut que je me tape un chroot 32 ou il y a un moyen de faire autrement ?
Merci d’avance pour mes début en 64bis ![]()
