j’ai monté un raid 5 via mdadm avec succès je pense et quand je vais voir l’interface graphique Gparted, j’ai un beau message d’erreur tune2fs, dumpe2fs, e2 label qui me dit au final que je dois installer e2fsprogs v1.41+
Je m’applique et installe le fichier que l’on me propose, à savoir le 1.42.8 en suivant bien le tuto…
[code]1) Change directory into the top of the e2fsprogs source tree
Create a build directory and cd into it:
mkdir build; cd build
Run the configure script
…/configure
If you wish to turn on ELF shared libraries, add the option
–enable-elf-shlibs. If you wish to build profiling libraries, add
the option --enable-profile.Note that if you are building on an older system (i.e., a 2.4
kernel and/or glibc 2.2), the use of thread local storage will probably
cause programs that use the uuid library to core dump. To disable
thread local storage, use the configure option --disable-tls. -
Compile the programs
make
Check to make sure the installation built correctly:
make check
Install the programs
Run `make install’
Install the include files and libraries
You can run `make install-libs’ to install the include files and
libraries. Please note that this installation is not needed for the
programs to work. It is only needed if you expect to develop other
programs using the libraries or if you want to compile other program
using these libraries (like the 4.4BSD dump and restore port).[/code]
fstab
[code]#
/ was on /dev/sda1 during installation
UUID=d63cd400-ab0e-4969-81d7-bcba64b8664a / ext4 errors=remount-ro 0 1
/home was on /dev/sda9 during installation
UUID=c6267c6f-0190-4003-a46b-04c17e333f47 /home ext4 defaults 0 2
/tmp was on /dev/sda8 during installation
UUID=2c564de2-d74d-41fb-bf27-a479b8fcdd0e /tmp ext4 defaults 0 2
/usr was on /dev/sda5 during installation
UUID=24f76331-0491-46f0-ae7c-a1a3291c60a2 /usr ext4 defaults 0 2
/var was on /dev/sda6 during installation
UUID=a510e8b1-7fdf-4e58-9b8a-36a62c5d275c /var ext4 defaults 0 2
swap was on /dev/sda7 during installation
UUID=6a080d54-38a3-4aac-ba7b-137d0c3f4170 none swap sw 0 0[/code]
Mais quand je retourne dans gparted, j’ai toujours le même message et maintenant, je n’ai même plus mon Raid
Que se passe t’il ?
