Hello,
Voici ce qu’il y’a dans /var/log/Xorg.0.log
[code][ 15.277]
X.Org X Server 1.16.4
Release Date: 2014-12-20
[ 15.278] X Protocol Version 11, Revision 0
[ 15.278] Build Operating System: Linux 3.16.0-4-amd64 x86_64 Debian
[ 15.278] Current Operating System: Linux verax 3.16.0-4-amd64 #1 SMP Debian 3.16.7-ckt9-2 (2015-04-13) x86_64
[ 15.278] Kernel command line: BOOT_IMAGE=/vmlinuz-3.16.0-4-amd64 root=/dev/mapper/verax–vg-root ro quiet
[ 15.278] Build Date: 11 February 2015 12:32:02AM
[ 15.278] xorg-server 2:1.16.4-1 (http://www.debian.org/support)
[ 15.278] Current version of pixman: 0.32.6
[ 15.278] Before reporting problems, check http://wiki.x.org
[ 15.278] Markers: (–) probed, () from config file, (==) default setting,
[ 15.278] (==) Log file: “/var/log/Xorg.0.log”, Time: Wed Apr 22 08:13:12 2015
[ 15.281] (==) Using system config directory “/usr/share/X11/xorg.conf.d”
[ 15.282] (==) No Layout section. Using the first Screen section.
[ 15.282] (==) No screen section available. Using defaults.
[ 15.282] () |–>Screen “Default Screen Section” (0)
[ 15.282] (**) | |–>Monitor “”
[ 15.282] (==) No monitor specified for screen “Default Screen Section”.
Using a default monitor configuration.
[ 15.282] (==) Automatically adding devices
[ 15.282] (==) Automatically enabling devices
[ 15.282] (==) Automatically adding GPU devices
[ 15.284] (WW) The directory “/usr/share/fonts/X11/cyrillic” does not exist.
[ 15.284] Entry deleted from font path.
[ 15.288] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
/usr/share/fonts/X11/75dpi,
built-ins
[ 15.288] (==) ModulePath set to “/usr/lib/xorg/modules”
[ 15.288] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 15.288] (II) Loader magic: 0x7f02f15f5d80
[ 15.288] (II) Module ABI versions:
[ 15.288] X.Org ANSI C Emulation: 0.4
[ 15.288] X.Org Video Driver: 18.0
[ 15.288] X.Org XInput driver : 21.0
[ 15.288] X.Org Server Extension : 8.0
[ 15.289] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 15.290] (–) PCI:*(0:0:2:0) 8086:1616:17aa:2226 rev 9, Mem @ 0xf0000000/16777216, 0xe0000000/268435456, I/O @ 0x00003000/64
[ 15.290] (II) LoadModule: “glx”
[ 15.291] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 15.299] (II) Module glx: vendor=“X.Org Foundation”
[ 15.299] compiled for 1.16.4, module version = 1.0.0
[ 15.299] ABI class: X.Org Server Extension, version 8.0
[ 15.299] (==) AIGLX enabled
[ 15.299] (==) Matched intel as autoconfigured driver 0
[ 15.299] (==) Matched intel as autoconfigured driver 1
[ 15.299] (==) Matched modesetting as autoconfigured driver 2
[ 15.299] (==) Matched fbdev as autoconfigured driver 3
[ 15.299] (==) Matched vesa as autoconfigured driver 4
[ 15.299] (==) Assigned the driver to the xf86ConfigLayout
[ 15.299] (II) LoadModule: “intel”
[ 15.305] (II) Loading /usr/lib/xorg/modules/drivers/intel_drv.so
[ 15.310] (II) Module intel: vendor=“X.Org Foundation”
[ 15.310] compiled for 1.15.99.904, module version = 2.21.15
[ 15.310] Module class: X.Org Video Driver
[ 15.310] ABI class: X.Org Video Driver, version 18.0
[ 15.310] (II) LoadModule: “modesetting”
[ 15.310] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 15.311] (II) Module modesetting: vendor=“X.Org Foundation”
[ 15.311] compiled for 1.15.99.904, module version = 0.9.0
[ 15.311] Module class: X.Org Video Driver
[ 15.311] ABI class: X.Org Video Driver, version 18.0
[ 15.311] (II) LoadModule: “fbdev”
[ 15.311] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[ 15.311] (II) Module fbdev: vendor=“X.Org Foundation”
[ 15.311] compiled for 1.15.99.904, module version = 0.4.4
[ 15.311] (II) LoadModule: “vesa”
[ 15.312] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[ 15.312] (II) Module vesa: vendor=“X.Org Foundation”
[ 15.312] compiled for 1.15.99.904, module version = 2.3.3
[ 15.312] Module class: X.Org Video Driver
[ 15.312] ABI class: X.Org Video Driver, version 18.0
[ 15.312] (II) intel: Driver for Intel® Integrated Graphics Chipsets:
i810, i810-dc100, i810e, i815, i830M, 845G, 854, 852GM/855GM, 865G,
915G, E7221 (i915), 915GM, 945G, 945GM, 945GME, Pineview GM,
Pineview G, 965G, G35, 965Q, 946GZ, 965GM, 965GME/GLE, G33, Q35, Q33,
GM45, 4 Series, G45/G43, Q45/Q43, G41, B43, HD Graphics,
HD Graphics 2000, HD Graphics 3000, HD Graphics 2500,
HD Graphics 4000, HD Graphics P4000, HD Graphics 4600,
HD Graphics 5000, HD Graphics P4600/P4700, Iris™ Graphics 5100,
HD Graphics 4400, HD Graphics 4200, Iris™ Pro Graphics 5200
[ 15.313] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 15.313] (II) FBDEV: driver for framebuffer: fbdev
[ 15.313] (II) VESA: driver for VESA chipsets: vesa
[ 15.313] (++) using VT number 7
[ 15.321] (WW) Falling back to old probe method for modesetting
[ 15.321] (WW) Falling back to old probe method for fbdev
[ 15.321] (II) Loading sub module “fbdevhw”
[ 15.321] (II) LoadModule: “fbdevhw”
[ 15.321] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[ 15.322] (II) Module fbdevhw: vendor=“X.Org Foundation”
[ 15.322] compiled for 1.16.4, module version = 0.0.2
[ 15.322] ABI class: X.Org Video Driver, version 18.0
[ 15.322] (WW) Falling back to old probe method for vesa
[ 15.322] (II) intel(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 15.322] (==) intel(0): Depth 24, (–) framebuffer bpp 32
[ 15.322] (==) intel(0): RGB weight 888
[ 15.322] (==) intel(0): Default visual is TrueColor
[ 15.322] (WW) intel(0): Unknown chipset
[ 15.322] () intel(0): Relaxed fencing disabled
[ 15.322] () intel(0): Wait on SwapBuffers? enabled
[ 15.322] () intel(0): Triple buffering? enabled
[ 15.322] () intel(0): Framebuffer linear
[ 15.322] () intel(0): Pixmaps tiled
[ 15.322] () intel(0): 3D buffers tiled
[ 15.322] () intel(0): SwapBuffers wait enabled
[ 15.322] (==) intel(0): video overlay key set to 0x101fe
[ 15.323] (II) intel(0): Output eDP1 has no monitor section
[ 15.323] (–) intel(0): found backlight control interface /sys/class/backlight/intel_backlight
[ 15.323] (II) intel(0): Output DP1 has no monitor section
[ 15.352] (II) intel(0): Output HDMI1 has no monitor section
[ 15.352] (II) intel(0): Output DP2 has no monitor section
[ 15.352] (II) intel(0): Output HDMI2 has no monitor section
[ 15.353] (II) intel(0): EDID for output eDP1
[ 15.353] (II) intel(0): Manufacturer: LGD Model: 437 Serial#: 0
[ 15.353] (II) intel(0): Year: 2013 Week: 0
[ 15.353] (II) intel(0): EDID Version: 1.4
[ 15.353] (II) intel(0): Digital Display Input
[ 15.353] (II) intel(0): 6 bits per channel
[ 15.353] (II) intel(0): Digital interface is DisplayPort
[ 15.353] (II) intel(0): Max Image Size [cm]: horiz.: 28 vert.: 16
[ 15.353] (II) intel(0): Gamma: 2.20
[ 15.353] (II) intel(0): No DPMS capabilities specified
[ 15.353] (II) intel(0): Supported color encodings: RGB 4:4:4
[ 15.353] (II) intel(0): First detailed timing is preferred mode
[ 15.353] (II) intel(0): Preferred mode is native pixel format and refresh rate
[ 15.353] (II) intel(0): redX: 0.604 redY: 0.351 greenX: 0.335 greenY: 0.558
[ 15.353] (II) intel(0): blueX: 0.148 blueY: 0.113 whiteX: 0.313 whiteY: 0.329
[ 15.353] (II) intel(0): Manufacturer’s mask: 0
[ 15.353] (II) intel(0): Supported detailed timing:
[ 15.353] (II) intel(0): clock: 138.5 MHz Image Size: 276 x 156 mm
[ 15.353] (II) intel(0): h_active: 1920 h_sync: 1968 h_sync_end 2000 h_blank_end 2106 h_border: 0
[ 15.353] (II) intel(0): v_active: 1080 v_sync: 1083 v_sync_end 1088 v_blanking: 1095 v_border: 0
[ 15.353] (II) intel(0): LG Display
[ 15.353] (II) intel(0): LP125WF2-SPB2
[ 15.353] (II) intel(0): EDID (in hex):
[ 15.353] (II) intel(0): 00ffffffffffff0030e4370400000000
[ 15.353] (II) intel(0): 00170104951c107802bf059a59558e26
[ 15.353] (II) intel(0): 1d505400000001010101010101010101
[ 15.353] (II) intel(0): 010101010101163680ba70380f403020
[ 15.353] (II) intel(0): 3500149c1000001a0000000000000000
[ 15.353] (II) intel(0): 00000000000000000000000000fe004c
[ 15.353] (II) intel(0): 4720446973706c61790a2020000000fe
[ 15.353] (II) intel(0): 004c503132355746322d5350423200dd
[ 15.353] (II) intel(0): Not using default mode “320x240” (doublescan mode not supported)
[ 15.353] (II) intel(0): Not using default mode “400x300” (doublescan mode not supported)
[ 15.353] (II) intel(0): Not using default mode “512x384” (doublescan mode not supported)
[ 15.353] (II) intel(0): Not using default mode “640x480” (doublescan mode not supported)
[ 15.353] (II) intel(0): Not using default mode “640x512” (doublescan mode not supported)
[ 15.353] (II) intel(0): Not using default mode “800x600” (doublescan mode not supported)
[ 15.353] (II) intel(0): Not using default mode “896x672” (doublescan mode not supported)
[ 15.353] (II) intel(0): Not using default mode “928x696” (doublescan mode not supported)
[ 15.353] (II) intel(0): Not using default mode “960x720” (doublescan mode not supported)
[ 15.353] (II) intel(0): Not using default mode “576x432” (doublescan mode not supported)
[ 15.353] (II) intel(0): Not using default mode “680x384” (doublescan mode not supported)
[ 15.353] (II) intel(0): Not using default mode “700x525” (doublescan mode not supported)
[ 15.353] (II) intel(0): Not using default mode “720x450” (doublescan mode not supported)
[ 15.353] (II) intel(0): Not using default mode “800x512” (doublescan mode not supported)
[ 15.353] (II) intel(0): Not using default mode “840x525” (doublescan mode not supported)
[ 15.353] (II) intel(0): Not using default mode “960x540” (doublescan mode not supported)
[ 15.353] (II) intel(0): Not using default mode “960x600” (doublescan mode not supported)
[ 15.353] (II) intel(0): Not using default mode “1024x768” (doublescan mode not supported)
[ 15.353] (II) intel(0): Printing probed modes for output eDP1
[ 15.353] (II) intel(0): Modeline "1920x1080"x60.0 138.46 1920 1968 2000 2106 1080 1083 1088 1095 +hsync -vsync (65.7 kHz eP)
[ 15.353] (II) intel(0): Modeline "1920x1080"x59.9 138.50 1920 1968 2000 2080 1080 1083 1088 1111 +hsync -vsync (66.6 kHz d)
[ 15.353] (II) intel(0): Modeline "1680x1050"x60.0 146.25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync (65.3 kHz d)
[ 15.353] (II) intel(0): Modeline "1680x1050"x59.9 119.00 1680 1728 1760 1840 1050 1053 1059 1080 +hsync -vsync (64.7 kHz d)
[ 15.353] (II) intel(0): Modeline "1600x1024"x60.2 103.12 1600 1600 1656 1664 1024 1024 1029 1030 +hsync +vsync (62.0 kHz d)
[ 15.353] (II) intel(0): Modeline "1400x1050"x60.0 122.00 1400 1488 1640 1880 1050 1052 1064 1082 +hsync +vsync (64.9 kHz d)
[ 15.353] (II) intel(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz d)
[ 15.353] (II) intel(0): Modeline "1440x900"x59.9 106.50 1440 1520 1672 1904 900 903 909 934 -hsync +vsync (55.9 kHz d)
[ 15.353] (II) intel(0): Modeline "1280x960"x60.0 108.00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync (60.0 kHz d)
[ 15.353] (II) intel(0): Modeline "1360x768"x59.8 84.75 1360 1432 1568 1776 768 771 781 798 -hsync +vsync (47.7 kHz d)
[ 15.353] (II) intel(0): Modeline "1360x768"x60.0 72.00 1360 1408 1440 1520 768 771 781 790 +hsync -vsync (47.4 kHz d)
[ 15.353] (II) intel(0): Modeline "1152x864"x60.0 81.62 1152 1216 1336 1520 864 865 868 895 -hsync +vsync (53.7 kHz d)
[ 15.353] (II) intel(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz d)
[ 15.353] (II) intel(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz d)
[ 15.353] (II) intel(0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz d)
[ 15.353] (II) intel(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz d)
[ 15.353] (II) intel(0): EDID for output DP1
[ 15.384] (II) intel(0): EDID for output HDMI1
[ 15.384] (II) intel(0): EDID for output DP2
[ 15.384] (II) intel(0): EDID for output HDMI2
[ 15.384] (II) intel(0): Output eDP1 connected
[ 15.384] (II) intel(0): Output DP1 disconnected
[ 15.384] (II) intel(0): Output HDMI1 disconnected
[ 15.384] (II) intel(0): Output DP2 disconnected
[ 15.384] (II) intel(0): Output HDMI2 disconnected
[ 15.384] (II) intel(0): Using exact sizes for initial modes
[ 15.384] (II) intel(0): Output eDP1 using initial mode 1920x1080
[ 15.384] (II) intel(0): Using default gamma of (1.0, 1.0, 1.0) unless otherwise stated.
[ 15.384] (II) intel(0): Kernel page flipping support detected, enabling
[ 15.384] (==) intel(0): DPI set to (96, 96)
[ 15.384] (II) Loading sub module “fb”
[ 15.384] (II) LoadModule: “fb”
[ 15.384] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 15.385] (II) Module fb: vendor=“X.Org Foundation”
[ 15.385] compiled for 1.16.4, module version = 1.0.0
[ 15.385] ABI class: X.Org ANSI C Emulation, version 0.4
[ 15.385] (II) Loading sub module “dri2”
[ 15.385] (II) LoadModule: “dri2”
[ 15.385] (II) Module “dri2” already built-in
[ 15.385] (II) UnloadModule: “modesetting”
[ 15.385] (II) Unloading modesetting
[ 15.385] (II) UnloadModule: “fbdev”
[ 15.385] (II) Unloading fbdev
[ 15.385] (II) UnloadSubModule: “fbdevhw”
[ 15.385] (II) Unloading fbdevhw
[ 15.386] (II) UnloadModule: “vesa”
[ 15.386] (II) Unloading vesa
[ 15.386] (==) Depth 24 pixmap format is 32 bpp
[ 15.386] (WW) intel(0): cannot enable DRI2 whilst forcing software fallbacks
[ 15.386] (II) intel(0): Allocated new frame buffer 1920x1080 stride 7680, untiled
[ 15.387] (II) UXA(0): Driver registered support for the following operations:
[ 15.387] (II) solid
[ 15.387] (II) copy
[ 15.387] (II) composite (RENDER acceleration)
[ 15.387] (II) put_image
[ 15.387] (II) get_image
[ 15.387] (==) intel(0): Backing store enabled
[ 15.387] (==) intel(0): Silken mouse enabled
[ 15.388] (II) intel(0): Initializing HW Cursor
[ 15.388] (II) intel(0): RandR 1.2 enabled, ignore the following RandR disabled message.
[ 15.388] (==) intel(0): DPMS enabled
[ 15.388] (==) intel(0): Intel XvMC decoder disabled
[ 15.388] (WW) intel(0): Disabling Xv because no adaptors could be initialized.
[ 15.388] (II) intel(0): direct rendering: Failed
[ 15.388] (==) intel(0): hotplug detection: “enabled”
[ 15.408] (–) RandR disabled
[ 15.415] (II) SELinux: Disabled on system
[ 15.416] (II) AIGLX: Screen 0 is not DRI2 capable
[ 15.416] (EE) AIGLX: reverting to software rendering
[ 15.484] (II) AIGLX: Loaded and initialized swrast
[ 15.484] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[ 15.484] (II) intel(0): Setting screen physical size to 508 x 285
[ 15.522] (II) config/udev: Adding input device Power Button (/dev/input/event3)
[ 15.522] () Power Button: Applying InputClass “evdev keyboard catchall”
[ 15.522] (II) LoadModule: “evdev”
[ 15.522] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 15.524] (II) Module evdev: vendor=“X.Org Foundation”
[ 15.524] compiled for 1.16.0, module version = 2.9.0
[ 15.524] Module class: X.Org XInput Driver
[ 15.524] ABI class: X.Org XInput driver, version 21.0
[ 15.524] (II) Using input driver ‘evdev’ for ‘Power Button’
[ 15.524] () Power Button: always reports core events
[ 15.524] () evdev: Power Button: Device: “/dev/input/event3”
[ 15.524] (–) evdev: Power Button: Vendor 0 Product 0x1
[ 15.524] (–) evdev: Power Button: Found keys
[ 15.524] (II) evdev: Power Button: Configuring as keyboard
[ 15.524] () Option “config_info” “udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input7/event3”
[ 15.524] (II) XINPUT: Adding extended input device “Power Button” (type: KEYBOARD, id 6)
[ 15.524] () Option “xkb_rules” “evdev”
[ 15.524] () Option “xkb_model” “pc105”
[ 15.524] () Option “xkb_layout” “ch”
[ 15.524] () Option “xkb_variant” “fr”
[ 15.537] (II) config/udev: Adding input device Video Bus (/dev/input/event13)
[ 15.537] () Video Bus: Applying InputClass “evdev keyboard catchall”
[ 15.537] (II) Using input driver ‘evdev’ for ‘Video Bus’
[ 15.537] () Video Bus: always reports core events
[ 15.537] () evdev: Video Bus: Device: “/dev/input/event13”
[ 15.537] (–) evdev: Video Bus: Vendor 0 Product 0x6
[ 15.537] (–) evdev: Video Bus: Found keys
[ 15.537] (II) evdev: Video Bus: Configuring as keyboard
[ 15.537] () Option “config_info” “udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input18/event13”
[ 15.537] (II) XINPUT: Adding extended input device “Video Bus” (type: KEYBOARD, id 7)
[ 15.537] () Option “xkb_rules” “evdev”
[ 15.537] () Option “xkb_model” “pc105”
[ 15.537] () Option “xkb_layout” “ch”
[ 15.537] () Option “xkb_variant” “fr”
[ 15.537] (II) config/udev: Adding input device Lid Switch (/dev/input/event1)
[ 15.537] (II) No input driver specified, ignoring this device.
[ 15.537] (II) This device may have been added with another device file.
[ 15.537] (II) config/udev: Adding input device Sleep Button (/dev/input/event2)
[ 15.537] () Sleep Button: Applying InputClass “evdev keyboard catchall”
[ 15.537] (II) Using input driver ‘evdev’ for ‘Sleep Button’
[ 15.537] () Sleep Button: always reports core events
[ 15.537] () evdev: Sleep Button: Device: “/dev/input/event2”
[ 15.537] (–) evdev: Sleep Button: Vendor 0 Product 0x3
[ 15.537] (–) evdev: Sleep Button: Found keys
[ 15.537] (II) evdev: Sleep Button: Configuring as keyboard
[ 15.537] () Option “config_info” “udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input6/event2”
[ 15.537] (II) XINPUT: Adding extended input device “Sleep Button” (type: KEYBOARD, id 8)
[ 15.538] (II) config/udev: Adding input device HDA Intel HDMI HDMI/DP,pcm=3 (/dev/input/event14)
[ 15.538] (II) No input driver specified, ignoring this device.
[ 15.538] (II) This device may have been added with another device file.
[ 15.538] (II) config/udev: Adding input device HDA Intel HDMI HDMI/DP,pcm=7 (/dev/input/event15)
[ 15.538] (II) config/udev: Adding input device HDA Intel HDMI HDMI/DP,pcm=8 (/dev/input/event16)
[ 15.538] (II) config/udev: Adding input device ELAN Touchscreen (/dev/input/event10)
[ 15.538] () ELAN Touchscreen: Applying InputClass “evdev touchscreen catchall”
[ 15.538] (II) Using input driver ‘evdev’ for ‘ELAN Touchscreen’
[ 15.538] () ELAN Touchscreen: always reports core events
[ 15.538] () evdev: ELAN Touchscreen: Device: “/dev/input/event10”
[ 15.538] (–) evdev: ELAN Touchscreen: Vendor 0x4f3 Product 0x301
[ 15.538] (–) evdev: ELAN Touchscreen: Found absolute axes
[ 15.538] (–) evdev: ELAN Touchscreen: Found absolute multitouch axes
[ 15.538] (II) evdev: ELAN Touchscreen: No buttons found, faking one.
[ 15.538] (–) evdev: ELAN Touchscreen: Found x and y absolute axes
[ 15.538] (–) evdev: ELAN Touchscreen: Found absolute touchscreen
[ 15.538] (II) evdev: ELAN Touchscreen: Configuring as touchscreen
[ 15.538] () evdev: ELAN Touchscreen: YAxisMapping: buttons 4 and 5
[ 15.538] () evdev: ELAN Touchscreen: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 15.538] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-5/2-5:1.0/0003:04F3:0301.0001/input/input15/event10”
[ 15.538] (II) XINPUT: Adding extended input device “ELAN Touchscreen” (type: TOUCHSCREEN, id 9)
[ 15.538] (II) evdev: ELAN Touchscreen: initialized for absolute axes.
[ 15.538] () ELAN Touchscreen: (accel) keeping acceleration scheme 1
[ 15.538] () ELAN Touchscreen: (accel) acceleration profile 0
[ 15.538] () ELAN Touchscreen: (accel) acceleration factor: 2.000
[ 15.538] () ELAN Touchscreen: (accel) acceleration threshold: 4
[ 15.539] (II) config/udev: Adding input device ELAN Touchscreen (/dev/input/mouse0)
[ 15.539] (II) No input driver specified, ignoring this device.
[ 15.539] (II) This device may have been added with another device file.
[ 15.539] (II) config/udev: Adding input device Integrated Camera (/dev/input/event11)
[ 15.539] () Integrated Camera: Applying InputClass “evdev keyboard catchall”
[ 15.539] (II) Using input driver ‘evdev’ for ‘Integrated Camera’
[ 15.539] () Integrated Camera: always reports core events
[ 15.539] () evdev: Integrated Camera: Device: “/dev/input/event11”
[ 15.539] (–) evdev: Integrated Camera: Vendor 0x4f2 Product 0xb449
[ 15.539] (–) evdev: Integrated Camera: Found keys
[ 15.539] (II) evdev: Integrated Camera: Configuring as keyboard
[ 15.539] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-8/2-8:1.0/input/input17/event11”
[ 15.539] (II) XINPUT: Adding extended input device “Integrated Camera” (type: KEYBOARD, id 10)
[ 15.539] () Option “xkb_rules” “evdev”
[ 15.539] () Option “xkb_model” “pc105”
[ 15.539] () Option “xkb_layout” “ch”
[ 15.539] () Option “xkb_variant” “fr”
[ 15.539] (II) config/udev: Adding input device HDA Digital PCBeep (/dev/input/event5)
[ 15.539] (II) config/udev: Adding input device HDA Intel PCH Dock Mic (/dev/input/event6)
[ 15.539] (II) config/udev: Adding input device HDA Intel PCH Mic (/dev/input/event7)
[ 15.539] (II) config/udev: Adding input device HDA Intel PCH Dock Headphone (/dev/input/event8)
[ 15.540] (II) config/udev: Adding input device HDA Intel PCH Headphone (/dev/input/event9)
[ 15.540] (II) No input driver specified, ignoring this device.
[ 15.540] (II) This device may have been added with another device file.
[ 15.540] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event0)
[ 15.540] () AT Translated Set 2 keyboard: Applying InputClass “evdev keyboard catchall”
[ 15.540] (II) Using input driver ‘evdev’ for ‘AT Translated Set 2 keyboard’
[ 15.540] () AT Translated Set 2 keyboard: always reports core events
[ 15.540] () evdev: AT Translated Set 2 keyboard: Device: “/dev/input/event0”
[ 15.540] (–) evdev: AT Translated Set 2 keyboard: Vendor 0x1 Product 0x1
[ 15.540] (–) evdev: AT Translated Set 2 keyboard: Found keys
[ 15.540] (II) evdev: AT Translated Set 2 keyboard: Configuring as keyboard
[ 15.540] () Option “config_info” “udev:/sys/devices/platform/i8042/serio0/input/input0/event0”
[ 15.540] (II) XINPUT: Adding extended input device “AT Translated Set 2 keyboard” (type: KEYBOARD, id 11)
[ 15.540] () Option “xkb_rules” “evdev”
[ 15.540] () Option “xkb_model” “pc105”
[ 15.540] () Option “xkb_layout” “ch”
[ 15.540] () Option “xkb_variant” “fr”
[ 15.540] (II) config/udev: Adding input device PS/2 Synaptics TouchPad (/dev/input/event12)
[ 15.540] () PS/2 Synaptics TouchPad: Applying InputClass “evdev pointer catchall”
[ 15.540] () PS/2 Synaptics TouchPad: Applying InputClass “Touchpad/TrackPoint”
[ 15.540] (II) Using input driver ‘evdev’ for ‘PS/2 Synaptics TouchPad’
[ 15.540] () PS/2 Synaptics TouchPad: always reports core events
[ 15.540] () evdev: PS/2 Synaptics TouchPad: Device: “/dev/input/event12”
[ 15.540] (–) evdev: PS/2 Synaptics TouchPad: Vendor 0x2 Product 0x1
[ 15.540] (–) evdev: PS/2 Synaptics TouchPad: Found 3 mouse buttons
[ 15.540] (–) evdev: PS/2 Synaptics TouchPad: Found relative axes
[ 15.540] (–) evdev: PS/2 Synaptics TouchPad: Found x and y relative axes
[ 15.540] (II) evdev: PS/2 Synaptics TouchPad: Configuring as mouse
[ 15.540] () Option “Emulate3Buttons” “0”
[ 15.540] () Option “EmulateWheel” “1”
[ 15.540] () Option “EmulateWheelButton” “2”
[ 15.540] () Option “YAxisMapping” “4 5”
[ 15.540] () evdev: PS/2 Synaptics TouchPad: YAxisMapping: buttons 4 and 5
[ 15.540] () Option “XAxisMapping” “6 7”
[ 15.540] () evdev: PS/2 Synaptics TouchPad: XAxisMapping: buttons 6 and 7
[ 15.540] () evdev: PS/2 Synaptics TouchPad: EmulateWheelButton: 2, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 15.540] () Option “config_info” “udev:/sys/devices/platform/i8042/serio1/input/input9/event12”
[ 15.540] (II) XINPUT: Adding extended input device “PS/2 Synaptics TouchPad” (type: MOUSE, id 12)
[ 15.540] (II) evdev: PS/2 Synaptics TouchPad: initialized for relative axes.
[ 15.540] () PS/2 Synaptics TouchPad: (accel) keeping acceleration scheme 1
[ 15.540] () PS/2 Synaptics TouchPad: (accel) acceleration profile 0
[ 15.540] () PS/2 Synaptics TouchPad: (accel) acceleration factor: 2.000
[ 15.540] () PS/2 Synaptics TouchPad: (accel) acceleration threshold: 4
[ 15.540] (II) config/udev: Adding input device PS/2 Synaptics TouchPad (/dev/input/mouse1)
[ 15.541] (II) config/udev: Adding input device PC Speaker (/dev/input/event4)
[ 15.541] (II) No input driver specified, ignoring this device.
[ 15.541] (II) This device may have been added with another device file.
[ 24.877] (II) intel(0): EDID vendor “LGD”, prod id 1079
[ 24.877] (II) intel(0): Printing DDC gathered Modelines:
[ 24.877] (II) intel(0): Modeline "1920x1080"x0.0 138.46 1920 1968 2000 2106 1080 1083 1088 1095 +hsync -vsync (65.7 kHz eP)
[ 25.812] (II) intel(0): EDID vendor “LGD”, prod id 1079
[ 25.812] (II) intel(0): Printing DDC gathered Modelines:
[ 25.812] (II) intel(0): Modeline "1920x1080"x0.0 138.46 1920 1968 2000 2106 1080 1083 1088 1095 +hsync -vsync (65.7 kHz eP)
[ 28.502] (II) intel(0): EDID vendor “LGD”, prod id 1079
[ 28.502] (II) intel(0): Printing DDC gathered Modelines:
[ 28.502] (II) intel(0): Modeline "1920x1080"x0.0 138.46 1920 1968 2000 2106 1080 1083 1088 1095 +hsync -vsync (65.7 kHz eP)
[ 28.627] (II) intel(0): EDID vendor “LGD”, prod id 1079
[ 28.627] (II) intel(0): Printing DDC gathered Modelines:
[ 28.627] (II) intel(0): Modeline "1920x1080"x0.0 138.46 1920 1968 2000 2106 1080 1083 1088 1095 +hsync -vsync (65.7 kHz eP)
[ 28.692] (II) intel(0): EDID vendor “LGD”, prod id 1079
[ 28.692] (II) intel(0): Printing DDC gathered Modelines:
[ 28.692] (II) intel(0): Modeline "1920x1080"x0.0 138.46 1920 1968 2000 2106 1080 1083 1088 1095 +hsync -vsync (65.7 kHz eP)
[ 28.885] (II) intel(0): EDID vendor “LGD”, prod id 1079
[ 28.885] (II) intel(0): Printing DDC gathered Modelines:
[ 28.885] (II) intel(0): Modeline "1920x1080"x0.0 138.46 1920 1968 2000 2106 1080 1083 1088 1095 +hsync -vsync (65.7 kHz eP)
[ 29.058] (II) intel(0): EDID vendor “LGD”, prod id 1079
[ 29.058] (II) intel(0): Printing DDC gathered Modelines:
[ 29.058] (II) intel(0): Modeline "1920x1080"x0.0 138.46 1920 1968 2000 2106 1080 1083 1088 1095 +hsync -vsync (65.7 kHz eP)
[ 29.254] (II) intel(0): EDID vendor “LGD”, prod id 1079
[ 29.254] (II) intel(0): Printing DDC gathered Modelines:
[ 29.254] (II) intel(0): Modeline "1920x1080"x0.0 138.46 1920 1968 2000 2106 1080 1083 1088 1095 +hsync -vsync (65.7 kHz eP)
[ 29.435] (II) intel(0): EDID vendor “LGD”, prod id 1079
[ 29.435] (II) intel(0): Printing DDC gathered Modelines:
[ 29.435] (II) intel(0): Modeline "1920x1080"x0.0 138.46 1920 1968 2000 2106 1080 1083 1088 1095 +hsync -vsync (65.7 kHz eP)
[ 29.616] (II) intel(0): EDID vendor “LGD”, prod id 1079
[ 29.616] (II) intel(0): Printing DDC gathered Modelines:
[ 29.616] (II) intel(0): Modeline "1920x1080"x0.0 138.46 1920 1968 2000 2106 1080 1083 1088 1095 +hsync -vsync (65.7 kHz eP)
[ 30.147] (II) intel(0): EDID vendor “LGD”, prod id 1079
[ 30.147] (II) intel(0): Printing DDC gathered Modelines:
[ 30.147] (II) intel(0): Modeline "1920x1080"x0.0 138.46 1920 1968 2000 2106 1080 1083 1088 1095 +hsync -vsync (65.7 kHz eP)
[ 30.370] (II) intel(0): EDID vendor “LGD”, prod id 1079
[ 30.370] (II) intel(0): Printing DDC gathered Modelines:
[ 30.370] (II) intel(0): Modeline "1920x1080"x0.0 138.46 1920 1968 2000 2106 1080 1083 1088 1095 +hsync -vsync (65.7 kHz eP)
[ 30.554] (II) intel(0): EDID vendor “LGD”, prod id 1079
[ 30.555] (II) intel(0): Printing DDC gathered Modelines:
[ 30.555] (II) intel(0): Modeline "1920x1080"x0.0 138.46 1920 1968 2000 2106 1080 1083 1088 1095 +hsync -vsync (65.7 kHz eP)
[ 30.777] (II) intel(0): EDID vendor “LGD”, prod id 1079
[ 30.777] (II) intel(0): Printing DDC gathered Modelines:
[ 30.777] (II) intel(0): Modeline "1920x1080"x0.0 138.46 1920 1968 2000 2106 1080 1083 1088 1095 +hsync -vsync (65.7 kHz eP)
