Bonsoir,
Petit problème qui dure depuis x temps, et dont je n’ai jamais vraiment trouvé une solution, la gravure d’une image iso sur un CD-R sous Debian.
Avec Brasero, la gravure ne démarre pas du tout, et me renvoie une belle erreur.
Checking session consistency (brasero_burn_check_session_consistency brasero-burn.c:1739)
BraseroBurnURI called brasero_job_get_action
BraseroBurnURI called brasero_job_set_output_size_for_current_track
BraseroBurnURI stopping
BraseroBurnURI called brasero_job_get_session_output_size
BraseroBurnURI output set (IMAGE) image = /tmp/brasero_tmp_BA6MIY.bin toc = none
BraseroBurnURI called brasero_job_get_current_track
BraseroBurnURI no burn:// URI found
BraseroLocalTrack called brasero_job_get_action
BraseroLocalTrack called brasero_job_set_output_size_for_current_track
BraseroLocalTrack stopping
BraseroLocalTrack called brasero_job_get_session_output_size
BraseroLocalTrack output set (IMAGE) image = /tmp/brasero_tmp_Q3MNIY.bin toc = none
BraseroLocalTrack called brasero_job_get_current_track
BraseroLocalTrack no remote URIs
BraseroChecksumImage called brasero_job_get_current_track
BraseroChecksumImage called brasero_job_get_action
BraseroChecksumImage called brasero_job_get_flags
BraseroChecksumImage called brasero_job_get_fd_in
BraseroChecksumImage called brasero_job_set_output_size_for_current_track
BraseroChecksumImage stopping
BraseroChecksumImage called brasero_job_get_session_output_size
BraseroChecksumImage output set (IMAGE) image = /tmp/brasero_tmp_VANNIY.bin toc = none
BraseroChecksumImage called brasero_job_get_input_type
BraseroChecksumImage called brasero_job_set_current_action
BraseroChecksumImage Starting checksuming file /home/user/image.iso (size = 331350016)
BraseroChecksumImage called brasero_job_get_fd_out
BraseroChecksumImage Setting new checksum (type = 2) b3cd3e2e6a74b93ab41059c47c2b43fd ((null) before)
BraseroChecksumImage Finished track successfully
BraseroLibburn called brasero_job_get_action
BraseroLibburn unsupported operation
BraseroLibburn deactivating
BraseroLibburn called brasero_job_get_device
BraseroLibburn Drive (/dev/sr0) init result = 1
BraseroLibburn called brasero_job_get_flags
BraseroLibburn called brasero_job_get_media
BraseroLibburn called brasero_job_get_fd_in
BraseroLibburn called brasero_job_get_tracks
BraseroLibburn Setting multi 0
BraseroLibburn Setting burnproof 1
BraseroLibburn Setting dummy 0
BraseroLibburn called brasero_job_get_session_output_size
BraseroLibburn called brasero_job_set_current_action
BraseroLibburn burn_drive_convert_fs_adr( /dev/sr0 )
BraseroLibburn Writing
BraseroLibburn called brasero_job_set_dangerous
BraseroLibburn burn_drive_is_enumerable_adr( /dev/sr0 ) is true
BraseroLibburn Async START UNIT succeeded after 0.1 seconds
BraseroLibburn Allocating buffer via mmap()
BraseroLibburn cd Profile= 09h , obs= 32768 , obs_pad= 0
BraseroLibburn TAO pre-track 01 : get_nwa(0)=1, d=0 , demand=331350016 , cap=736958464
BraseroLibburn SCSI error condition on command 2Ah WRITE(10): [3 0C 00] Medium error. Write error.
BraseroLibburn Libburn reported an error SCSI error on write(224,16): [3 0C 00] Medium error. Write error.
BraseroLibburn called brasero_job_error
BraseroLibburn finished with an error
BraseroLibburn asked to stop because of an error
error = 1
message = "SCSI error on write(224,16): [3 0C 00] Medium error. Write error."
BraseroLibburn stopping
Session error : SCSI error on write(224,16): [3 0C 00] Medium error. Write error. (brasero_burn_record brasero-burn.c:2856)
Avec wodim, j’utilise la commande suivante
wodim -v -eject speed=1 dev=/dev/sr0 -data image.iso
Et la sortie
TOC Type: 1 = CD-ROM
scsidev: '/dev/sr0'
devname: '/dev/sr0'
scsibus: -2 target: -2 lun: -2
Linux sg driver version: 3.5.27
Wodim version: 1.1.11
SCSI buffer size: 64512
Device type : Removable CD-ROM
Version : 5
Response Format: 2
Capabilities :
Vendor_info : 'TSSTcorp'
Identification : 'DVD+-RW SU-208CB'
Revision : 'D200'
Device seems to be: Generic mmc2 DVD-R/DVD-RW.
Current: 0x0009 (CD-R)
Profile: 0x0015 (DVD-R/DL sequential recording)
Profile: 0x0016 (DVD-R/DL layer jump recording)
Profile: 0x002B (DVD+R/DL)
Profile: 0x001B (DVD+R)
Profile: 0x001A (DVD+RW)
Profile: 0x0014 (DVD-RW sequential recording)
Profile: 0x0013 (DVD-RW restricted overwrite)
Profile: 0x0012 (DVD-RAM)
Profile: 0x0011 (DVD-R sequential recording)
Profile: 0x0010 (DVD-ROM)
Profile: 0x000A (CD-RW)
Profile: 0x0009 (CD-R) (current)
Profile: 0x0008 (CD-ROM)
Profile: 0x0002 (Removable disk)
Using generic SCSI-3/mmc CD-R/CD-RW driver (mmc_cdr).
Driver flags : MMC-3 SWABAUDIO BURNFREE
Supported modes: TAO PACKET SAO SAO/R96P SAO/R96R RAW/R16 RAW/R96P RAW/R96R
Drive buf size : 554400 = 541 KB
Beginning DMA speed test. Set CDR_NODMATEST environment variable if device
communication breaks or freezes immediately after that.
FIFO size : 12582912 = 12288 KB
Track 01: data 316 MB
Total size: 362 MB (35:57.25) = 161794 sectors
Lout start: 363 MB (35:59/19) = 161794 sectors
Current Secsize: 2048
ATIP info from disk:
Indicated writing power: 4
Is not unrestricted
Is not erasable
Disk sub type: Medium Type A, low Beta category (A-) (2)
ATIP start of lead in: -12508 (97:15/17)
ATIP start of lead out: 359845 (79:59/70)
Disk type: Short strategy type (Phthalocyanine or similar)
Manuf. index: 22
Manufacturer: Ritek Co.
Blocks total: 359845 Blocks current: 359845 Blocks remaining: 198051
Speed set to 1764 KB/s
Starting to write CD/DVD at speed 10.0 in real TAO mode for single session.
Last chance to quit, starting real write in 0 seconds. Operation starts.
Waiting for reader process to fill input buffer ... input buffer ready.
Performing OPC...
Starting new track at sector: 0
Track 01: 316 of 316 MB written (fifo 100%) [buf 100%] 10.4x.
Track 01: Total bytes read/written: 331350016/331350016 (161792 sectors).
Writing time: 229.718s
Average write speed 9.7x.
Min drive buffer fill was 100%
Fixating...
Fixating time: 28.263s
BURN-Free was never needed.
wodim: fifo had 5220 puts and 5220 gets.
wodim: fifo was 0 times empty and 5021 times full, min fill was 96%.
Je ne vois pas d’erreurs avec wodim et au final le CD est vide. Pourtant il a tourné pendant 2 minutes.
Autre chose qui me dérange aussi, j’ai des CD-R verbatim qui ne sont pas du tout reconnu par le système, donc pour le moment ils pourrissent dans un placard.
Je vous remercie.
