Gravure de dvd impossible
Bonjour à tous
Je rencontre un problème lorsque j’essaye de graver un dvd, j’obtiens un message d’erreur au bout de quelques temps quelque soit le logiciel que j’utilise pour la gravure. Je vous met ci-dessous les différents messages obtenus:
-avec gnomebaker:[ul]Executing ‘builtin_dd if=/home/malfosse/telechargements/7.2-RELEASE-amd64-dvd1.iso of=/dev/hdc obs=32k seek=0’
/dev/hdc: “Current Write Speed” is 16.4x1352KBps.
:-[ WRITE@LBA=10h failed with SK=3h/POWER CALIBRATION AREA ERROR]: Input/output error
:frowning: write failed: Input/output error
/dev/hdc: flushing cache
/dev/hdc: updating RMA
/dev/hdc: closing disc[/ul]
-avec brasero:[ul]BraseroGrowisofs called brasero_job_get_action
BraseroGrowisofs getting varg
BraseroGrowisofs called brasero_job_get_input_type
BraseroGrowisofs got varg:
BraseroGrowisofs deactivating
BraseroGrowisofs called brasero_job_get_flags
BraseroGrowisofs called brasero_job_get_speed
BraseroGrowisofs called brasero_job_get_device
BraseroGrowisofs called brasero_job_get_session_output_size
BraseroGrowisofs called brasero_job_get_fd_in
BraseroGrowisofs called brasero_job_get_current_track
BraseroGrowisofs called brasero_job_set_current_action
growisofs
-use-the-force-luke=notray
-use-the-force-luke=dao
-dvd-compat
-speed=16
-use-the-force-luke=tracksize:1224109
-use-the-force-luke=tty
-Z
/dev/hdc=/home/malfosse/telechargements/7.2-RELEASE-amd64-dvd1.iso
BraseroGrowisofs launching command
BraseroGrowisofs called brasero_job_get_fd_out
BraseroGrowisofs stdout: Executing 'builtin_dd if=/home/malfosse/telechargements/7.2-RELEASE-amd64-dvd1.iso of=/dev/hdc obs=32k seek=0’
BraseroGrowisofs called brasero_job_set_dangerous
BraseroGrowisofs stderr: /dev/hdc: engaging DVD-R DAO upon user request…
BraseroGrowisofs stderr: :-[ PERFORM OPC failed with SK=5h/COMMAND SEQUENCE ERROR]: Input/output error
BraseroGrowisofs stderr: /dev/hdc: reserving 1224109 blocks
BraseroGrowisofs stderr: /dev/hdc: “Current Write Speed” is 16.4x1352KBps.
BraseroGrowisofs stdout: 32768/2506975232 ( 0.0%) @0.0x, remaining 7650:34 RBU 100.0% UBU -100.0%
BraseroGrowisofs called brasero_job_set_written_session
BraseroGrowisofs called brasero_job_set_rate
BraseroGrowisofs called brasero_job_start_progress
BraseroGrowisofs stdout: 32768/2506975232 ( 0.0%) @0.0x, remaining 12750:58 RBU 100.0% UBU 100.0%
BraseroGrowisofs stdout: 32768/2506975232 ( 0.0%) @0.0x, remaining 16576:15 RBU 100.0% UBU 100.0%
BraseroGrowisofs stdout: 32768/2506975232 ( 0.0%) @0.0x, remaining 20401:33 RBU 100.0% UBU 100.0%
BraseroGrowisofs stdout: 32768/2506975232 ( 0.0%) @0.0x, remaining 25501:56 RBU 100.0% UBU 100.0%
BraseroGrowisofs stderr: :-[ WRITE@LBA=10h failed with SK=3h/POWER CALIBRATION AREA ERROR]: Input/output error
BraseroGrowisofs stderr: :frowning: write failed: Input/output error
BraseroGrowisofs called brasero_job_error
BraseroGrowisofs finished with an error
BraseroGrowisofs asked to stop because of an error
error = 1
message = "Erreur non gérée, abandon"
BraseroGrowisofs stopping
BraseroGrowisofs got killed
BraseroGrowisofs stderr: /dev/hdc: flushing cache
BraseroGrowisofs called brasero_job_set_progress
Session error : Erreur non gérée, abandon (brasero_burn_record burn.c:2369)
[/ul]
Mon graveur est un plextor px-716a, lorsque que je fais un wodim -checkdrive dev=/dev/hdc j’obtiens :
[ul]Device type : Removable CD-ROM
Version : 0
Response Format: 1
Vendor_info : 'PLEXTOR '
Identification : 'DVDR PX-716A '
Revision : '1.10’
Device seems to be: Generic mmc2 DVD-R/DVD-RW.
Using generic SCSI-3/mmc DVD-R(W) driver (mmc_mdvd).
Driver flags : SWABAUDIO BURNFREE
Supported modes: PACKET SAO
[/ul]
Le graveur ne semble supporter que SAO alors qu’il devrait supporter d’autres modes de gravure, cela peut il être la cause de mon problème? Si quelqu’un avait une petite piste ca serait super cela fait bientot un mois que je m’arrache les cheveux sur ce problème et la calvitie me va pas trop :slight_smile:
La gravure de cd ainsi que la lecture de dvd par contre fonctionne parfaitement.
Cordialement
Je me permet un petit up après avoir apporter quelques precisions à mon post
Est-ce que tu as essayé de graver directement avec wodim sans utiliser de logiciel graphique ?
Si oui et que ça ne marche pas, quelles erreurs te renvoie wodim ?
Cela ne fonctionne pas non plus avec wodim, mais je ne suis pas très sur de la commande à utiliser.
[ul]esprit:/home/malfosse/iso# wodim 7.2-RELEASE-amd64-dvd1.iso dev=/dev/hdc
wodim: No write mode specified.
wodim: Asuming -tao mode.
wodim: Future versions of wodim may have different drive dependent defaults.
Version : 0
Response Format: 1
Revision : '1.10’
Speed set to 22160 KB/s
Starting to write CD/DVD at speed 17.0 in real unknown mode for single session.
Last chance to quit, starting real write in 0 seconds. Operation starts.
wodim: faio_wait_on_buffer for writer timed out.
Errno: 0 (Success), write_g1 scsi sendcmd: no error
CDB: 2A 00 00 00 00 1F 00 00 1F 00
status: 0x2 (CHECK CONDITION)
Sense Bytes: 70 00 03 00 00 00 00 0A 00 00 00 00 02 00 00 00
Sense Key: 0x3 Medium Error, Segment 0
Sense Code: 0x02 Qual 0x00 (no seek complete) Fru 0x0
Sense flags: Blk 0 (not valid)
resid: 63488
cmd finished after 65.640s timeout 40s
write track data: error after 63488 bytes
wodim: A write error occured.
wodim: Please properly read the error message above.
[/ul]
La commande est bonne (le dev= n’est utile que si wodim ne détecte pas automatiquement ton graveur)…
Je ne connais pas l’erreur que renvoie wodim mais avec ce message d’erreur tu devrais trouver plus facilement quelqu’un pour t’aider, ainsi que des sujets traitant de ce problème sur la Toile !
Merci de t’être penché sur mon problème je vais continuer à chercher sur cette piste.
[quote]
at speed 17.0 [/quote]
Est-ce vraiment la vitesse à laquelle tu graves d’habitude ?
