bonjour,
j’ essaye depuis quelque jour de graver en console ou k3b (en user ou root )mais impossible voici le probléme chaque cd vierge que je met dans le graveur il trouve toujours vide
sarge@debian:~/Documents$ cdrecord -v -audio -pad -eject speed=40 fs=30m dev=/dev/hdc CORONA-TRANCEMIX-JEAN-2004.wma
cdrecord: No write mode specified.
cdrecord: Asuming -tao mode.
cdrecord: Future versions of cdrecord may have different drive dependent defaults.
cdrecord: Continuing in 5 seconds…
Cdrecord-Clone 2.01a38 (i686-pc-linux-gnu) Copyright © 1995-2004 Jörg Schilling
NOTE: this version of cdrecord is an inofficial (modified) release of cdrecord
and thus may have bugs that are not present in the original version.
Please send bug reports and support requests to cdrtools@packages.debian.org.
The original author should not be bothered with problems of this version.
cdrecord: Warning: Running on Linux-2.6.8-1-386
cdrecord: There are unsettled issues with Linux-2.5 and newer.
cdrecord: If you have unexpected problems, please try Linux-2.4 or Solaris.
cdrecord: Warning: Linux-2.6.8 introduced incompatible interface changes.
cdrecord: Warning: SCSI transport does no longer work for suid root programs.
cdrecord: Warning: if cdrecord fails, try to run it from a root account.
TOC Type: 0 = CD-DA
cdrecord: Operation not permitted. WARNING: Cannot do mlockall(2).
cdrecord: WARNING: This causes a high risk for buffer underruns.
cdrecord: Operation not permitted. WARNING: Cannot set RR-scheduler
cdrecord: Permission denied. WARNING: Cannot set priority using setpriority().
scsidev: '/dev/hdc’
devname: '/dev/hdc’
scsibus: -2 target: -2 lun: -2
Warning: Open by ‘devname’ is unintentional and not supported.
Linux sg driver version: 3.5.27
Using libscg version ‘schily-0.8’.
SCSI buffer size: 64512
atapi: 1
Device type : Removable CD-ROM
Version : 0
Response Format: 1
Vendor_info : 'Polaroid’
Identifikation : 'BurnMAX52 '
Revision : '001H’
Device seems to be: Generic mmc CD-RW.
Current: 0x0000
Profile: 0x000A
Profile: 0x0009
Profile: 0x0008
Profile: 0x0002
Using generic SCSI-3/mmc CD-R/CD-RW driver (mmc_cdr).
Driver flags : MMC-2 SWABAUDIO BURNFREE
Supported modes: TAO PACKET SAO SAO/R96P SAO/R96R RAW/R16 RAW/R96P RAW/R96R
FIFO size : 31457280 = 30720 KB
Track 01: audio 7 MB (00:43.11) no preemp swab pad
Total size: 7 MB (00:43.12) = 3234 sectors
Lout start: 7 MB (00:45/09) = 3234 sectors
cdrecord: Success. test unit ready: scsi sendcmd: no error
CDB: 00 00 00 00 00 00
status: 0x2 (CHECK CONDITION)
Sense Bytes: 70 00 02 00 00 00 00 0A 00 00 00 00 3A 01 00 00
Sense Key: 0x2 Not Ready, Segment 0
Sense Code: 0x3A Qual 0x01 (medium not present - tray closed) Fru 0x0
Sense flags: Blk 0 (not valid)
cmd finished after 0.000s timeout 40s
cdrecord: No disk / Wrong disk!
Quoi faire des personnes ont se probléme ?
