bonjour,
impossible de graver en console ou k3b il trouve toujours aucun cdr que je met dans le graveur :
$ cdrecord -scanbus
Cdrecord-Clone 2.01 (i686-pc-linux-gnu) Copyright © 1995-2004 Jörg Schilling
cdrecord: Warning: Running on Linux-2.6.8-1-386
cdrecord: There are unsettled issues with Linux-2.5 and newer.
cdrecord: If you have unexpected problems, please try Linux-2.4 or Solaris.
cdrecord: Warning: Linux-2.6.8 introduced incompatible interface changes.
cdrecord: Warning: SCSI transport does no longer work for suid root programs.
cdrecord: Warning: if cdrecord fails, try to run it from a root account.
Using libscg version ‘schily-0.8’.
scsibus0:
0,0,0 0) 'ATAPI ’ 'CD-ROM 52X ’ ‘172A’ Removable CD-ROM
0,1,0 1) ‘Polaroid’ 'BurnMAX52 ’ ‘001H’ Removable CD-ROM
0,2,0 2) *
0,3,0 3) *
0,4,0 4) *
0,5,0 5) *
0,6,0 6) *
0,7,0 7) *
aprés si j’ essaye de graver :
$ cdrecord -v -speed=16 -dev=0,1,0 -overburn -data Gang.De.Requins.FRENCH-TS.ReEnc.DivX-GGT.avi
cdrecord: No write mode specified.
cdrecord: Asuming -tao mode.
cdrecord: Future versions of cdrecord may have different drive dependent defaults.
cdrecord: Continuing in 5 seconds…
TOC Type: 1 = CD-ROM
scsidev: '0,1,0’
scsibus: 0 target: 1 lun: 0
SCSI buffer size: 32768
atapi: 1
Device type : Removable CD-ROM
Version : 0
Response Format: 1
Vendor_info : 'Polaroid’
Identifikation : 'BurnMAX52 '
Revision : ‘001H’
Device seems to be: Generic mmc CD-RW.
Current: 0x0008
Profile: 0x000A
Profile: 0x0009
Profile: 0x0008 (current)
Profile: 0x0002
Using generic SCSI-3/mmc CD-R/CD-RW driver (mmc_cdr).
Driver flags : MMC-2 SWABAUDIO BURNFREE
Supported modes: TAO PACKET SAO SAO/R96P SAO/R96R RAW/R16 RAW/R96P RAW/R96R
FIFO size : 4194304 = 4096 KB
Track 01: data 697 MB
Total size: 801 MB (79:24.70) = 357353 sectors
Lout start: 801 MB (79:26/53) = 357353 sectors
cdrecord: Success. test unit ready: scsi sendcmd: no error
CDB: 00 00 00 00 00 00
status: 0x2 (CHECK CONDITION)
Sense Bytes: 70 00 02 00 00 00 00 0A 00 00 00 00 3A 01 00 00
Sense Key: 0x2 Not Ready, Segment 0
Sense Code: 0x3A Qual 0x01 (medium not present - tray closed) Fru 0x0
Sense flags: Blk 0 (not valid)
cmd finished after 0.000s timeout 40s
cdrecord: No disk / Wrong disk! <-----aucun cdr il trouver a l’ interieur
comment faire ? en root même probleme
