Voilou quelques nouvelles…
[code]Disk /dev/sda: 1500.3 GB, 1500301910016 bytes
255 heads, 63 sectors/track, 182401 cylinders
Disk identifier: 0x000646dc
/dev/sda1 1 182402 1465137152 5 Extended
/dev/sda5 1 38246 307205120 83 Linux
/dev/sda6 38246 45895 61436928 83 Linux
/dev/sda7 45895 84140 307205120 83 Linux
/dev/sda8 84140 91789 61436928 83 Linux
/dev/sda9 91789 98163 51203072 83 Linux
/dev/sda10 98164 136409 307205120 83 Linux
/dev/sda11 136409 182402 369437696 83 Linux
Disk /dev/sdb: 250.1 GB, 250059350016 bytes
255 heads, 63 sectors/track, 30401 cylinders
Disk identifier: 0x0004d1a4
/dev/sdb1 1 2432 19535008+ 83 Linux
/dev/sdb2 2433 2918 3903795 82 Linux swap / Solaris
/dev/sdb3 2919 5086 17408001 5 Extended
/dev/sdb5 * 2919 5086 17408000 83 Linux
Disk /dev/sdc: 2000.4 GB, 2000398934016 bytes
255 heads, 63 sectors/track, 243201 cylinders
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disk identifier: 0x0001fd03
/dev/sdc1 1 243202 1953513472 5 Extended
/dev/sdc5 1 38246 307205120 83 Linux
/dev/sdc6 38246 45895 61436928 83 Linux
/dev/sdc7 45895 84140 307205120 83 Linux
/dev/sdc8 84140 91789 61436928 83 Linux
/dev/sdc9 91789 98163 51203072 83 Linux
/dev/sdc10 98164 136409 307205120 83 Linux
/dev/sdc11 136409 182403 369448960 83 Linux
Disk /dev/sdd: 1500.3 GB, 1500301910016 bytes
Disk identifier: 0x000d6ccd
/dev/sdd1 1 182401 1465136001 5 Extended
/dev/sdd5 1 38245 307202899+ 83 Linux
/dev/sdd6 38246 45894 61440561 83 Linux
/dev/sdd7 45895 84139 307202931 83 Linux
/dev/sdd8 84140 91788 61440561 83 Linux
/dev/sdd9 91789 98162 51199123+ 83 Linux
/dev/sdd10 98163 136407 307202931 83 Linux
/dev/sdd11 136408 182401 369446773+ 83 Linux[/code]
Le detail de /etc/mdadm.conf :
Le detail de /etc/mdadm/mdadm.conf :
[code]# mdadm.conf
Please refer to mdadm.conf(5) for information about this file.
by default, scan all partitions (/proc/partitions) for MD superblocks.
alternatively, specify devices to scan, using wildcards if desired.
DEVICE partitions
auto-create devices with Debian standard permissions
CREATE owner=root group=disk mode=0660 auto=yes
automatically tag new arrays as belonging to the local system
HOMEHOST
instruct the monitoring daemon where to send mail alerts
MAILADDR root
definitions of existing MD arrays
ARRAY /dev/md5 UUID=c3f71c1f:82b5efb3:5afe47ed:2ca1911f
ARRAY /dev/md6 UUID=a41b88b9:6dfd23d3:5afe47ed:2ca1911f
ARRAY /dev/md7 UUID=21d5cec2:85ed9b31:5afe47ed:2ca1911f
ARRAY /dev/md8 UUID=2c316359:11262143:5afe47ed:2ca1911f
ARRAY /dev/md9 UUID=9616715f:c65c845d:5afe47ed:2ca1911f
ARRAY /dev/md10 UUID=4ba59dd3:8bfe911f:5afe47ed:2ca1911f
ARRAY /dev/md11 UUID=964b8933:82fed079:5afe47ed:2ca1911f
This file was auto-generated on Sat, 05 Nov 2011 09:49:40 +0100
by mkconf 3.1.4-1+8efb9d1
ARRAY /dev/md/11_0 level=raid1 num-devices=2 metadata=0.90 UUID=964b8933:82fed079:5afe47ed:2ca1911f
devices=/dev/sdb11,/dev/sdc11
ARRAY /dev/md/10_0 level=raid1 num-devices=2 metadata=0.90 UUID=4ba59dd3:8bfe911f:5afe47ed:2ca1911f
devices=/dev/sdb10,/dev/sdc10
ARRAY /dev/md/9_0 level=raid1 num-devices=2 metadata=0.90 UUID=9616715f:c65c845d:5afe47ed:2ca1911f
devices=/dev/sdb9,/dev/sdc9
ARRAY /dev/md/8_0 level=raid1 num-devices=2 metadata=0.90 UUID=2c316359:11262143:5afe47ed:2ca1911f
devices=/dev/sdb8,/dev/sdc8
ARRAY /dev/md/7_0 level=raid1 num-devices=2 metadata=0.90 UUID=21d5cec2:85ed9b31:5afe47ed:2ca1911f
devices=/dev/sdb7,/dev/sdc7
ARRAY /dev/md/123_0 level=raid1 num-devices=2 metadata=0.90 UUID=a41b88b9:6dfd23d3:5afe47ed:2ca1911f
devices=/dev/sdb6,/dev/sdc6
ARRAY /dev/md/122_0 level=raid1 num-devices=2 metadata=0.90 UUID=c3f71c1f:82b5efb3:5afe47ed:2ca1911f
devices=/dev/sdb5,/dev/sdc5
ARRAY /dev/md/127_0 level=raid1 num-devices=2 metadata=0.90 UUID=964b8933:82fed079:5afe47ed:2ca1911f
ARRAY /dev/md/126_0 level=raid1 num-devices=2 metadata=0.90 UUID=4ba59dd3:8bfe911f:5afe47ed:2ca1911f
ARRAY /dev/md/125_0 level=raid1 num-devices=2 metadata=0.90 UUID=9616715f:c65c845d:5afe47ed:2ca1911f
ARRAY /dev/md/124_0 level=raid1 num-devices=2 metadata=0.90 UUID=21d5cec2:85ed9b31:5afe47ed:2ca1911f
ARRAY /dev/md5 level=raid1 num-devices=2 metadata=0.90 UUID=c3f71c1f:82b5efb3:5afe47ed:2ca1911f
ARRAY /dev/md6 level=raid1 num-devices=2 metadata=0.90 UUID=a41b88b9:6dfd23d3:5afe47ed:2ca1911f
ARRAY /dev/md7 level=raid1 num-devices=2 metadata=0.90 UUID=21d5cec2:85ed9b31:5afe47ed:2ca1911f
ARRAY /dev/md9 level=raid1 num-devices=2 metadata=0.90 UUID=9616715f:c65c845d:5afe47ed:2ca1911f
ARRAY /dev/md10 level=raid1 num-devices=2 metadata=0.90 UUID=4ba59dd3:8bfe911f:5afe47ed:2ca1911f
ARRAY /dev/md11 level=raid1 num-devices=2 metadata=0.90 UUID=964b8933:82fed079:5afe47ed:2ca1911f
devices=/dev/sdb11,/dev/sdc11[/code]
Et le détail complet de
[code]root@Hestia:~# mdadm --examine /dev/sda5
/dev/sda5:
Magic : a92b4efc
Version : 1.2
Feature Map : 0x0
Array UUID : 16a01ab1:233c5ee7:afe442ef:df8480c0
Creation Time : Sat Dec 10 12:08:39 2011
Raid Level : raid1
Raid Devices : 2
Avail Dev Size : 614408192 (292.97 GiB 314.58 GB)
Array Size : 614403478 (292.97 GiB 314.57 GB)
Used Dev Size : 614403478 (292.97 GiB 314.57 GB)
Data Offset : 2048 sectors
Super Offset : 8 sectors
State : active
Device UUID : 7776b0cc:8a5c5357:69e12a82:8248b039
Update Time : Sat Dec 10 13:12:43 2011
Checksum : 538300e7 - correct
Events : 7
Device Role : Active device 0
Array State : AA (‘A’ == active, ‘.’ == missing)
root@Hestia:~# mdadm --examine /dev/sda6
/dev/sda6:
Magic : a92b4efc
Version : 1.2
Feature Map : 0x0
Array UUID : cefe9fe7:93005f73:02e83a98:920dc528
Creation Time : Sat Dec 10 12:10:10 2011
Raid Level : raid1
Raid Devices : 2
Avail Dev Size : 122871808 (58.59 GiB 62.91 GB)
Array Size : 122871664 (58.59 GiB 62.91 GB)
Used Dev Size : 122871664 (58.59 GiB 62.91 GB)
State : active
Device UUID : 5f5bc13f:7899239c:76ba1c99:ed9b2503
Update Time : Sat Dec 10 12:10:10 2011
Checksum : 8485dc25 - correct
Events : 0
root@Hestia:~# mdadm --examine /dev/sda7
/dev/sda7:
Magic : a92b4efc
Version : 1.2
Feature Map : 0x0
Array UUID : b85a67b0:a52fdb3b:1d261c75:561ee1a0
Creation Time : Sat Dec 10 12:10:28 2011
Raid Level : raid1
Raid Devices : 2
Array Size : 614403542 (292.97 GiB 314.57 GB)
Used Dev Size : 614403542 (292.97 GiB 314.57 GB)
State : active
Device UUID : c1586084:b45260e2:ce94a3f2:b4d72aa4
Update Time : Sat Dec 10 12:10:28 2011
Checksum : 2ac6f249 - correct
Events : 0
root@Hestia:~# mdadm --examine /dev/sda8
/dev/sda8:
Magic : a92b4efc
Version : 1.2
Feature Map : 0x0
Array UUID : ae9ad314:3836e062:f7ca1abd:df705bae
Creation Time : Sat Dec 10 12:10:54 2011
Raid Level : raid1
Raid Devices : 2
State : active
Device UUID : 70ec8968:096a5bdf:f8bbcdd3:fcf80dcf
Update Time : Sat Dec 10 12:10:54 2011
Checksum : be4ab678 - correct
Events : 0
root@Hestia:~# mdadm --examine /dev/sda9
/dev/sda9:
Magic : a92b4efc
Version : 1.2
Feature Map : 0x0
Array UUID : ea61cf48:4008889f:af0f9619:24f4d487
Creation Time : Sat Dec 10 12:11:14 2011
Raid Level : raid1
Raid Devices : 2
Avail Dev Size : 102404096 (48.83 GiB 52.43 GB)
Array Size : 102396054 (48.83 GiB 52.43 GB)
Used Dev Size : 102396054 (48.83 GiB 52.43 GB)
State : active
Device UUID : 9e228a79:83bf0b3e:b3382824:eef9495e
Update Time : Sat Dec 10 12:11:14 2011
Checksum : b1b9635a - correct
Events : 0
root@Hestia:~# mdadm --examine /dev/sda10
/dev/sda10:
Magic : a92b4efc
Version : 1.2
Feature Map : 0x0
Array UUID : b2bdf45f:5315736a:4cff324e:0ade2acd
Creation Time : Sat Dec 10 12:11:31 2011
Raid Level : raid1
Raid Devices : 2
State : active
Device UUID : b088139b:5a9e6bf2:6873d36e:ce8f505a
Update Time : Sat Dec 10 12:11:31 2011
Checksum : 6790e09a - correct
Events : 0
root@Hestia:~# mdadm --examine /dev/sda11
/dev/sda11:
Magic : a92b4efc
Version : 1.2
Feature Map : 0x0
Array UUID : 4853e4be:be67877e:69ec8676:2bb7688d
Creation Time : Sat Dec 10 12:11:51 2011
Raid Level : raid1
Raid Devices : 2
Avail Dev Size : 738873344 (352.32 GiB 378.30 GB)
Array Size : 738873072 (352.32 GiB 378.30 GB)
Used Dev Size : 738873072 (352.32 GiB 378.30 GB)
State : active
Device UUID : 001864a3:bc0463e7:5508fe57:77e99be0
Update Time : Sat Dec 10 12:11:51 2011
Checksum : 3ebbe464 - correct
Events : 0
root@Hestia:~# mdadm --examine /dev/sdc5
/dev/sdc5:
Magic : a92b4efc
Version : 1.2
Feature Map : 0x0
Raid Level : raid1
Raid Devices : 2
State : active
Device UUID : 48d13773:05e8be9d:1a5bfa9d:62626660
Checksum : 82fb7ac5 - correct
Events : 7
Device Role : Active device 1
root@Hestia:~# mdadm --examine /dev/sdc6
/dev/sdc6:
Magic : a92b4efc
Version : 1.2
Feature Map : 0x0
Raid Level : raid1
Raid Devices : 2
State : active
Device UUID : 429cbb33:76e6c650:7d2bcbb8:dd74dc22
Checksum : 6c88b3fe - correct
Events : 0
root@Hestia:~# mdadm --examine /dev/sdc7
/dev/sdc7:
Magic : a92b4efc
Version : 1.2
Feature Map : 0x0
Raid Level : raid1
Raid Devices : 2
State : active
Device UUID : 5649c0dc:586e5597:347c78ea:f8fc732c
Checksum : b83a0b2c - correct
Events : 0
root@Hestia:~# mdadm --examine /dev/sdc8
/dev/sdc8:
Magic : a92b4efc
Version : 1.2
Feature Map : 0x0
Raid Level : raid1
Raid Devices : 2
State : active
Device UUID : 1ee9a381:8ec201bd:a329cde9:a253ea24
Checksum : 20e6d3fd - correct
Events : 0
root@Hestia:~# mdadm --examine /dev/sdc9
/dev/sdc9:
Magic : a92b4efc
Version : 1.2
Feature Map : 0x0
Raid Level : raid1
Raid Devices : 2
State : active
Device UUID : 1591f2dd:28b79a22:f41af516:811474c7
Checksum : 56a7c64c - correct
Events : 0
root@Hestia:~# mdadm --examine /dev/sdc10
/dev/sdc10:
Magic : a92b4efc
Version : 1.2
Feature Map : 0x0
Raid Level : raid1
Raid Devices : 2
State : active
Device UUID : ee3935ef:d78656c9:a854ef75:75b4b1cb
Checksum : b1a803e - correct
Events : 0
root@Hestia:~# mdadm --examine /dev/sdc11
/dev/sdc11:
Magic : a92b4efc
Version : 1.2
Feature Map : 0x0
Raid Level : raid1
Raid Devices : 2
Avail Dev Size : 738895872 (352.33 GiB 378.31 GB)
State : active
Device UUID : 5985d2df:7c2a00d0:a31d9ae2:f16ef6c7
Checksum : d5be6a46 - correct
Events : 0
root@Hestia:~# mdadm --examine /dev/sdd5
/dev/sdd5:
Magic : a92b4efc
Version : 1.2
Feature Map : 0x0
Name : Hestia:5 (local to host Hestia)
Raid Level : raid1
Raid Devices : 2
Avail Dev Size : 614403751 (292.97 GiB 314.57 GB)
State : active
Device UUID : b0f71f39:bd768d38:4f3bd248:023fceda
Update Time : Sat Dec 10 12:17:16 2011
Checksum : 183da67a - correct
Events : 3
Device Role : spare
root@Hestia:~# mdadm --examine /dev/sdd6
/dev/sdd6:
Magic : a92b4efc
Version : 1.2
Feature Map : 0x0
Name : Hestia:6 (local to host Hestia)
Raid Level : raid1
Raid Devices : 2
Avail Dev Size : 122879074 (58.59 GiB 62.91 GB)
State : active
Device UUID : 2e7094d3:dec1c59a:8657115f:5b47ec3d
Checksum : 279d3d19 - correct
Events : 0
Device Role : spare
root@Hestia:~# mdadm --examine /dev/sdd7
/dev/sdd7:
Magic : a92b4efc
Version : 1.2
Feature Map : 0x0
Name : Hestia:7 (local to host Hestia)
Raid Level : raid1
Raid Devices : 2
Avail Dev Size : 614403814 (292.97 GiB 314.57 GB)
State : active
Device UUID : 680be83f:99c3e3ea:9b96e1eb:39d1b741
Checksum : 9683bdea - correct
Events : 0
Device Role : spare
root@Hestia:~# mdadm --examine /dev/sdd8
/dev/sdd8:
Magic : a92b4efc
Version : 1.2
Feature Map : 0x0
Name : Hestia:8 (local to host Hestia)
Raid Level : raid1
Raid Devices : 2
State : active
Device UUID : 94d8a35b:8c92137c:5abc9a39:9da6fc99
Checksum : 90bf5261 - correct
Events : 0
Device Role : spare
root@Hestia:~# mdadm --examine /dev/sdd9
/dev/sdd9:
Magic : a92b4efc
Version : 1.2
Feature Map : 0x0
Name : Hestia:9 (local to host Hestia)
Raid Level : raid1
Raid Devices : 2
Avail Dev Size : 102396199 (48.83 GiB 52.43 GB)
State : active
Device UUID : fba480b6:45797a43:2732a843:6efc6ca3
Checksum : 6ba83873 - correct
Events : 0
Device Role : spare
root@Hestia:~# mdadm --examine /dev/sdd10
/dev/sdd10:
Magic : a92b4efc
Version : 1.2
Feature Map : 0x0
Name : Hestia:10 (local to host Hestia)
Raid Level : raid1
Raid Devices : 2
State : active
Device UUID : c006c1b7:aa3c887d:0fdd037d:a682a85f
Checksum : 2d9a0c6d - correct
Events : 0
Device Role : spare
root@Hestia:~# mdadm --examine /dev/sdd11
/dev/sdd11:
Magic : a92b4efc
Version : 1.2
Feature Map : 0x0
Name : Hestia:11 (local to host Hestia)
Raid Level : raid1
Raid Devices : 2
Avail Dev Size : 738891499 (352.33 GiB 378.31 GB)
State : active
Device UUID : 67d1f113:d2ace242:34f489de:d334e022
Checksum : de4f8814 - correct
Events : 0
Device Role : spare
Array State : AA (‘A’ == active, ‘.’ == missing)[/code]
Heu comprend pas tout, mais visiblement, c’est "active"
Mais les données sont-elles toujours là ? (Je ne sais pas trop ce qui c’est passé?? Et Avail Dev Size : 738891499 (352.33 GiB 378.31 GB)
ça signifie quoi ? La partition fait 352 Go, elle est libre de 352 Go ?)
Comment acceder à la grappe RAID ? Avec le nom, mais 'hestia':5, je me base sur quoi ?
Merci pour les tuyaux ?
Bonne soirée.
