desole pour la quantitem je suis encore en querty
ici le grub sous /boot /dev/sda1 je reviens depuis une autre machine
la copie est incomplete le terminal manque de lignes
END /etc/grub.d/05_debian_theme
BEGIN /etc/grub.d/06_mint_theme
set menu_color_normal=white/black
set menu_color_highlight=white/light-gray
END /etc/grub.d/06_mint_theme
BEGIN /etc/grub.d/10_linux
function gfxmode {
set gfxpayload="$1"
if [ “$1” = “keep” ]; then
set vt_handoff=vt.handoff=7
else
set vt_handoff=
fi
if [ ${recordfail} != 1 ]; then
if [ -e ${prefix}/gfxblacklist.txt ]; then
if hwmatch ${prefix}/gfxblacklist.txt 3; then
if [ ${match} = 0 ]; then
set linux_gfx_mode=keep
else
set linux_gfx_mode=text
fi
else
fi
else
fi
else
fi
export linux_gfx_mode
if [ “$linux_gfx_mode” != “text” ]; then load_video; fi
menuentry ‘Linux Mint 17.1 Cinnamon 32-bit, 3.13.0-37-generic (/dev/sda1)’ --class ubuntu --class gnu-linux --class gnu --class os {
recordfail
gfxmode $linux_gfx_mode
insmod gzio
insmod part_msdos
insmod ext2
set root=‘hd0,msdos1’
if [ x$feature_platform_search_hint = xy ]; then
search --no-floppy --fs-uuid --set=root --hint-bios=hd0,msdos1 --hint-efi=hd0,msdos1 --hint-baremetal=ahci0,msdos1 --hint=‘hd0,msdos1’ d68505b8-cea5-4b12-8261-b0def2b2233c
else
search --no-floppy --fs-uuid --set=root d68505b8-cea5-4b12-8261-b0def2b2233c
fi
linux /vmlinuz-3.13.0-37-generic root=UUID=cd925568-cf63-4952-bc90-216c1b34bf0c ro quiet splash $vt_handoff
initrd /initrd.img-3.13.0-37-generic
menuentry ‘Linux Mint 17.1 Cinnamon 32-bit, 3.13.0-37-generic (/dev/sda1) – recovery mode’ --class ubuntu --class gnu-linux --class gnu --class os {
recordfail
insmod gzio
insmod part_msdos
insmod ext2
else
fi
echo ‘Chargement de Linux 3.13.0-37-generic…’
linux /vmlinuz-3.13.0-37-generic root=UUID=cd925568-cf63-4952-bc90-216c1b34bf0c ro recovery nomodeset
echo ‘Chargement du disque mémoire initial…’
submenu “Previous Linux versions” {
menuentry ‘Linux Mint 17.1 Cinnamon 32-bit, 3.2.0-4-686-pae (/dev/sda1)’ --class ubuntu --class gnu-linux --class gnu --class os {
recordfail
insmod gzio
insmod part_msdos
insmod ext2
else
fi
linux /vmlinuz-3.2.0-4-686-pae root=UUID=cd925568-cf63-4952-bc90-216c1b34bf0c ro quiet splash $vt_handoff
initrd /initrd.img-3.2.0-4-686-pae
menuentry ‘Linux Mint 17.1 Cinnamon 32-bit, 3.2.0-4-686-pae (/dev/sda1) – recovery mode’ --class ubuntu --class gnu-linux --class gnu --class os {
recordfail
insmod gzio
insmod part_msdos
insmod ext2
else
fi
echo ‘Chargement de Linux 3.2.0-4-686-pae…’
linux /vmlinuz-3.2.0-4-686-pae root=UUID=cd925568-cf63-4952-bc90-216c1b34bf0c ro recovery nomodeset
END /etc/grub.d/10_linux
BEGIN /etc/grub.d/10_lupin
END /etc/grub.d/10_lupin
BEGIN /etc/grub.d/20_linux_xen
END /etc/grub.d/20_linux_xen
BEGIN /etc/grub.d/20_memtest86+
menuentry ‘Memory test (memtest86+)’ {
insmod part_msdos
insmod ext2
else
fi
knetbsd /memtest86+.elf
menuentry ‘Memory test (memtest86+, serial console 115200)’ {
insmod part_msdos
insmod ext2
else
fi
linux16 /memtest86+.bin console=ttyS0,115200n8
END /etc/grub.d/20_memtest86+
BEGIN /etc/grub.d/30_os-prober
menuentry ‘Debian GNU/Linux (7.
(sur /dev/sda7)’ --class gnu-linux --class gnu --class os $menuentry_id_option ‘osprober-gnulinux-simple-e1854469-6997-4955-abe5-2876735c0335’ {
insmod part_msdos
insmod ext2
else
fi
submenu ‘Options avancées pour Debian GNU/Linux (7.
(sur /dev/sda7)’ $menuentry_id_option ‘osprober-gnulinux-advanced-e1854469-6997-4955-abe5-2876735c0335’ {
menuentry ‘Linux Mint 17.1 Cinnamon 32-bit, 3.13.0-37-generic (/dev/sda1) (sur /dev/sda7)’ --class gnu-linux --class gnu --class os $menuentry_id_option ‘osprober-gnulinux-/vmlinuz-3.13.0-37-generic–e1854469-6997-4955-abe5-2876735c0335’ {
insmod part_msdos
insmod ext2
else
fi
menuentry ‘Linux Mint 17.1 Cinnamon 32-bit, 3.13.0-37-generic (/dev/sda1) – recovery mode (sur /dev/sda7)’ --class gnu-linux --class gnu --class os $menuentry_id_option ‘osprober-gnulinux-/vmlinuz-3.13.0-37-generic-root=UUID=cd925568-cf63-4952-bc90-216c1b34bf0c ro recovery nomodeset-e1854469-6997-4955-abe5-2876735c0335’ {
insmod part_msdos
insmod ext2
else
fi
menuentry ‘Linux Mint 17.1 Cinnamon 32-bit, 3.2.0-4-686-pae (/dev/sda1) (sur /dev/sda7)’ --class gnu-linux --class gnu --class os $menuentry_id_option ‘osprober-gnulinux-/vmlinuz-3.2.0-4-686-pae–e1854469-6997-4955-abe5-2876735c0335’ {
insmod part_msdos
insmod ext2
else
fi
menuentry ‘Linux Mint 17.1 Cinnamon 32-bit, 3.2.0-4-686-pae (/dev/sda1) – recovery mode (sur /dev/sda7)’ --class gnu-linux --class gnu --class os $menuentry_id_option ‘osprober-gnulinux-/vmlinuz-3.2.0-4-686-pae-root=UUID=cd925568-cf63-4952-bc90-216c1b34bf0c ro recovery nomodeset-e1854469-6997-4955-abe5-2876735c0335’ {
insmod part_msdos
insmod ext2
else
fi
(sur /dev/sda7) (sur /dev/sda7)’ --class gnu-linux --class gnu --class os $menuentry_id_option ‘osprober-gnulinux-/vmlinuz-3.13.0-37-generic–e1854469-6997-4955-abe5-2876735c0335’ {
insmod part_msdos
insmod ext2
else
fi
menuentry ‘Linux Mint 17.1 Cinnamon 32-bit, 3.13.0-37-generic (/dev/sda1) (sur /dev/sda7) (sur /dev/sda7)’ --class gnu-linux --class gnu --class os $menuentry_id_option ‘osprober-gnulinux-/vmlinuz-3.13.0-37-generic–e1854469-6997-4955-abe5-2876735c0335’ {
insmod part_msdos
insmod ext2
else
fi
menuentry ‘Linux Mint 17.1 Cinnamon 32-bit, 3.13.0-37-generic (/dev/sda1) – recovery mode (sur /dev/sda7) (sur /dev/sda7)’ --class gnu-linux --class gnu --class os $menuentry_id_option ‘osprober-gnulinux-/vmlinuz-3.13.0-37-generic-root=UUID=cd925568-cf63-4952-bc90-216c1b34bf0c ro recovery nomodeset-e1854469-6997-4955-abe5-2876735c0335’ {
insmod part_msdos
insmod ext2
else
fi
menuentry ‘Linux Mint 17.1 Cinnamon 32-bit, 3.2.0-4-686-pae (/dev/sda1) (sur /dev/sda7) (sur /dev/sda7)’ --class gnu-linux --class gnu --class os $menuentry_id_option ‘osprober-gnulinux-/vmlinuz-3.2.0-4-686-pae–e1854469-6997-4955-abe5-2876735c0335’ {
insmod part_msdos
insmod ext2
else
fi
menuentry ‘Linux Mint 17.1 Cinnamon 32-bit, 3.2.0-4-686-pae (/dev/sda1) – recovery mode (sur /dev/sda7) (sur /dev/sda7)’ --class gnu-linux --class gnu --class os $menuentry_id_option ‘osprober-gnulinux-/vmlinuz-3.2.0-4-686-pae-root=UUID=cd925568-cf63-4952-bc90-216c1b34bf0c ro recovery nomodeset-e1854469-6997-4955-abe5-2876735c0335’ {
insmod part_msdos
insmod ext2
else
fi
(sur /dev/sda7) (sur /dev/sda7) (sur /dev/sda7)’ --class gnu-linux --class gnu --class os $menuentry_id_option ‘osprober-gnulinux-/vmlinuz-3.13.0-37-generic–e1854469-6997-4955-abe5-2876735c0335’ {
insmod part_msdos
insmod ext2
else
fi
menuentry ‘Linux Mint 17.1 Cinnamon 32-bit, 3.13.0-37-generic (/dev/sda1) (sur /dev/sda7) (sur /dev/sda7) (sur /dev/sda7)’ --class gnu-linux --class gnu --class os $menuentry_id_option ‘osprober-gnulinux-/vmlinuz-3.13.0-37-generic–e1854469-6997-4955-abe5-2876735c0335’ {
insmod part_msdos
insmod ext2
else
fi
menuentry ‘Linux Mint 17.1 Cinnamon 32-bit, 3.13.0-37-generic (/dev/sda1) – recovery mode (sur /dev/sda7) (sur /dev/sda7) (sur /dev/sda7)’ --class gnu-linux --class gnu --class os $menuentry_id_option ‘osprober-gnulinux-/vmlinuz-3.13.0-37-generic-root=UUID=cd925568-cf63-4952-bc90-216c1b34bf0c ro recovery nomodeset-e1854469-6997-4955-abe5-2876735c0335’ {
insmod part_msdos
insmod ext2
else
fi
menuentry ‘Linux Mint 17.1 Cinnamon 32-bit, 3.2.0-4-686-pae (/dev/sda1) (sur /dev/sda7) (sur /dev/sda7) (sur /dev/sda7)’ --class gnu-linux --class gnu --class os $menuentry_id_option ‘osprober-gnulinux-/vmlinuz-3.2.0-4-686-pae–e1854469-6997-4955-abe5-2876735c0335’ {
insmod part_msdos
insmod ext2
else
fi
menuentry ‘Linux Mint 17.1 Cinnamon 32-bit, 3.2.0-4-686-pae (/dev/sda1) – recovery mode (sur /dev/sda7) (sur /dev/sda7) (sur /dev/sda7)’ --class gnu-linux --class gnu --class os $menuentry_id_option ‘osprober-gnulinux-/vmlinuz-3.2.0-4-686-pae-root=UUID=cd925568-cf63-4952-bc90-216c1b34bf0c ro recovery nomodeset-e1854469-6997-4955-abe5-2876735c0335’ {
insmod part_msdos
insmod ext2
else
fi
menuentry ‘unknown Linux distribution (sur /dev/sda9)’ --class gnu-linux --class gnu --class os $menuentry_id_option ‘osprober-gnulinux-simple-d112886d-7116-4ec5-b6ea-0d44076c2b52’ {
insmod part_msdos
insmod ext2
set root=‘hd0,msdos9’
search --no-floppy --fs-uuid --set=root --hint-bios=hd0,msdos9 --hint-efi=hd0,msdos9 --hint-baremetal=ahci0,msdos9 --hint=‘hd0,msdos9’ d112886d-7116-4ec5-b6ea-0d44076c2b52
else
search --no-floppy --fs-uuid --set=root d112886d-7116-4ec5-b6ea-0d44076c2b52
fi
linux /boot/vmlinuz-3.2.53-slitaz root=/dev/sda9
submenu ‘Options avancées pour unknown Linux distribution (sur /dev/sda9)’ $menuentry_id_option ‘osprober-gnulinux-advanced-d112886d-7116-4ec5-b6ea-0d44076c2b52’ {
menuentry ‘SliTaz 5.0-rolling (kernel 3.2.53) (sur /dev/sda9)’ --class gnu-linux --class gnu --class os $menuentry_id_option ‘osprober-gnulinux-/boot/vmlinuz-3.2.53-slitaz–d112886d-7116-4ec5-b6ea-0d44076c2b52’ {
insmod part_msdos
insmod ext2
else
fi
set timeout_style=menu
if [ “${timeout}” = 0 ]; then
set timeout=10
fi
END /etc/grub.d/30_os-prober
BEGIN /etc/grub.d/30_uefi-firmware
END /etc/grub.d/30_uefi-firmware
BEGIN /etc/grub.d/40_custom
This file provides an easy way to add custom menu entries. Simply type the
menu entries you want to add after this comment. Be careful not to change
the ‘exec tail’ line above.
END /etc/grub.d/40_custom
BEGIN /etc/grub.d/41_custom
if [ -f ${config_directory}/custom.cfg ]; then
source ${config_directory}/custom.cfg
elif [ -z “${config_directory}” -a -f $prefix/custom.cfg ]; then
source $prefix/custom.cfg;
fi
END /etc/grub.d/41_custom
