Jai ce curieux probleme sur une fraiche installation de Lenny. Le menu GRUB se presente bien mais ne veut demarrer ni en mode normal ni la console ??
Voici mon menu.lst :
# menu.lst - See: grub(8), info grub, update-grub(8)
# grub-install(8), grub-floppy(8),
# grub-md5-crypt, /usr/share/doc/grub
# and /usr/share/doc/grub-legacy-doc/.
## default num
# Set the default entry to the entry number NUM. Numbering starts from 0, and
# the entry number 0 is the default if the command is not used.
# You can specify 'saved' instead of a number. In this case, the default entry
# is the entry saved with the command 'savedefault'.
# WARNING: If you are using dmraid do not change this entry to 'saved' or your
# array will desync and will not let you boot your system.
default 0
## timeout sec
# Set a timeout, in SEC seconds, before automatically booting the default entry
# (normally the first entry defined).
timeout 5
# Pretty colours
color cyan/blue white/blue
## password ['--md5'] passwd
# If used in the first section of a menu file, disable all interactive editing
# control (menu entry editor and command-line) and entries protected by the
# command 'lock'
# e.g. password topsecret
# password --md5 $1$gLhU0/$aW78kHK1QfV3P2b2znUoe/
# password topsecret
password --md5 $1$lJHiS/$eoYYnEeUtt1pcb4Nw.TNq.
# examples
# title Windows 95/98/NT/2000
# root (hd0,0)
# makeactive
# chainloader +1
# title Linux
# root (hd0,1)
# kernel /vmlinuz root=/dev/hda2 ro
# Put static boot stanzas before and/or after AUTOMAGIC KERNEL LIST
### BEGIN AUTOMAGIC KERNELS LIST
## lines between the AUTOMAGIC KERNELS LIST markers will be modified
## by the debian update-grub script except for the default options below
## DO NOT UNCOMMENT THEM, Just edit them to your needs
## ## Start Default Options ##
## default kernel options
## default kernel options for automagic boot options
## If you want special options for specific kernels use kopt_x_y_z
## where x.y.z is kernel version. Minor versions can be omitted.
## e.g. kopt=root=/dev/hda1 ro
## kopt_2_6_8=root=/dev/hdc1 ro
## kopt_2_6_8_2_686=root=/dev/hdc2 ro
# kopt=root=/dev/sdb2 ro
## default grub root device
## e.g. groot=(hd0,0)
# groot=(hd2,1)
## should update-grub create alternative automagic boot options
## e.g. alternative=true
## alternative=false
# alternative=true
## should update-grub lock alternative automagic boot options
## e.g. lockalternative=true
## lockalternative=false
## additional options to use with the default boot option, but not with the
## alternatives
## e.g. defoptions=vga=791 resume=/dev/hda5
# defoptions=
## should update-grub lock old automagic boot options
## e.g. lockold=false
## lockold=true
# lockold=false
## Xen hypervisor options to use with the default Xen boot option
# xenhopt=
## Xen Linux kernel options to use with the default Xen boot option
# xenkopt=console=tty0
## altoption boot targets option
## multiple altoptions lines are allowed
## e.g. altoptions=(extra menu suffix) extra boot options
## altoptions=(single-user) single
# altoptions=(single-user mode) single
## controls how many kernels should be put into the menu.lst
## only counts the first occurence of a kernel, not the
## alternative kernel options
## e.g. howmany=all
## howmany=7
# howmany=all
## should update-grub create memtest86 boot option
## e.g. memtest86=true
## memtest86=false
# memtest86=true
## should update-grub adjust the value of the default booted system
## can be true or false
# updatedefaultentry=false
## should update-grub add savedefault to the default options
# savedefault=false
## ## End Default Options ##
title Debian GNU/Linux, kernel 2.6.26-2-amd64
root (hd2,1)
kernel /boot/vmlinuz-2.6.26-2-amd64 root=/dev/sdb2 ro
initrd /boot/initrd.img-2.6.26-2-amd64
title Debian GNU/Linux, kernel 2.6.26-2-amd64 (single-user mode)
root (hd2,1)
kernel /boot/vmlinuz-2.6.26-2-amd64 root=/dev/sdb2 ro single
### END DEBIAN AUTOMAGIC KERNELS LIST
et le resultat de fdisk -l :
[code]Disk /dev/sda: 400.0 GB, 400088457216 bytes
255 heads, 63 sectors/track, 48641 cylinders
Disk identifier: 0xfa5c7e19
/dev/sda1 * 1 48641 390708801 f W95 Ext’d (LBA)
/dev/sda5 1 23498 188747622 83 Linux
/dev/sda6 23499 48640 201953083+ 83 Linux
/dev/sda7 48641 48641 8001 83 Linux
Disk /dev/sdb: 250.0 GB, 250059350016 bytes
255 heads, 63 sectors/track, 30401 cylinders
Disk identifier: 0xf96ef96e
/dev/sdb1 1 973 7815591 82 Linux swap / Solaris
/dev/sdb2 * 974 3405 19535040 83 Linux
/dev/sdb3 3406 30401 216845370 5 Extended
/dev/sdb5 3406 9484 48829536 83 Linux
/dev/sdb6 9485 30401 168015771 83 Linux
Disk /dev/sdc: 160.0 GB, 160041885696 bytes
16 heads, 63 sectors/track, 310101 cylinders
Units = cylinders of 1008 * 512 = 516096 bytes
Disk identifier: 0x79ad1202
/dev/sdc1 1 310097 156288856+ 83 Linux
Disk /dev/sdd: 1000.2 GB, 1000204886016 bytes
255 heads, 63 sectors/track, 121601 cylinders
Disk identifier: 0xe8900690
/dev/sdd1 1 121601 976760001 83 Linux
Disk /dev/sde: 2063 MB, 2063597568 bytes
16 heads, 32 sectors/track, 7872 cylinders
Units = cylinders of 512 * 512 = 262144 bytes
Disk identifier: 0x00061f72
/dev/sde1 * 1 7872 2015216 b W95 FAT32
Avec :
sda1 - vieille install de wind95 non uilisee
sda5 - documents
sda6 - music
sda7 - crypt
sdb1 - swap
sdb2 - root debian
sdb5 - databases
sdb6 - home
sdc1 - videos
Le reste, c’est du stockage externe usb.
A priori, tout a l’air normal non ? D’ou peut venir l’erreur ?
grace au live swap menu.
