Grub2, toujours bogué ?
Ça fait au moins 3 mois qu’à chaque upgrade, apt-listbugs me répond que Grub2 est bogué.
Ça me paraît long :115
Sid 64 2.6.32-4-amd64
Oui grub-pc qui est encore bien vérolé…
~/ apt-listbugs list grub-pc Reading package fields... Done Reading package status... Done Retrieving bug reports... Done Parsing Found/Fixed information... Done critical bugs of grub-pc (1.98-1 -> ) <unfixed> #570960 - grub-pc: grub2 not working on lenny and squeeze after fresh install grave bugs of grub-pc (1.98-1 -> ) <unfixed> #554790 - use /dev/disk/by-uuid (or similiar) for grub-pc/install_devices Merged with: 558312 558748 561766 564928 565210 567230 567582 574350 #564844 - grub-pc: Fonts don't show in the new graphical boot menu #550632 - grub-pc: chainload from legacy fails with bios disk error #557425 - lenny->squeeze upgrade, debconf defaults -> system unbootable Merged with: 558747 #550704 - grub-pc - Needs to handle symlinks in /dev/mapper Merged with: 552056 #547944 - grub-pc: upgrade-from-grub-legacy option to install in a given hard disk is tricky #548648 - grub-pc misdetects md RAID layout and fails to initialize #575076 - grub-update stopped working after upgrade to grub-pc_1.98-1_amd64.deb (md device) #574863 - grub-pc: grub-probe unable to find mapping for /boot on LVM with a snapshot LV #565706 - grub-pc: grub2 enters rescue mode with "fd0 cannot get C/H/S values" #550477 - grub-pc: after update-from-grub-legacy the system stopped booting #551319 - [grub] grub: crashes frequently on boot serious bugs of grub-pc (1.98-1 -> ) <unfixed> #546822 - apt-get update of grub-pc daisychained from -legacy boots into -pc #582342 - grub-pc: fails to load ramdisk on boot; system with RAID & CRYPTO; tested initramfs-tools under bug #582177 Summary: grub-pc(15 bugs)
Mais bon, je l’ai installé, et ça fonctionne, sans aucuns soucis…
~/ apt-cache policy grub-pc grub-pc: Installé : 1.98-1 Candidat : 1.98-1 Table de version : *** 1.98-1 0 500 http://ftp.fr.debian.org testing/main Packages 500 http://ftp.fr.debian.org sid/main Packages 100 /var/lib/dpkg/status 1.96+20080724-16 0 500 http://ftp.fr.debian.org lenny/main Packages
Idem, je l’ai installé directement sur la dernière sid, et migré dernièrement sur la plus vieille sid (qui a bien vécu, c’est le pc « labo » et ou il y avait grub 0.97), aucun problème non plus.
Grub toujours bogué, au point de ne pas réussir à s’installer sur une sid toute neuve et de réussir à empècher lilo de s’installer :mrgreen:
J’avais pas fait gaffe à tous ces bugs, ma sid a survécu à chaque update si ça peut te rassurer à passer le pas ^^
J’ai remarqué une résolution plus ou moins grande selon les update lors du boot (là c’est revenu “en gros” avec la derniére) mais à part ça je pourrais pas dire ce que les mises à jours ont apportés :confused:
Bon ben merci, je vais tenter demain.
N’oublie pas d’avoir un LiveCD (amd64) sous la main au cas ou… :wink:
Fait et apparemment, no problem :023
