j’essai de faire fonctionner cette webcam
LDLC OV7620+VC302
je suis sous debian etch,
debian:/home/jmarc# uname -a
Linux debian 2.6.18-6-686 #1 SMP Sun Feb 10 22:11:31 UTC 2008 i686 GNU/Linux
debian:/home/jmarc# lspci
00:00.0 Host bridge: VIA Technologies, Inc. VT82C693A/694x [Apollo PRO133x] (rev 44)
00:01.0 PCI bridge: VIA Technologies, Inc. VT82C598/694x [Apollo MVP3/Pro133x AGP]
00:07.0 ISA bridge: VIA Technologies, Inc. VT82C596 ISA [Mobile South] (rev 23)
00:07.1 IDE interface: VIA Technologies, Inc. VT82C586A/B/VT82C686/A/B/VT823x/A/C PIPC Bus Master IDE (rev 10)
00:07.2 USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev 11)00:07.3 Host bridge: VIA Technologies, Inc. VT82C596 Power Management (rev 30)
00:0c.0 Multimedia audio controller: C-Media Electronics Inc CM8738 (rev 10)
00:0e.0 Ethernet controller: VIA Technologies, Inc. VT6105 [Rhine-III] (rev 86)
00:12.0 USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev 50)00:12.1 USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev 50)00:12.2 USB Controller: VIA Technologies, Inc. USB 2.0 (rev 51)
01:00.0 VGA compatible controller: nVidia Corporation NV11 [GeForce2 MX/MX 400] (rev b2)
debian:/home/jmarc# lsusb
Bus 004 Device 004: ID 04b8:0820 Seiko Epson Corp.
Bus 004 Device 001: ID 0000:0000
Bus 003 Device 002: ID 0ac8:307b Z-Star Microelectronics Corp.
Bus 003 Device 001: ID 0000:0000
Bus 002 Device 002: ID 056a:0065 Wacom Co., Ltd
Bus 002 Device 001: ID 0000:0000
Bus 001 Device 002: ID 1241:1122 Belkin
Bus 001 Device 001: ID 0000:0000
debian:/home/jmarc# dmidecode
# dmidecode 2.8
Legacy DMI 2.0 present.
29 structures occupying 797 bytes.
Table at 0x000F0800.
Handle 0x0000, DMI type 0, 18 bytes
BIOS Information
Vendor: Award Software International, Inc.
Version: 4.51 PG
Release Date: 01/01/00
Address: 0xE0000
Runtime Size: 128 kB
ROM Size: 256 kB
Characteristics:
ISA is supported
PCI is supported
PNP is supported
APM is supported
BIOS is upgradeable
BIOS shadowing is allowed
ESCD support is available
Boot from CD is supported
Selectable boot is supported
BIOS ROM is socketed
EDD is supported
5.25"/360 KB floppy services are supported (int 13h)
5.25"/1.2 MB floppy services are supported (int 13h)
3.5"/720 KB floppy services are supported (int 13h)
3.5"/2.88 MB floppy services are supported (int 13h)
Print screen service is supported (int 5h)
8042 keyboard services are supported (int 9h)
Serial services are supported (int 14h)
Printer services are supported (int 17h)
CGA/mono video services are supported (int 10h)
Handle 0x0001, DMI type 1, 8 bytes
System Information
Manufacturer: MICRO-STAR INTERNATIONAL CO., LTD
Product Name: MS-6153
Version: 2.X
Serial Number:
Handle 0x0002, DMI type 2, 8 bytes
Base Board Information
Product Name: MS-6153 (VT693)
Version: 2.X
Serial Number:
Handle 0x0003, DMI type 3, 9 bytes
Chassis Information
Manufacturer:
Type: Unknown
Lock: Not Present
Version:
Serial Number:
Asset Tag:
Handle 0x0004, DMI type 4, 26 bytes
Processor Information
Socket Designation: Slot 1
Type: Central Processor
Family: Pentium II
Manufacturer: Intel
ID: 8A 06 00 00 FF F9 87 03
Signature: Type 0, Family 6, Model 8, Stepping 10
Flags:
FPU (Floating-point unit on-chip)
VME (Virtual mode extension)
DE (Debugging extension)
PSE (Page size extension)
TSC (Time stamp counter)
MSR (Model specific registers)
PAE (Physical address extension)
MCE (Machine check exception)
CX8 (CMPXCHG8 instruction supported)
SEP (Fast system call)
MTRR (Memory type range registers)
PGE (Page global enable)
MCA (Machine check architecture)
CMOV (Conditional move instruction supported)
PAT (Page attribute table)
PSE-36 (36-bit page size extension)
PSN (Processor serial number present and enabled)
MMX (MMX technology supported)
FXSR (Fast floating-point save and restore)
SSE (Streaming SIMD extensions)
Version: Pentium III
Voltage: 3.3 V
External Clock: 100 MHz
Max Speed: 500 MHz
Current Speed: 1000 MHz
Status: Populated, Enabled
Upgrade: Slot 1
Handle 0x0005, DMI type 5, 21 bytes
Memory Controller Information
Error Detecting Method: None
Error Correcting Capabilities:
Single-bit Error Correcting
Supported Interleave: Four-way Interleave
Current Interleave: One-way Interleave
Maximum Memory Module Size: 256 MB
Maximum Total Memory Size: 768 MB
Supported Speeds:
70 ns
60 ns
Supported Memory Types:
Other
Unknown
Standard
FPM
EDO
Parity
ECC
SIMM
DIMM
SDRAM
Memory Module Voltage: 3.3 V
Associated Memory Slots: 3
0x0006
0x0007
0x0008
Handle 0x0006, DMI type 6, 12 bytes
Memory Module Information
Socket Designation: BANK_0
Bank Connections: 0 1
Current Speed: 70 ns
Type: DIMM SDRAM
Installed Size: 128 MB (Single-bank Connection)
Enabled Size: 128 MB (Single-bank Connection)
Error Status: OK
Handle 0x0007, DMI type 6, 12 bytes
Socket Designation: BANK_1
Bank Connections: 2 3
Type: DIMM SDRAM
Installed Size: 256 MB (Single-bank Connection)
Enabled Size: 256 MB (Single-bank Connection)
Error Status: OK
Handle 0x0008, DMI type 6, 12 bytes
Socket Designation: BANK_2
Bank Connections: 4 5
Type: DIMM SDRAM
Error Status: OK
Handle 0x0009, DMI type 7, 15 bytes
Cache Information
Socket Designation: Internal Cache
Configuration: Enabled, Not Socketed, Level 1
Operational Mode: Write Back
Installed Size: 32 KB
Maximum Size: 32 KB
Supported SRAM Types:
Synchronous
Installed SRAM Type: Synchronous
Handle 0x000A, DMI type 7, 15 bytes
Cache Information
Socket Designation: External Cache
Configuration: Enabled, Not Socketed, Level 2
Installed Size: 256 KB
Maximum Size: 2048 KB
Pipeline Burst
Synchronous
Installed SRAM Type: Pipeline Burst Synchronous
Handle 0x000B, DMI type 8, 9 bytes
Port Connector Information
Internal Reference Designator: PRIMARY IDE
Internal Connector Type: On Board IDE
External Reference Designator:
External Connector Type: None
Port Type: Other
Handle 0x000C, DMI type 8, 9 bytes
Internal Reference Designator: SECONDARY IDE
Port Type: Other
Handle 0x000D, DMI type 8, 9 bytes
Internal Reference Designator: FDD
Internal Connector Type: On Board Floppy
Port Type: 8251 FIFO Compatible
Handle 0x000E, DMI type 8, 9 bytes
Internal Reference Designator: COM1
Internal Connector Type: 9 Pin Dual Inline (pin 10 cut)
External Connector Type: DB-9 male
Port Type: Serial Port 16450 Compatible
Handle 0x000F, DMI type 8, 9 bytes
Internal Reference Designator: COM2
Handle 0x0010, DMI type 8, 9 bytes
Internal Reference Designator: LPT1
Internal Connector Type: DB-25 female
External Connector Type: DB-25 female
Port Type: Parallel Port ECP/EPP
Handle 0x0011, DMI type 8, 9 bytes
Internal Reference Designator: Keyboard
Internal Connector Type: Other
External Connector Type: PS/2
Port Type: Keyboard Port
Handle 0x0012, DMI type 8, 9 bytes
Internal Reference Designator: PS/2 Mouse
Internal Connector Type: PS/2
External Reference Designator: No Detected
Port Type: Mouse Port
Handle 0x0013, DMI type 9, 12 bytes
System Slot Information
Designation: ISA
Type: 16-bit ISA
Current Usage: Unknown
Length: Long
Characteristics:
5.0 V is provided
Handle 0x0014, DMI type 9, 12 bytes
Designation: ISA
Type: 16-bit ISA
Length: Long
Characteristics:
5.0 V is provided
Handle 0x0015, DMI type 9, 12 bytes
Designation: PCI
Type: 32-bit PCI
Current Usage: Available
Length: Long
Characteristics:
5.0 V is provided
Handle 0x0016, DMI type 9, 12 bytes
Designation: PCI
Type: 32-bit PCI
Current Usage: In Use
Length: Long
Characteristics:
5.0 V is provided
Handle 0x0017, DMI type 9, 12 bytes
Designation: PCI
Type: 32-bit PCI
Length: Long
Characteristics:
5.0 V is provided
Handle 0x0018, DMI type 9, 12 bytes
Designation: PCI
Type: 32-bit PCI
Length: Long
Characteristics:
5.0 V is provided
Handle 0x0019, DMI type 9, 12 bytes
Designation: PCI
Type: 32-bit PCI
Length: Long
Characteristics:
5.0 V is provided
Handle 0x001A, DMI type 9, 12 bytes
Designation: AGP
Type: 32-bit AGP
Length: Long
Characteristics:
5.0 V is provided
Handle 0x001B, DMI type 8, 9 bytes
Internal Reference Designator: USB
Internal Connector Type: None
External Connector Type: Other
Port Type: USB
Handle 0x001C, DMI type 13, 22 bytes
BIOS Language Information
Installable Languages: 3
n|US|iso8859-1
r|CA|iso8859-1
a|JP|unicode
Currently Installed Language: n|US|iso8859-1
debian:/home/jmarc# dmesg /var/log/messages
Linux version 2.6.18-6-686 (Debian 2.6.18.dfsg.1-18etch1) (waldi@debian.org) (gcc version 4.1.2 20061115 (prerelease) (Debian 4.1.1-21)) #1 SMP Sun Feb 10 22:11:31 UTC 2008
BIOS-provided physical RAM map:
BIOS-e820: 0000000000000000 - 00000000000a0000 (usable)
BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
BIOS-e820: 0000000000100000 - 0000000027ff0000 (usable)
BIOS-e820: 0000000027ff0000 - 0000000027ff3000 (ACPI NVS)
BIOS-e820: 0000000027ff3000 - 0000000028000000 (ACPI data)
BIOS-e820: 00000000ffff0000 - 0000000100000000 (reserved)
0MB HIGHMEM available.
639MB LOWMEM available.
On node 0 totalpages: 163824
DMA zone: 4096 pages, LIFO batch:0
Normal zone: 159728 pages, LIFO batch:31
DMI 2.0 present.
ACPI: RSDP (v000 MSISYS ) @ 0x000f6ed0
ACPI: RSDT (v001 MSISYS MS-6153W 0x30302e31 AWRD 0x00000000) @ 0x27ff3000
ACPI: FADT (v001 MSISYS MS-6153W 0x30302e31 AWRD 0x00000000) @ 0x27ff3040
ACPI: DSDT (v001 VIA692 MS-6153W 0x00001000 MSFT 0x01000007) @ 0x00000000
ACPI: PM-Timer IO Port: 0x4008
Allocating PCI resources starting at 30000000 (gap: 28000000:d7ff0000)
Detected 1002.292 MHz processor.
Built 1 zonelists. Total pages: 163824
Kernel command line: root=/dev/mapper/debian-root ro
Local APIC disabled by BIOS -- you can enable it with "lapic"
mapped APIC to ffffd000 (0150c000)
Enabling fast FPU save and restore... done.
Enabling unmasked SIMD FPU exception support... done.
Initializing CPU#0
PID hash table entries: 4096 (order: 12, 16384 bytes)
Console: colour VGA+ 80x25
Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Memory: 641208k/655296k available (1541k kernel code, 13508k reserved, 580k data, 196k init, 0k highmem)
Checking if this processor honours the WP bit even in supervisor mode... Ok.
Calibrating delay using timer specific routine.. 2006.63 BogoMIPS (lpj=4013276)
Security Framework v1.0.0 initialized
SELinux: Disabled at boot.
Capability LSM initialized
Mount-cache hash table entries: 512
CPU: After generic identify, caps: 0387f9ff 00000000 00000000 00000000 00000000 00000000 00000000
CPU: After vendor identify, caps: 0387f9ff 00000000 00000000 00000000 00000000 00000000 00000000
CPU: L1 I cache: 16K, L1 D cache: 16K
CPU: L2 cache: 256K
CPU serial number disabled.
CPU: After all inits, caps: 0383f9ff 00000000 00000000 00000040 00000000 00000000 00000000
Intel machine check architecture supported.
Intel machine check reporting enabled on CPU#0.
Compat vDSO mapped to ffffe000.
Checking 'hlt' instruction... OK.
SMP alternatives: switching to UP code
Freeing SMP alternatives: 12k freed
ACPI: Core revision 20060707
ACPI: setting ELCR to 0200 (from 1e20)
CPU0: Intel Pentium III (Coppermine) stepping 0a
SMP motherboard not detected.
Local APIC not detected. Using dummy APIC emulation.
Brought up 1 CPUs
migration_cost=0
checking if image is initramfs... it is
Freeing initrd memory: 4907k freed
NET: Registered protocol family 16
ACPI: bus type pci registered
PCI: PCI BIOS revision 2.10 entry at 0xfb0e0, last bus=1
PCI: Using configuration type 1
Setting up standard PCI resources
ACPI: Interpreter enabled
ACPI: Using PIC for interrupt routing
ACPI: PCI Root Bridge [PCI0] (0000:00)
PCI: Probing PCI hardware (bus 00)
ACPI: Assume root bridge [\_SB_.PCI0] bus is 0
Boot video device is 0000:01:00.0
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
ACPI: PCI Interrupt Link [LNKA] (IRQs 1 3 4 5 6 7 10 *11 12 14 15)
ACPI: PCI Interrupt Link [LNKB] (IRQs 1 3 4 5 6 7 10 11 *12 14 15)
ACPI: PCI Interrupt Link [LNKC] (IRQs 1 3 4 *5 6 7 10 11 12 14 15)
ACPI: PCI Interrupt Link [LNKD] (IRQs 1 3 4 5 6 7 *10 11 12 14 15)
Linux Plug and Play Support v0.97 (c) Adam Belay
pnp: PnP ACPI init
pnp: PnP ACPI: found 12 devices
PnPBIOS: Disabled by ACPI PNP
PCI: Using ACPI for IRQ routing
PCI: If a device doesn't work, try "pci=routeirq". If it helps, post a report
PCI: Bridge: 0000:00:01.0
IO window: c000-cfff
MEM window: ec000000-edffffff
PREFETCH window: e0000000-e7ffffff
PCI: Setting latency timer of device 0000:00:01.0 to 64
NET: Registered protocol family 2
IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
TCP: Hash tables configured (established 131072 bind 65536)
TCP reno registered
audit: initializing netlink socket (disabled)
audit(1207441717.524:1): initialized
VFS: Disk quotas dquot_6.5.1
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Initializing Cryptographic API
io scheduler noop registered
io scheduler anticipatory registered
io scheduler deadline registered
io scheduler cfq registered (default)
Activating ISA DMA hang workarounds.
isapnp: Scanning for PnP cards...
isapnp: No Plug & Play device found
Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled
serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
serial8250: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
00:08: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
00:09: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
RAMDISK driver initialized: 16 RAM disks of 8192K size 1024 blocksize
PNP: PS/2 Controller [PNP0303:PS2K] at 0x60,0x64 irq 1
PNP: PS/2 controller doesn't have AUX irq; using default 12
serio: i8042 AUX port at 0x60,0x64 irq 12
serio: i8042 KBD port at 0x60,0x64 irq 1
mice: PS/2 mouse device common for all mice
TCP bic registered
NET: Registered protocol family 17
NET: Registered protocol family 8
NET: Registered protocol family 20
Using IPI No-Shortcut mode
ACPI: (supports S0 S1 S5)
Freeing unused kernel memory: 196k freed
Time: tsc clocksource has been installed.
input: AT Translated Set 2 keyboard as /class/input/input0
ACPI: Fan [FAN] (on)
ACPI: CPU0 (power states: C1[C1] C2[C2])
ACPI: Thermal Zone [THRM] (59 C)
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
VP_IDE: IDE controller at PCI slot 0000:00:07.1
PCI: VIA IRQ fixup for 0000:00:07.1, from 255 to 0
VP_IDE: chipset revision 16
VP_IDE: not 100% native mode: will probe irqs later
VP_IDE: VIA vt82c596b (rev 23) IDE UDMA66 controller on pci0000:00:07.1
ide0: BM-DMA at 0xd000-0xd007, BIOS settings: hda:DMA, hdb:DMA
ide1: BM-DMA at 0xd008-0xd00f, BIOS settings: hdc:DMA, hdd:DMA
Probing IDE interface ide0...
usbcore: registered new driver usbfs
usbcore: registered new driver hub
via-rhine.c:v1.10-LK1.4.1 July-24-2006 Written by Donald Becker
USB Universal Host Controller Interface driver v3.0
Time: acpi_pm clocksource has been installed.
hda: Maxtor 6Y120L0, ATA DISK drive
hdb: WDC WD800JB-00JJC0, ATA DISK drive
ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
Probing IDE interface ide1...
hdc: _NEC DVD_RW ND-3540A, ATAPI CD/DVD-ROM drive
hdd: LITE-ON DVD SOHD-16P9S, ATAPI CD/DVD-ROM drive
ide1 at 0x170-0x177,0x376 on irq 15
ACPI: PCI Interrupt Link [LNKC] enabled at IRQ 5
PCI: setting IRQ 5 as level-triggered
ACPI: PCI Interrupt 0000:00:0e.0[A] -> Link [LNKC] -> GSI 5 (level, low) -> IRQ 5
eth0: VIA Rhine III at 0x1dc00, 00:11:95:de:21:1f, IRQ 5.
eth0: MII PHY found at address 1, status 0x786d advertising 05e1 Link 45e1.
ACPI: PCI Interrupt Link [LNKD] enabled at IRQ 10
PCI: setting IRQ 10 as level-triggered
ACPI: PCI Interrupt 0000:00:07.2[D] -> Link [LNKD] -> GSI 10 (level, low) -> IRQ 10
uhci_hcd 0000:00:07.2: UHCI Host Controller
uhci_hcd 0000:00:07.2: new USB bus registered, assigned bus number 1
uhci_hcd 0000:00:07.2: irq 10, io base 0x0000d400
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
ACPI: PCI Interrupt Link [LNKB] enabled at IRQ 12
PCI: setting IRQ 12 as level-triggered
ACPI: PCI Interrupt 0000:00:12.0[A] -> Link [LNKB] -> GSI 12 (level, low) -> IRQ 12
uhci_hcd 0000:00:12.0: UHCI Host Controller
uhci_hcd 0000:00:12.0: new USB bus registered, assigned bus number 2
uhci_hcd 0000:00:12.0: irq 12, io base 0x0000e000
usb usb2: configuration #1 chosen from 1 choice
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 2 ports detected
ACPI: PCI Interrupt 0000:00:12.1[B] -> Link [LNKC] -> GSI 5 (level, low) -> IRQ 5
uhci_hcd 0000:00:12.1: UHCI Host Controller
uhci_hcd 0000:00:12.1: new USB bus registered, assigned bus number 3
uhci_hcd 0000:00:12.1: irq 5, io base 0x0000e400
usb usb3: configuration #1 chosen from 1 choice
hub 3-0:1.0: USB hub found
hub 3-0:1.0: 2 ports detected
ACPI: PCI Interrupt 0000:00:12.2[C] -> Link [LNKD] -> GSI 10 (level, low) -> IRQ 10
ehci_hcd 0000:00:12.2: EHCI Host Controller
ehci_hcd 0000:00:12.2: new USB bus registered, assigned bus number 4
ehci_hcd 0000:00:12.2: irq 10, io mem 0xef001000
ehci_hcd 0000:00:12.2: USB 2.0 started, EHCI 0.95, driver 10 Dec 2004
usb usb4: configuration #1 chosen from 1 choice
hub 4-0:1.0: USB hub found
hub 4-0:1.0: 4 ports detected
usb 1-1: new low speed USB device using uhci_hcd and address 2
usb 1-1: configuration #1 chosen from 1 choice
hda: max request size: 128KiB
hda: 240121728 sectors (122942 MB) w/2048KiB Cache, CHS=65535/16/63, UDMA(66)
hda: cache flushes supported
hda: hda1 hda2 < hda5 hda6 hda7 >
hdb: max request size: 128KiB
hdb: 156301488 sectors (80026 MB) w/8192KiB Cache, CHS=65535/16/63, UDMA(66)
hdb: cache flushes supported
hdb: hdb1 hdb2 < hdb5 >
hdc: ATAPI 48X DVD-ROM DVD-R CD-R/RW drive, 2048kB Cache, UDMA(33)
Uniform CD-ROM driver Revision: 3.20
hdd: ATAPI 48X DVD-ROM drive, 254kB Cache, UDMA(33)
usbcore: registered new driver hiddev
usb 2-2: new full speed USB device using uhci_hcd and address 2
usb 2-2: configuration #1 chosen from 1 choice
usb 3-1: new full speed USB device using uhci_hcd and address 2
usb 3-1: configuration #1 chosen from 1 choice
input: HID 1241:1122 as /class/input/input1
input: USB HID v1.00 Mouse [HID 1241:1122] on usb-0000:00:07.2-1
usbcore: registered new driver usbhid
drivers/usb/input/hid-core.c: v2.6:USB HID core driver
device-mapper: ioctl: 4.7.0-ioctl (2006-06-24) initialised: dm-devel@redhat.com
Attempting manual resume
kjournald starting. Commit interval 5 seconds
EXT3-fs: mounted filesystem with ordered data mode.
ts: Compaq touchscreen protocol output
pci_hotplug: PCI Hot Plug PCI Core version: 0.5
shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
Linux agpgart interface v0.101 (c) Dave Jones
agpgart: Detected VIA Apollo Pro 133 chipset
agpgart: AGP aperture is 64M @ 0xe8000000
Real Time Clock Driver v1.12ac
input: Wacom Bamboo as /class/input/input2
usbcore: registered new driver wacom
/home/jmarc/wacom/linuxwacom-0.7.9-7/src/2.6.18/wacom_sys.c: v1.46-pc0.2:USB Wacom Graphire and Wacom Intuos tablet driver
Floppy drive(s): fd0 is 1.44M
input: PC Speaker as /class/input/input3
FDC 0 is a post-1991 82077
Linux video capture interface: v2.00
/usr/src/modules/gspcav1-20071224/gspca_core.c: USB GSPCA camera found.(ZC3XX)
/usr/src/modules/gspcav1-20071224/gspca_core.c: [spca5xx_probe:4275] Camera type JPEG
/usr/src/modules/gspcav1-20071224/Vimicro/zc3xx.h: [zc3xx_config:591] Sensor OV7620
/usr/src/modules/gspcav1-20071224/gspca_core.c: [spca5xx_getcapability:1249] maxw 640 maxh 480 minw 160 minh 120
usbcore: registered new driver gspca
/usr/src/modules/gspcav1-20071224/gspca_core.c: gspca driver 01.00.20 registered
parport: PnPBIOS parport detected.
parport0: PC-style at 0x378, irq 7 [PCSPP]
ACPI: PCI Interrupt 0000:00:0c.0[A] -> Link [LNKB] -> GSI 12 (level, low) -> IRQ 12
EXT3 FS on dm-0, internal journal
loop: loaded (max 8 devices)
EXT3 FS on hdb1, internal journal
EXT3 FS on dm-2, internal journal
NTFS driver 2.1.27 [Flags: R/W MODULE].
NTFS-fs warning (device hda1): parse_options(): Option iocharset is deprecated. Please use option nls=<charsetname> in the future.
NTFS volume version 3.1.
NTFS-fs warning (device hda1): load_system_files(): Unsupported volume flags 0x4000 encountered.
NTFS-fs error (device hda1): load_system_files(): Volume has unsupported flags set. Mounting read-only. Run chkdsk and mount in Windows.
Adding 1937400k swap on /dev/mapper/debian-swap_1. Priority:-1 extents:1 across:1937400keth0: link up, 100Mbps, full-duplex, lpa 0x45E1
ACPI: Power Button (FF) [PWRF]
ACPI: Power Button (CM) [PWRB]
lp0: using parport0 (interrupt-driven).
ppdev: user-space parallel port driver
NET: Registered protocol family 5
Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
NFSD: Using /var/lib/nfs/v4recovery as the NFSv4 state recovery directory
NFSD: starting 90-second grace period
tun: Universal TUN/TAP device driver, 1.6
tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
usbcore: deregistering driver gspca
/usr/src/modules/gspcav1-20071224/gspca_core.c: driver gspca deregistered
/usr/src/modules/gspcav1-20071224/gspca_core.c: [gspca_set_isoc_ep:945] ISO EndPoint found 0x81 AlternateSet 7
/usr/src/modules/gspcav1-20071224/gspca_core.c: [spca5xx_do_ioctl:2124] Bridge ZC301-2
NTFS-fs error (device hda1): ntfs_ucstonls(): Unicode name contains characters that cannot be converted to character set iso8859-15. You might want to try to use the mount option nls=utf8.
NTFS-fs warning (device hda1): ntfs_filldir(): Skipping unrepresentable inode 0x3693.
NTFS-fs warning (device hda1): ntfs_filldir(): Skipping unrepresentable inode 0x1d6e.
NTFS-fs warning (device hda1): ntfs_filldir(): Skipping unrepresentable inode 0x27ef.
NTFS-fs warning (device hda1): ntfs_filldir(): Skipping unrepresentable inode 0x298b.
NTFS-fs warning (device hda1): ntfs_filldir(): Skipping unrepresentable inode 0x2fc5.
printk: 3 messages suppressed.
NTFS-fs warning (device hda1): ntfs_filldir(): Skipping unrepresentable inode 0x3297.
NET: Registered protocol family 4
NET: Registered protocol family 3
usb 4-1: new high speed USB device using ehci_hcd and address 4
usb 4-1: configuration #1 chosen from 1 choice
drivers/usb/class/usblp.c: usblp0: USB Bidirectional printer dev 4 if 1 alt 0 proto 2 vid 0x04B8 pid 0x0820
usbcore: registered new driver usblp
drivers/usb/class/usblp.c: v0.13: USB Printer Device Class driver
…vous savez tout ou presque,
le resultat est que
debian:/home/jmarc# spcaview -d /dev/video0 -f yuv
Spcaview version: 1.1.8 date: 25:12:2007 (C) mxhaard@magic.fr
Initializing SDL.
SDL initialized.
bpp 3 format 15
Using video device /dev/video0.
Initializing v4l.
**************** PROBING CAMERA *********************
Camera found: LDLC OV7620+VC302
Bridge found: ZC301-2
StreamId: JPEG Camera
quality 1 autoexpo 1 Timeframe 0 lightfreq 50
Available Resolutions width 640 heigth 480 native
Available Resolutions width 352 heigth 288 decoded
Available Resolutions width 320 heigth 240 native *
Available Resolutions width 176 heigth 144 decoded
unable to probe size !!
grabbing method default MMAP asked
VIDIOCGMBUF size 2457616 frames 2 offets[0]=0 offsets[1]=1228808
VIDIOCGPICT
brightnes=32768 hue=0 color=0 contrast=32768 whiteness=0
depth=12 palette=4
VIDIOCSPICT
brightness=32768 hue=0 color=0 contrast=32768 whiteness=0
depth=24 palette=15
ici le curseur reste en attente,
spcaview s'ouvre avec un ecran qui reste
desesperement noir... LDLC OV7620+VC302
meme chose avec camorama, camstream,
…un conflit? une erreur?
j’aurais besoin de vos lumieres,
merci d’avance,
cordialement,
Jmarc Dufour
