Bonjour ces 2 messages d’erreur concerne les 2 SSD de mon PC récent (octobre 2023)
The hard disk health status as changed. Thic could mean that hard drive failure is imminent. it is always a good idea to have up to date backups
This message was generated by the smartd daemon running on:
host name: Leopard
DNS domain: [spoiler]Coucy[/spoiler]
The following warning/error was logged by the smartd daemon:
Device: /dev/nvme1, number of Error Log entries increased from 2380 to 2381
Device info:
CT4000P3PSSD8, S/N:2331E86580C6, FW:P9CR40A
For details see host's SYSLOG.
You can also use the smartctl utility for further investigation.
The original message about this issue was sent at Sat May 31 09:20:03 2025 CEST
Another message will be sent in 24 hours if the problem
persists.
et le même message concernant le premier SSD:
host name: Leopard
DNS domain: Coucy
Device: /dev/nvme0, number of Error Log entries increased from 2381 to 2382
Device info:
CT4000P3PSSD8, S/N:2331E86580DB, FW:P9CR40A
Another message will be sent in 24 hours if the problem persists.
Le système a été intégralement réinstallé (entre le 28 et ) le 31 mai, et une restauration par timeshift du 23 juin.
Je lance une sauvegarde intégrale sur un disque USB neuf
PS:
message d’il y a 3 jours, que j’ai omis de poster: depuis aucun autre message.
