Hash Sum mismatch sur les package php7.0-dev et aptitude
J’essaye d’installer php7.0-dev et je choppe des erreurs Hash Sum Mismatch sur les dépendances
J’ai déjà essayé apt-get clean rm -rf /var/lib/apt/lists/* ....etc et des flags -o Acquire trouvés en ligne mais sans grand succès…
Je suis sur Debian 9 Stretch avec apt version 1.4.8.
Log :
apt-get -o Acquire::http::No-Cache=true install php7.0-dev
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following additional packages will be installed:
  autoconf automake autopoint autotools-dev binutils build-essential cpp cpp-6 debhelper dh-autoreconf dh-php dh-strip-nondeterminism dpkg-dev fakeroot g++ g++-6 gcc gcc-6 gettext gettext-base groff-base intltool-debian
  libalgorithm-diff-perl libalgorithm-diff-xs-perl libalgorithm-merge-perl libarchive-zip-perl libasan3 libatomic1 libc-dev-bin libc6-dev libcc1-0 libcilkrts5 libcroco3 libdpkg-perl libexporter-tiny-perl libfakeroot
  libfile-fcntllock-perl libfile-stripnondeterminism-perl libgcc-6-dev libglib2.0-0 libglib2.0-data libgomp1 libisl15 libitm1 liblist-moreutils-perl liblsan0 libltdl-dev libmail-sendmail-perl libmpc3 libmpfr4 libmpx2 libpcre16-3
  libpcre3-dev libpcre32-3 libpcrecpp0v5 libpipeline1 libquadmath0 libsigsegv2 libstdc++-6-dev libsys-hostname-long-perl libtimedate-perl libtool libtsan0 libubsan0 linux-libc-dev m4 make man-db manpages manpages-dev pkg-php-tools
  po-debconf shared-mime-info shtool xdg-user-dirs xml2
Suggested packages:
  autoconf-archive gnu-standards autoconf-doc binutils-doc cpp-doc gcc-6-locales dh-make debian-keyring g++-multilib g++-6-multilib gcc-6-doc libstdc++6-6-dbg gcc-multilib flex bison gdb gcc-doc gcc-6-multilib libgcc1-dbg libgomp1-dbg
  libitm1-dbg libatomic1-dbg libasan3-dbg liblsan0-dbg libtsan0-dbg libubsan0-dbg libcilkrts5-dbg libmpx2-dbg libquadmath0-dbg gettext-doc libasprintf-dev libgettextpo-dev groff glibc-doc libtool-doc libstdc++-6-doc gfortran
  | fortran95-compiler gcj-jdk m4-doc make-doc www-browser libmail-box-perl
The following NEW packages will be installed:
  libpcre3-dev libpcre32-3 libpcrecpp0v5 libpipeline1 libquadmath0 libsigsegv2 libstdc++-6-dev libsys-hostname-long-perl libtimedate-perl libtool libtsan0 libubsan0 linux-libc-dev m4 make man-db manpages manpages-dev php7.0-dev
  pkg-php-tools po-debconf shared-mime-info shtool xdg-user-dirs xml2
0 upgraded, 77 newly installed, 0 to remove and 0 not upgraded.
Need to get 21.8 MB/57.2 MB of archives.
After this operation, 218 MB of additional disk space will be used.
Do you want to continue? [Y/n] Y5
  Hash Sum mismatch
  Hashes of expected file:
   - SHA256:4021d318a8e9480d740fecfe5efba7a6d60eacc66a064ca3b5c1889b8c67e506
   - MD5Sum:a411993452ef331302f22e4ab0f4f611 [weak]
   - Filesize:28948 [weak]
  Hashes of received file:
   - SHA256:7f0a81e458df5e9648252bf3a76ffd57f366a0ddcab5290a9c3bb5bc0c79e513
   - MD5Sum:83c6ec240f9529814782a1143275f13e [weak]
   - Filesize:564486 [weak]
  Last modification reported: Thu, 05 Jan 2017 21:43:03 +0000
[tronqué]
Merci pour votre aide
Tu as bien fait un apt-get update avant ?
Tu as uniquement les dépots standards debian ? Des backports ou des mirroirs ?
quand j’ai un truc comme ça j’essaie d’accéder directement au .deb ( http://ftp.crihan.fr/debian/pool/main/p/php7.0/php7.0-dev_7.0.30-0+deb9u1_amd64.deb par exemple )
avec deux navigateurs : firefox et tor , je teste en local et je conclus.
Oui pour le apt-get update.
J’ai trouvé depuis, c’est le firewall de mon environnement réseau qui filtre et change la taille des packets reçus.
