Hdmi nVidia => souci avec le AC3
Je viens tout juste d’installer Debian Wheezy 7.9 (en vue de faire tourner VDR - http://www.tvdr.de/) . Je rencontre un souci que je n’arrive pas à régler côté son :
Avec la sortie spdif
=> RAS
Avec la sortie hdmi (carte graphique nVidia GeForce 210)
=> le fichier 5.1 est restitué en 2 canaux seulement.
Pourriez-vous m’aider à corriger ce problème ?
Merci d’avance.
mplayer /DATA/ac3.mkv -ao alsa:device=hw=0.7
MPlayer svn r34540 (Debian), built with gcc-4.7 (C) 2000-2012 MPlayer Team
mplayer: could not open config files /root/.lircrc and /etc/lirc/lircrc
mplayer: No such file or directory
Failed to read LIRC config file ~/.lircrc.
Playing /DATA/ac3.mkv.
libavformat version 53.21.1 (external)
Mismatching header version 53.19.0
libavformat file format detected.
[matroska,webm @ 0x7fcfa9cb0860]Estimating duration from bitrate, this may be inaccurate
[lavf] stream 0: subtitle (text), -sid 0
[lavf] stream 1: video (h264), -vid 0
[lavf] stream 2: audio (ac3), -aid 0, -alang eng
VIDEO:  [H264]  1920x1080  0bpp  23.976 fps    0.0 kbps ( 0.0 kbyte/s)
Load subtitles in /DATA/
Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family
libavcodec version 53.35.0 (external)
Mismatching header version 53.32.2
Selected video codec: [ffh264] vfm: ffmpeg (FFmpeg H.264)
Opening audio decoder: [ffmpeg] FFmpeg/libavcodec audio decoders
AUDIO: 48000 Hz, 2 ch, s16le, 384.0 kbit/25.00% (ratio: 48000->192000)
Selected audio codec: [ffac3] afm: ffmpeg (FFmpeg AC-3)
AO: [alsa] 48000Hz 2ch s16le (2 bytes per sample)
Starting playback...
Unsupported PixelFormat 61
Unsupported PixelFormat 53
Unsupported PixelFormat 81
Movie-Aspect is 1.78:1 - prescaling to correct movie aspect.
VO: [vdpau] 1920x1080 => 1920x1080 Planar YV12
A:   2.5 V:   2.5 A-V:  0.000 ct:  0.042   0/  0 32% 11%  0.4% 0 0
Exiting... (Quit)
