Pour le dmrc (oups fait une faute dans le premier msg) ça ne change rien
et pour le nvidia j’ai un résultat qui m’inquiete un peu.
[code]debian@mart-laptop:~$ sudo aptitude install nvidia-kernel-source nvidia-glx
Reading package lists… Done
Building dependency tree
Reading state information… Done
Reading extended state information
Initializing package states… Done
Reading task descriptions… Done
The following packages are BROKEN:
nvidia-glx nvidia-glx-dev
1 packages upgraded, 0 newly installed, 0 to remove and 5 not upgraded.
Need to get 7658kB of archives. After unpacking 5075kB will be freed.
The following packages have unmet dependencies:
nvidia-glx-dev: Conflicts: nvidia-glx (>= 180.45) but 185.18.14-2 is to be installed.
nvidia-glx: Depends: nvidia-kernel-185.18.14 which is a virtual package.
open: 216; closed: 122; defer: 0; conflict: 14 oThe following actions will resolve these dependencies:
Remove the following packages:
ia32-libs
ia32-libs-gtk
ia32-libs-libidn11
ia32-libs-libnspr4
ia32-libs-libssh2
nspluginwrapper
nvidia-glx
nvidia-glx-dev
picasa
wine
Install the following packages:
gcc-4.3-multilib [4.3.3-13 (testing)]
gcc-multilib [4:4.3.3-9 (unstable, unstable, testing)]
ia32-libdrm2 [2.4.12-1~22 (unstable-i386)]
ia32-libgl1-mesa-glx [7.0.3-7~22 (testing-i386)]
ia32-libx11-6 [2:1.2.2-1~22 (unstable-i386)]
ia32-libxau6 [1:1.0.4-2~22 (unstable-i386, testing-i386)]
ia32-libxcb1 [1.3-2~22 (unstable-i386, testing-i386)]
ia32-libxdamage1 [1:1.1.1-4~22 (unstable-i386, testing-i386)]
ia32-libxdmcp6 [1:1.0.2-3~22 (unstable-i386, testing-i386)]
ia32-libxext6 [2:1.0.4-1~22 (unstable-i386, testing-i386)]
ia32-libxfixes3 [1:4.0.3-2~22 (unstable-i386, testing-i386)]
ia32-libxxf86vm1 [1:1.0.2-1~22 (unstable-i386, testing-i386)]
libc6-dev-i386 [2.9-21 (unstable, unstable)]
libgl1-mesa-dev [7.0.3-7 (testing-i386)]
mesa-common-dev [7.0.3-7 (testing)]
Downgrade the following packages:
cpp-4.3 [4.3.3-14 (unstable, unstable, now) -> 4.3.3-13 (testing)]
g+±4.3 [4.3.3-14 (unstable, unstable, now) -> 4.3.3-13 (testing)]
gcc-4.3 [4.3.3-14 (unstable, unstable, now) -> 4.3.3-13 (testing)]
gcc-4.3-base [4.3.3-14 (unstable, unstable, now) -> 4.3.3-13 (testing)]
libstdc++6-4.3-dev [4.3.3-14 (unstable, unstable, now) -> 4.3.3-13 (testing)]
Score is -8879
Accept this solution? [Y/n/q/?]
Ca fait beaucoup de changements quand meme…
