Voila voila j’ai tout bien installé comme me demandait l’assistant et cependant j’ai des soucis :
Page 1 (Scheduler not running?):
{'cups_connection_failure': False}
Page 2 (Is local server publishing?):
{'local_server_exporting_printers': False}
Page 3 (Choose printer):
{'cups_dest': <cups.Dest HP-PSC-1510 (default)>,
'cups_instance': None,
'cups_queue': 'HP-PSC-1510',
'cups_queue_listed': True}
Page 4 (Check printer sanity):
{'cups_device_uri_scheme': u'http',
'cups_printer_dict': {'device-uri': u'http://192.168.1.1:631',
'printer-info': u'HP PSC 1510',
'printer-is-shared': True,
'printer-location': u'Salon',
'printer-make-and-model': u'HP PSC 1510 Series, hpcups 3.12.6',
'printer-state': 4,
'printer-state-message': u'Print file was not accepted.',
'printer-state-reasons': [u'cups-ipp-conformance-failure-report',
u'cups-ipp-missing-validate-job'],
'printer-type': 167948,
'printer-uri-supported': u'ipp://localhost:631/printers/HP-PSC-1510'},
'cups_printer_remote': False,
'is_cups_class': False,
'local_cups_queue_attributes': {'auth-info-required': u'none',
'charset-configured': u'utf-8',
'charset-supported': [u'us-ascii', u'utf-8'],
'color-supported': True,
'compression-supported': [u'none', u'gzip'],
'copies-default': 1,
'copies-supported': (1, 9999),
'cups-version': u'1.5.3',
'document-format-default': u'application/octet-stream',
'document-format-supported': [u'application/octet-stream',
u'application/pdf',
u'application/postscript',
u'application/vnd.adobe-reader-postscript',
u'application/vnd.cups-pdf',
u'application/vnd.cups-pdf-banner',
u'application/vnd.cups-postscript',
u'application/vnd.cups-raster',
u'application/vnd.cups-raw',
u'application/x-cshell',
u'application/x-csource',
u'application/x-perl',
u'application/x-shell',
u'image/gif',
u'image/jpeg',
u'image/png',
u'image/tiff',
u'image/urf',
u'image/x-bitmap',
u'image/x-photocd',
u'image/x-portable-anymap',
u'image/x-portable-bitmap',
u'image/x-portable-graymap',
u'image/x-portable-pixmap',
u'image/x-sgi-rgb',
u'image/x-sun-raster',
u'image/x-xbitmap',
u'image/x-xpixmap',
u'image/x-xwindowdump',
u'text/css',
u'text/html',
u'text/plain'],
'finishings-default': 3,
'finishings-supported': [3],
'generated-natural-language-supported': [u'en-us'],
'ipp-versions-supported': [u'1.0',
u'1.1',
u'2.0',
u'2.1'],
'ippget-event-life': 15,
'job-creation-attributes-supported': [u'copies',
u'finishings',
u'ipp-attribute-fidelity',
u'job-hold-until',
u'job-name',
u'job-priority',
u'job-sheets',
u'media',
u'media-col',
u'multiple-document-handling',
u'number-up',
u'output-bin',
u'output-mode',
u'orientation-requested',
u'page-ranges',
u'print-quality',
u'printer-resolution',
u'sides'],
'job-hold-until-default': u'no-hold',
'job-hold-until-supported': [u'no-hold',
u'indefinite',
u'day-time',
u'evening',
u'night',
u'second-shift',
u'third-shift',
u'weekend'],
'job-ids-supported': True,
'job-k-limit': 0,
'job-k-octets-supported': (0, 9612516),
'job-page-limit': 0,
j’ai cru comprendre que ça venait de CUPS mais n’étant sur de rien je vous demande
