Par contre chose étonnante (?) un lspci trouve bien tout, voici le retour d’un lspci -v :
[code]00:00.0 Host bridge: Intel Corporation 82852/82855 GM/GME/PM/GMV Processor to I/O Controller (rev 02)
Subsystem: IBM ThinkPad R50e
Flags: bus master, fast devsel, latency 0
Memory at (32-bit, prefetchable)
Capabilities: [40] Vendor Specific Information <?>
Kernel driver in use: agpgart-intel
00:00.1 System peripheral: Intel Corporation 82852/82855 GM/GME/PM/GMV Processor to I/O Controller (rev 02)
00:00.3 System peripheral: Intel Corporation 82852/82855 GM/GME/PM/GMV Processor to I/O Controller (rev 02)
00:02.0 VGA compatible controller: Intel Corporation 82852/855GM Integrated Graphics Device (rev 02) (prog-if 00 [VGA controller])
Subsystem: IBM Device 0557
Flags: bus master, fast devsel, latency 0, IRQ 16
Memory at e0000000 (32-bit, prefetchable) [size=128M]
Memory at d0000000 (32-bit, non-prefetchable) [size=512K]
I/O ports at 1800 [size=8]
Expansion ROM at [disabled]
Capabilities: [d0] Power Management version 1
00:02.1 Display controller: Intel Corporation 82852/855GM Integrated Graphics Device (rev 02)
Flags: fast devsel
Memory at e8000000 (32-bit, prefetchable) [size=128M]
Memory at d0080000 (32-bit, non-prefetchable) [size=512K]
00:1d.0 USB Controller: Intel Corporation 82801DB/DBL/DBM (ICH4/ICH4-L/ICH4-M) USB UHCI Controller #1 (rev 01) (prog-if 00 [UHCI])
Flags: bus master, medium devsel, latency 0, IRQ 16
I/O ports at 1820 [size=32]
Kernel driver in use: uhci_hcd
00:1d.1 USB Controller: Intel Corporation 82801DB/DBL/DBM (ICH4/ICH4-L/ICH4-M) USB UHCI Controller #2 (rev 01) (prog-if 00 [UHCI])
Flags: bus master, medium devsel, latency 0, IRQ 19
I/O ports at 1840 [size=32]
00:1d.2 USB Controller: Intel Corporation 82801DB/DBL/DBM (ICH4/ICH4-L/ICH4-M) USB UHCI Controller #3 (rev 01) (prog-if 00 [UHCI])
Flags: bus master, medium devsel, latency 0, IRQ 18
I/O ports at 1860 [size=32]
00:1d.7 USB Controller: Intel Corporation 82801DB/DBM (ICH4/ICH4-M) USB2 EHCI Controller (rev 01) (prog-if 20 [EHCI])
Flags: bus master, medium devsel, latency 0, IRQ 23
Memory at d0100000 (32-bit, non-prefetchable) [size=1K]
Capabilities: [50] Power Management version 2
Capabilities: [58] Debug port: BAR=1 offset=0080
Kernel driver in use: ehci_hcd
00:1e.0 PCI bridge: Intel Corporation 82801 Mobile PCI Bridge (rev 81) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=02, subordinate=05, sec-latency=64
I/O behind bridge: 00002000-00006fff
Memory behind bridge: d0200000-dfffffff
Prefetchable memory behind bridge: f0000000-f7ffffff
00:1f.0 ISA bridge: Intel Corporation 82801DBM (ICH4-M) LPC Interface Bridge (rev 01)
00:1f.1 IDE interface: Intel Corporation 82801DBM (ICH4-M) IDE Controller (rev 01) (prog-if 8a [Master SecP PriP])
I/O ports at 01f0 [size=8]
I/O ports at 03f4 [size=1]
I/O ports at 0170 [size=8]
I/O ports at 0374 [size=1]
I/O ports at 1810 [size=16]
Memory at 50000000 (32-bit, non-prefetchable) [size=1K]
Kernel driver in use: PIIX_IDE
00:1f.3 SMBus: Intel Corporation 82801DB/DBL/DBM (ICH4/ICH4-L/ICH4-M) SMBus Controller (rev 01)
Flags: medium devsel, IRQ 17
I/O ports at 1880 [size=32]
Kernel driver in use: i801_smbus
02:00.0 CardBus bridge: Ricoh Co Ltd RL5c476 II (rev 8d)
Subsystem: IBM Device 0555
Flags: bus master, medium devsel, latency 168, IRQ 16
Memory at b0000000 (32-bit, non-prefetchable) [size=4K]
Bus: primary=02, secondary=03, subordinate=04, sec-latency=176
Memory window 0: f0000000-f3fff000 (prefetchable)
Memory window 1: d4000000-d7fff000
I/O window 0: 00002000-000020ff
I/O window 1: 00002400-000024ff
16-bit legacy interface ports at 0001
Kernel driver in use: yenta_cardbus
02:00.1 SD Host controller: Ricoh Co Ltd R5C822 SD/SDIO/MMC/MS/MSPro Host Adapter (rev 13)
Subsystem: IBM ThinkPad X60s / Z60t
Flags: bus master, medium devsel, latency 64, IRQ 17
Memory at d0221000 (32-bit, non-prefetchable) [size=256]
Capabilities: [80] Power Management version 2
Kernel driver in use: sdhci-pci
02:01.0 Ethernet controller: Intel Corporation 82541GI Gigabit Ethernet Controller
Subsystem: IBM Device 055b
Flags: bus master, 66MHz, medium devsel, latency 64, IRQ 20
Memory at d0200000 (32-bit, non-prefetchable) [size=128K]
I/O ports at 6000 [size=64]
Capabilities: [dc] Power Management version 2
Capabilities: [e4] PCI-X non-bridge device
Kernel driver in use: e1000
02:02.0 Network controller: Intel Corporation PRO/Wireless 2200BG [Calexico2] Network Connection (rev 05)
Subsystem: Intel Corporation IBM ThinkPad R50e
Flags: bus master, medium devsel, latency 64, IRQ 21
Memory at d0220000 (32-bit, non-prefetchable) [size=4K]
Kernel driver in use: ipw2200
