je n’arrive pas à installer icedtea-6-plugin ou icedtea-7-plugin sous Debian Jessie 64bits:
apt-get install icedtea-7-plugin
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
icedtea-7-plugin : Depends: icedtea-netx (= 1.3.2-1) but 1.4-3~deb7u2 is to be installed
E: Unable to correct problems, you have held broken packages.
Malgré mes recherches je n’ai pas trouvé de solution à ce conflit de dépendances…
bugs.debian.org/cgi-bin/bugreport.cgi?bug=714464 ce ticket décrit mon problème également.
Quelqu’un a-t-il une solution ?
Merci d’avance !
Glaucos
