Id "6" respawning too fast
Je suis sous debian 3.0 kernel 2.4.32
Dans mon /var/log/syslog j’ai ce message qui apparrait toutes les 5 minutes :
Nov 20 11:36:57 machine1 init: Id “6” respawning too fast: disabled for 5 minutes
Voici le fichier /etc/inittab
/etc/inittab: init(8) configuration.
$Id: inittab,v 1.91 2002/01/25 13:35:21 miquels Exp $
The default runlevel.
Boot-time system configuration/initialization script.
This is run first except when booting in emergency (-b) mode.
si::sysinit:/etc/init.d/rcS
What to do in single-user mode.
~~:S:wait:/sbin/sulogin
/etc/init.d executes the S and K scripts upon change
of runlevel.
Runlevel 0 is halt.
Runlevel 1 is single-user.
Runlevels 2-5 are multi-user.
Runlevel 6 is reboot.
l0:0:wait:/etc/init.d/rc 0
l1:1:wait:/etc/init.d/rc 1
l2:2:wait:/etc/init.d/rc 2
l3:3:wait:/etc/init.d/rc 3
l4:4:wait:/etc/init.d/rc 4
l5:5:wait:/etc/init.d/rc 5
l6:6:wait:/etc/init.d/rc 6
Normally not reached, but fallthrough in case of emergency.
z6:6:respawn:/sbin/sulogin
What to do when CTRL-ALT-DEL is pressed.
ca:12345:ctrlaltdel:/sbin/shutdown -t1 -a -r now
Action on special keypress (ALT-UpArrow).
#kb::kbrequest:/bin/echo “Keyboard Request–edit /etc/inittab to let this work.”
What to do when the power fails/returns.
pf::powerwait:/etc/init.d/powerfail start
pn::powerfailnow:/etc/init.d/powerfail now
po::powerokwait:/etc/init.d/powerfail stop
/sbin/getty invocations for the runlevels.
The “id” field MUST be the same as the last
characters of the device (after “tty”).
Format:
Note that on most Debian systems tty7 is used by the X Window System,
so if you want to add more getty’s go ahead but skip tty7 if you run X.
1:2345:respawn:/sbin/getty 38400 tty1
2:23:respawn:/sbin/getty 38400 tty2
3:23:respawn:/sbin/getty 38400 tty3
4:23:respawn:/sbin/getty 38400 tty4
5:23:respawn:/sbin/getty 38400 tty5
6:23:respawn:/sbin/getty -n -l /bin/control_adsl.bash
Example how to put a getty on a serial line (for a terminal)
T0:23:respawn:/sbin/getty -L ttyS0 9600 vt100
#T1:23:respawn:/sbin/getty -L ttyS1 9600 vt100
Example how to put a getty on a modem line.
#T3:23:respawn:/sbin/mgetty -x0 -s 57600 ttyS3
Je ne sais pas à quoi est due ce message, auriez quelques idées ?
D’avance merci
[quote]6:23:respawn:/sbin/getty -n -l /bin/control_adsl.bash[/quote]se passe mal et s’arrête immédiatement. Pour éviter un respawn qui mettrait à genou la machine, il attend un délai avant de relancer le processus.
