Linux localhost 2.6.26-2-686 #1 SMP Wed Aug 19 06:06:52 UTC 2009 i686 GNU/Linux
(debian-503-1386-xfce+lxde-CD1) j’ai installé lxde
00:00.0 Host bridge: Intel Corporation 440BX/ZX/DX - 82443BX/ZX/DX Host bridge (rev 03)
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort+ >SERR- <PERR- INTx-
Latency: 64
Region 0: Memory at e0000000 (32-bit, prefetchable) [size=64M]
Capabilities: [a0] AGP version 1.0
Status: RQ=32 Iso- ArqSz=0 Cal=0 SBA+ ITACoh- GART64- HTrans- 64bit- FW- AGP3- Rate=x1,x2
Command: RQ=1 ArqSz=0 Cal=0 SBA- AGP- GART64- 64bit- FW- Rate=
Kernel driver in use: agpgart-intel
Kernel modules: intel-agp
00:01.0 PCI bridge: Intel Corporation 440BX/ZX/DX - 82443BX/ZX/DX AGP bridge (rev 03) (prog-if 00 [Normal decode])
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx-
Status: Cap- 66MHz+ UDF- FastB2B- ParErr- DEVSEL=medium >TAbort- <TAbort- SERR- <PERR- INTx-
Latency: 64
Bus: primary=00, secondary=01, subordinate=01, sec-latency=64
I/O behind bridge: 0000d000-0000dfff
Memory behind bridge: e4000000-e5ffffff
Prefetchable memory behind bridge: e6000000-e6ffffff
Secondary status: 66MHz+ FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- <SERR- <PERR-
BridgeCtl: Parity- SERR- NoISA- VGA+ MAbort- >Reset- FastB2B+
PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
Kernel modules: shpchp
00:07.0 ISA bridge: Intel Corporation 82371AB/EB/MB PIIX4 ISA (rev 02)
Control: I/O+ Mem+ BusMaster+ SpecCycle+ MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap- 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- SERR- <PERR- INTx-
Latency: 0
00:07.1 IDE interface: Intel Corporation 82371AB/EB/MB PIIX4 IDE (rev 01) (prog-if 80 [Master])
Control: I/O+ Mem- BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Latency: 64
Region 0: [virtual] Memory at 000001f0 (32-bit, non-prefetchable) [disabled] [size=8]
Region 1: [virtual] Memory at 000003f0 (type 3, non-prefetchable) [disabled] [size=1]
Region 2: [virtual] Memory at 00000170 (32-bit, non-prefetchable) [disabled] [size=8]
Region 3: [virtual] Memory at 00000370 (type 3, non-prefetchable) [disabled] [size=1]
Region 4: I/O ports at f000 [size=16]
Kernel driver in use: PIIX_IDE
Kernel modules: piix
00:07.2 USB Controller: Intel Corporation 82371AB/EB/MB PIIX4 USB (rev 01) (prog-if 00 [UHCI])
Latency: 64
Interrupt: pin D routed to IRQ 10
Region 4: I/O ports at e000 [size=32]
Kernel driver in use: uhci_hcd
Kernel modules: uhci-hcd
00:07.3 Bridge: Intel Corporation 82371AB/EB/MB PIIX4 ACPI (rev 02)
Control: I/O+ Mem+ BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Interrupt: pin ? routed to IRQ 9
Kernel driver in use: piix4_smbus
Kernel modules: i2c-piix4
00:0f.0 Multimedia audio controller: Ensoniq ES1371 [AudioPCI-97] (rev 06)
Subsystem: Ensoniq Creative Sound Blaster AudioPCI64V, AudioPCI128
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=slow >TAbort- <TAbort- SERR- <PERR- INTx-
Latency: 64 (3000ns min, 32000ns max)
Interrupt: pin A routed to IRQ 10
Region 0: I/O ports at e400 [size=64]
Capabilities: [dc] Power Management version 1
Flags: PMEClk- DSI+ D1- D2+ AuxCurrent=0mA PME(D0+,D1-,D2+,D3hot+,D3cold-)
Status: D0 PME-Enable- DSel=0 DScale=0 PME-
Kernel driver in use: ENS1371
Kernel modules: snd-ens1371
01:00.0 VGA compatible controller: ATI Technologies Inc 3D Rage IIC AGP (rev 7a) (prog-if 00 [VGA controller])
Subsystem: ATI Technologies Inc Rage 3D Pro AGP 2x XPERT 98
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping+ SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- SERR- <PERR- INTx-
Latency: 64 (2000ns min), Cache Line Size: 32 bytes
Interrupt: pin A routed to IRQ 11
Region 0: Memory at e6000000 (32-bit, prefetchable) [size=16M]
Region 1: I/O ports at d000 [size=256]
Region 2: Memory at e5000000 (32-bit, non-prefetchable) [size=4K]
[virtual] Expansion ROM at e4000000 [disabled] [size=128K]
Capabilities: [5c] Power Management version 1
Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot-,D3cold-)
