Salut a tous, voilà, j’utilise cups dans des ecoles, j’ai toujours un mal de chiens a le configurer…j’ai donc recuperer un cupsd.conf avec lequel ca fonctionne, je le copie sur un autre serveur…et là!!! ca ne fonctionne pas!!! mes serveurs ont la meme IP!! mes machines aussi!!..je ne comprends plus rien!
J’accede a l’interface par 192.168.1.49:631/ mais lorsque je clique sur “add prnter” j’obtiens “impossible d’afficher la page”
voici mon cupsd.conf
# Sample configuration file for the Common UNIX Printing System (CUPS)
# scheduler. See "man cupsd.conf" for a complete description of this
# file.
# Log general information in error_log - change "info" to "debug" for
# troubleshooting...
LogLevel info
# Administrator user group...
SystemGroup lpadmin
# Only listen for connections from the local machine.
Listen localhost:631
Listen 192.168.1.49:631
Listen /var/run/cups/cups.sock
# Show shared printers on the local network.
Browsing Yes
BrowseOrder allow,deny
BrowseAllow @LOCAL
BrowseAddress @LOCAL
# Default authentication type, when authentication is required...
DefaultAuthType Basic
DefaultEncryption Never
# Restrict access to the server...
#<Location />
# Order allow,deny
# Allow localhost
# Allow @LOCAL
# Allow 192.168.1.*
#</Location>
<Location />
Encryption IfRequested
Satisfy All
Order allow,deny
Allow 192.168.1.*
</Location>
# Restrict access to the admin pages...
#<Location /admin>
# Order allow,deny
# Allow localhost
#</Location>
#<Location /admin>
# AuthType Basic
# Require user @SYSTEM
# Order allow,deny
# Allow localhost
# Allow 192.168.1.*
#</Location>
<Location /admin>
AuthType Basic
AuthClass System
Satisfy All
Order deny,allow
Deny From All
Allow From 127.0.0.1
</Location>
# Restrict access to configuration files...
<Location /admin/conf>
AuthType Basic
Order allow,deny
Allow localhost
Allow 192.168.1.*
</Location>
# Set the default printer/job policies...
<Policy default>
# Job-related operations must be done by the owner or an adminstrator...
<Limit Send-Document Send-URI Hold-Job Release-Job Restart-Job Purge-Jobs Set-Job-Attributes Create-Job-Subscription Renew-Subscription Cancel-Subscription Get-Notifications Reprocess-Job Cancel-Current-Job Suspend-Current-Job Resume-Job CUPS-Move-Job>
Require user @OWNER @SYSTEM
Order deny,allow
</Limit>
# All administration operations require an adminstrator to authenticate...
<Limit Pause-Printer Resume-Printer Set-Printer-Attributes Enable-Printer Disable-Printer Pause-Printer-After-Current-Job Hold-New-Jobs Release-Held-New-Jobs Deactivate-Printer Activate-Printer Restart-Printer Shutdown-Printer Startup-Printer Promote-Job Schedule-Job-After CUPS-Add-Printer CUPS-Delete-Printer CUPS-Add-Class CUPS-Delete-Class CUPS-Accept-Jobs CUPS-Reject-Jobs CUPS-Set-Default>
AuthType Basic
Order deny,allow
</Limit>
# Only the owner or an administrator can cancel or authenticate a job...
<Limit Cancel-Job CUPS-Authenticate-Job>
Order deny,allow
</Limit>
<Limit All>
Order deny,allow
</Limit>
</Policy>
merci pour votre aide!
