Impossible de démarrer 2 VMs avec Virt-Manager
Bonjour tout le monde,
Est ce que quelqu’un à le même soucis, depuis quelques semaines seulement, je ne peux plus démarrer 2 VMs en même temps avec virt manager :
Erreur lors du démarrage du domaine: internal error: process exited while connecting to monitor: =usb.0,firstport=4,bus=pci.0,addr=0x6.0x2 -device virtio-serial-pci,id=virtio-serial0,bus=pci.0,addr=0x5 -drive file=/home/alexandre/VM/php.qcow2,format=qcow2,if=none,id=drive-virtio-disk0 -device virtio-blk-pci,scsi=off,bus=pci.0,addr=0x7,drive=drive-virtio-disk0,id=virtio-disk0,bootindex=1 -drive if=none,id=drive-ide0-0-0,readonly=on -device ide-cd,bus=ide.0,unit=0,drive=drive-ide0-0-0,id=ide0-0-0 -fsdev local,security_model=none,id=fsdev-fs0,path=/home/alexandre/workspace -device virtio-9p-pci,id=fs0,fsdev=fsdev-fs0,mount_tag=/hostshare,bus=pci.0,addr=0x9 -netdev tap,fd=26,id=hostnet0,vhost=on,vhostfd=28 -device virtio-net-pci,netdev=hostnet0,id=net0,mac=52:54:00:9d:26:5a,bus=pci.0,addr=0x3 -chardev pty,id=charserial0 -device isa-serial,chardev=charserial0,id=serial0 -chardev spicevmc,id=charchannel0,name=vdagent -device virtserialport,bus=virtio-serial0.0,nr=1,chardev=charchannel0,id=channel0,name=com.redhat.spice.0 -device usb-tablet,id=input0,bus=usb.0,port=
Traceback (most recent call last):
File “/usr/share/virt-manager/virtManager/asyncjob.py”, line 88, in cb_wrapper
callback(asyncjob, *args, **kwargs)
File “/usr/share/virt-manager/virtManager/asyncjob.py”, line 124, in tmpcb
callback(*args, **kwargs)
File “/usr/share/virt-manager/virtManager/libvirtobject.py”, line 83, in newfn
ret = fn(self, *args, **kwargs)
File “/usr/share/virt-manager/virtManager/domain.py”, line 1404, in startup
self._backend.create()
File “/usr/lib/python2.7/dist-packages/libvirt.py”, line 1035, in create
if ret == -1: raise libvirtError (‘virDomainCreate() failed’, dom=self)
libvirtError: internal error: process exited while connecting to monitor: =usb.0,firstport=4,bus=pci.0,addr=0x6.0x2 -device virtio-serial-pci,id=virtio-serial0,bus=pci.0,addr=0x5 -drive file=/home/alexandre/VM/php.qcow2,format=qcow2,if=none,id=drive-virtio-disk0 -device virtio-blk-pci,scsi=off,bus=pci.0,addr=0x7,drive=drive-virtio-disk0,id=virtio-disk0,bootindex=1 -drive if=none,id=drive-ide0-0-0,readonly=on -device ide-cd,bus=ide.0,unit=0,drive=drive-ide0-0-0,id=ide0-0-0 -fsdev local,security_model=none,id=fsdev-fs0,path=/home/alexandre/workspace -device virtio-9p-pci,id=fs0,fsdev=fsdev-fs0,mount_tag=/hostshare,bus=pci.0,addr=0x9 -netdev tap,fd=26,id=hostnet0,vhost=on,vhostfd=28 -device virtio-net-pci,netdev=hostnet0,id=net0,mac=52:54:00:9d:26:5a,bus=pci.0,addr=0x3 -chardev pty,id=charserial0 -device isa-serial,chardev=charserial0,id=serial0 -chardev spicevmc,id=charchannel0,name=vdagent -device virtserialport,bus=virtio-serial0.0,nr=1,chardev=charchannel0,id=channel0,name=com.redhat.spice.0 -device usb-tablet,id=input0,bus=usb.0,port=
Merci d’avance,
J’utilise depuis pas mal de temps virt-manager ou/et virsh sur mon Asus G53SW avec la version stable de debian et n’ai aucun problème de ce genre.
Peut-être voir les fichiers de configuration de ces machines virtuelles,
la ligne de commande utilisée (si lancé en ligne de commande),
le système de fichiers dans lequel sont les fichiers image disque de ces machines virtuelles,
les fichiers log de virt-manager qui sont dans le répertoire :
~/.cache/virt-manager
Sans doute un problème de partage de ressources tel que l’affichage, y a t’il un driver graphique sur les deux VM utilisant dès fois que le même périphérique ?
Bonsoir
Si ça peut aider, j’ai essayé de reformater le retour donné par AnGe7
    File "/usr/share/virt-manager/virtManager/asyncjob.py", line 88, in cb_wrapper
    File "/usr/share/virt-manager/virtManager/asyncjob.py", line 124, in tmpcb
    File "/usr/share/virt-manager/virtManager/libvirtobject.py", line 83, in newfn
    File "/usr/share/virt-manager/virtManager/domain.py", line 1404, in startup
    File "/usr/lib/python2.7/dist-packages/libvirt.py", line 1035, in create
    if ret == -1: raise libvirtError ('virDomainCreate() failed', dom=self)
Alors pour info je n’avais pas le soucis avant (je suis en version stretch)
J’ai le problème que depuis 1 mois environ.
Le problème se résous lorsque j’enlève le serveur Spice d’une de mes VM.
Merci pour le retour.
Par curiosité, j’aimerais savoir quels est ou sont les autres types de serveurs d’affichage que tu utilises,
car toutes mes machines virtuelles (qui fonctionnent parfaitement ensemble) utilisent actuellement le serveur d’affichage spice, et ça pourrait me permettre d’éviter le problème que tu as rencontré, d’autant que, bien sûr, comme j’utilise les versions stable, je vais bientôt me retrouver avec la version debian stretch.
Merci.
Il semblerait qu’il y ait un soucis avec l’attribution automatique du port ‘video’.
Il suffit d’éditer chaque config, de décocher la case ‘Port: Auto’ sur ‘Affichage Spice’ et de leur attribuer chacune un port différent (5900, 5901, 5902 etc).
2 J'aime
Merci beaucoup pour cette description détaillée.
Merci NooP
