Hello,
Merci pour vos aides.
Quand je lance en console, j’ai l’affichage graphique sans problème mais la console me renvoie ça :
patrick@HP-bureau:~$ gnome-app-install
/usr/share/gnome-app-install/AppInstall/SimpleGtkbuilderApp.py:33: RuntimeWarning: missing handler 'on_button_newly_close_clicked’
self.builder.connect_signals(self)
/usr/share/gnome-app-install/AppInstall/SimpleGtkbuilderApp.py:33: RuntimeWarning: missing handler 'on_button_newly_more_clicked’
WARNING: can not get name for '<atk.NoOpObject object at 0x3031500 (AtkNoOpObject at 0x30708a0)>'
WARNING: can not get name for '<atk.NoOpObject object at 0x3031af0 (AtkNoOpObject at 0x3089a30)>'
WARNING: can not get name for '<atk.NoOpObject object at 0x30327d0 (AtkNoOpObject at 0x30899e0)>‘
WARNING: can not get name for ‘<atk.NoOpObject object at 0x3032cd0 (AtkNoOpObject at 0x30762d0)>’
/usr/share/gnome-app-install/AppInstall/AppInstallApp.py:153: DeprecationWarning: Use the new widget gtk.Tooltip
self.tooltips = gtk.Tooltips()
/usr/share/gnome-app-install/AppInstall/AppInstallApp.py:477: DeprecationWarning: Use the new widget gtk.Tooltip
self.tooltips.set_tip(cell_parent, item_disclaimer)
/usr/share/gnome-app-install/AppInstall/AppInstallApp.py:232: DeprecationWarning: Use the new widget gtk.Tooltip
self.tooltips.set_tip(self.eventbox_filter, tooltip)
/usr/share/gnome-app-install/AppInstall/AppInstallApp.py:1234: GtkWarning: gtk_tree_model_sort_sort: assertion tree_model_sort->default_sort_func != NULL' failed item.applications.set_default_sort_func(None) /usr/share/gnome-app-install/AppInstall/AppInstallApp.py:1244: GtkWarning: gtk_tree_model_sort_set_sort_column_id: assertiontree_model_sort->default_sort_func != NULL’ failed
item.applications.set_sort_column_id(-1, sort_type)
Pas très lisible pour moi. Mais, apparemment, détection d’erreurs !!!
Sinon, pour le gnome-system-tools est installé. Je l’ai même réinstallé pour le cas oùùùùùùù !!!
