Y en a un paquet qui sont corrigés…
Ça fait peur… J’accepterais aussi.
ok, j’accepte ! je vous fais confiance, hein ^^
Ça fait peur… J’accepterais aussi.[/quote]
Dis pas ca toi
tu va l’effrayer !
lol (non, pas toi lol) genre, elle nous met la pression la ![]()
euh… j’ai eu cet écran :
[code]kdeutils (4:3.5.9-2) unstable; urgency=high
- klatopdaemon does not work with Debian kernels 2.6.25 or newer.
Those kernels are built without the option: ACPI_PROCFS_POWER which
provided the battery and ac interfaces on /proc/acpi/{ac,BAT} on
what klaptopdaemon uses. Since the ACPI_PROCFS_POWER is not going to
be renabled by the kernel team, klaptopdaemon is no longer usable
in Debian.
So now, klaptopdaemon is now a transitional package that installs
kpowersave a nice replacement that does not have this problem.
The Depends on klaptopdaemon | kpowersave have been removed from the
metapackage and a Recommends on kpowersave have been added instead.
– Ana Beatriz Guerrero Lopez ana@debian.org Fri, 18 Jul 2008 19:00:21 +0200
spamassassin (3.2.5-2+lenny2) stable; urgency=high
This version of SpamAssassin fixes a bug which caused mails sent
in 2010 to be flagged as suspiciously spammy. If upgrading to this
version, you are recommended to update any per-user caches previously
created by sa-compile, and to check mail already in your spam folder
for false positives more carefully than usual.
– Joey Hess joeyh@debian.org Fri, 01 Jan 2010 12:03:40 -0500
spamassassin (3.2.0-1) unstable; urgency=low
This version of SpamAssassin contains a new feature which can be
used to greatly improve the performance of SpamAssassin. Read
README.Debian and the sa-compile man page for more information.
etc etc (c’est très long)
j’ai fait défiler avec la touche entrée et j’en suis maintenant à ceci :
Lecture des fichiers de modifications (« changelog »)... Terminé
mon_user:/var/cache >
touche “q” (quitter)
ok.
avant de passer à
su root
aptitude clean
cd /var/cache
rm apt
mv /home/tonuser/apt . (ps: il y a bien un point qui signifie le répertoire courant)
je reboot ou c’est pas nécessaire ?
Non ce n’est pas nécéssaire
Edit=
[quote]j’ai fait défiler avec la touche entrée et j’en suis maintenant à ceci :
Si cela a continué sans taper q j’ai peur que la mise à jour ne se soit pas faite correctement
Je n’en suis pas certain ceci dit.
ok, c’est terminé.
et maintenant ? je dois faire une vérif ?
Vérif’ indispensable avant un redémarrage.
Et refaire un
pour être sur.
[quote=“galilea_val”]ok, c’est terminé.
et maintenant ? je dois faire une vérif ?[/quote]
Bien vérifier que xserver-xorg-video-intel est installé.
un reboot et prier que cela fonctionne ![]()
Résultat (très long une fois encore, sorry !) :
[code]
cat /etc/debian_version
4.0
aptitude upgrade
W: The “upgrade” command is deprecated; use “safe-upgrade” instead.
Lecture de l’information d’état étendu
Initialisation de l’état des paquets… Fait
Lecture des descriptions de tâches… Fait
ouverts : 122 ; fermés : 399 ; reportés : 511 ; en conflit : 18 o
Résolution des dépendances…
ouverts : 126 ; fermés : 914 ; reportés : 1074 ; en conflit : 29 .
ouverts : 118 ; fermés : 964 ; reportés : 1152 ; en conflit : 33 .
ouverts : 117 ; fermés : 1034 ; reportés : 1246 ; en conflit : 33 .
ouverts : 116 ; fermés : 1101 ; reportés : 1338 ; en conflit : 33 .
ouverts : 114 ; fermés : 1170 ; reportés : 1431 ; en conflit : 34 .
ouverts : 110 ; fermés : 1240 ; reportés : 1528 ; en conflit : 34 .
ouverts : 109 ; fermés : 1320 ; reportés : 1636 ; en conflit : 34 .
ouverts : 107 ; fermés : 1413 ; reportés : 1758 ; en conflit : 34 .
ouverts : 106 ; fermés : 1532 ; reportés : 1905 ; en conflit : 34 .
ouverts : 100 ; fermés : 1669 ; reportés : 2102 ; en conflit : 34 o
ouverts : 99 ; fermés : 1769 ; reportés : 2243 ; en conflit : 34 o Résolution des dépendances…
ouverts : 98 ; fermés : 1866 ; reportés : 2382 ; en conflit : 34 o Résolution des dépendances…
ouverts : 97 ; fermés : 1964 ; reportés : 2523 ; en conflit : 34 o Résolution des dépendances…
ouverts : 92 ; fermés : 2062 ; reportés : 2667 ; en conflit : 34 o Résolution des dépendances…
ouverts : 91 ; fermés : 2170 ; reportés : 2819 ; en conflit : 34 o Résolution des dépendances…
ouverts : 90 ; fermés : 2279 ; reportés : 2973 ; en conflit : 34 o Résolution des dépendances…
ouverts : 87 ; fermés : 2385 ; reportés : 3129 ; en conflit : 34 o Résolution des dépendances…
ouverts : 86 ; fermés : 2498 ; reportés : 3292 ; en conflit : 34 o Résolution des dépendances…
ouverts : 85 ; fermés : 2613 ; reportés : 3459 ; en conflit : 34 o Résolution des dépendances…
ouverts : 82 ; fermés : 2863 ; reportés : 3816 ; en conflit : 34 . Résolution des dépendances…
ouverts : 81 ; fermés : 3048 ; reportés : 4074 ; en conflit : 34 O Résolution des dépendances…
ouverts : 77 ; fermés : 3204 ; reportés : 4291 ; en conflit : 34 O Résolution des dépendances…
ouverts : 81 ; fermés : 3446 ; reportés : 4608 ; en conflit : 34 o Résolution des dépendances…
ouverts : 75 ; fermés : 3569 ; reportés : 4792 ; en conflit : 34 O Résolution des dépendances…
ouverts : 73 ; fermés : 3734 ; reportés : 5024 ; en conflit : 34 O Résolution des dépendances…
ouverts : 66 ; fermés : 3944 ; reportés : 5327 ; en conflit : 34 oRésolution des dépendances…
ouverts : 65 ; fermés : 4189 ; reportés : 5659 ; en conflit : 35 oRésolution des dépendances…
ouverts : 63 ; fermés : 4367 ; reportés : 5919 ; en conflit : 35 oRésolution des dépendances…
ouverts : 62 ; fermés : 4555 ; reportés : 6193 ; en conflit : 35 oRésolution des dépendances…
ouverts : 62 ; fermés : 4897 ; reportés : 6651 ; en conflit : 35 oRésolution des dépendances…
ouverts : 55 ; fermés : 5056 ; reportés : 6900 ; en conflit : 35 oRésolution des dépendances…
ouverts : 55 ; fermés : 5297 ; reportés : 7256 ; en conflit : 35 .Résolution des dépendances…
ouverts : 51 ; fermés : 5557 ; reportés : 7630 ; en conflit : 35 .Résolution des dépendances…
ouverts : 49 ; fermés : 5756 ; reportés : 7932 ; en conflit : 35 .Résolution des dépendances…
ouverts : 32 ; fermés : 5989 ; reportés : 8304 ; en conflit : 35 oRésolution des dépendances…
ouverts : 22 ; fermés : 6427 ; reportés : 8994 ; en conflit : 35 ORésolution des dépendances…
ouverts : 21 ; fermés : 6686 ; reportés : 9389 ; en conflit : 35 oRésolution des dépendances…
ouverts : 20 ; fermés : 6967 ; reportés : 9813 ; en conflit : 35 ORésolution des dépendances…
ouverts : 14 ; fermés : 7201 ; reportés : 10179 ; en conflit : 35 oRésolution des dépendances…
ouverts : 13 ; fermés : 7437 ; reportés : 10549 ; en conflit : 35 oRésolution des dépendances…
ouverts : 12 ; fermés : 7684 ; reportés : 10931 ; en conflit : 35 oRésolution des dépendances…
ouverts : 14 ; fermés : 7955 ; reportés : 11271 ; en conflit : 35 ORésolution des dépendances…
ouverts : 11 ; fermés : 8239 ; reportés : 11702 ; en conflit : 36 ORésolution des dépendances…
ouverts : 10 ; fermés : 8481 ; reportés : 12085 ; en conflit : 36 ORésolution des dépendances…
ouverts : 7 ; fermés : 8923 ; reportés : 12799 ; en conflit : 37 .Résolution des dépendances…
ouverts : 6 ; fermés : 9231 ; reportés : 13274 ; en conflit : 38 oRésolution des dépendances…
ouverts : 4 ; fermés : 9522 ; reportés : 13733 ; en conflit : 39 oRésolution des dépendances…
ouverts : 2 ; fermés : 9637 ; reportés : 13869 ; en conflit : 41 .Les paquets suivants ont des dépendances non satisfaites :
pulseaudio-esound-compat: Est en conflit avec: esound mais 0.2.36-3 est installé.[/code]
Sont normaux tous ces conflits ?
il ne l'est pas !!
[code]xserver-xorg-video-intel
bash: xserver-xorg-video-intel: command not found[/code]
il ne l’est pas !!
4.0
Debian 4.0 = Etch
[quote=“Clem_ufo”]Edit=
Citer:
Je me doutais bien que qqch avait foiré
Tu es sure d’avoir appuyé sur q lorsque le message était affiché ??? Pas après ???
[quote]Code:
bash: xserver-xorg-video-intel: command not found[/quote]
Je crois bien que oui.
apt-cache policy xserver-xorg-video-intel
Installé : (aucun)
Candidat : 2:2.3.2-2+lenny8
Table de version :
2:2.3.2-2+lenny8 0
500 http://ftp.de.debian.org stable/main Packages
Ouf
Bon d’abord, un état des lieux:
Puis
Résultats :
df -h
Sys. de fich. Tail. Occ. Disp. %Occ. Monté sur
/dev/sda1 7,4G 5,9G 1,2G 84% /
tmpfs 500M 0 500M 0% /lib/init/rw
udev 10M 84K 10M 1% /dev
tmpfs 500M 0 500M 0% /dev/shm
/dev/sda5 19G 14G 4,3G 76% /home
/dev/sda6 23G 21G 1,7G 93% /part1
/dev/sda7 23G 22G 727M 97% /part2
#aptitude install xserver-xorg-video-intel
E: Impossible de verrouiller /var/lib/dpkg/lock - open (11 Ressource temporairement non disponible)
E: Unable to lock the administration directory (/var/lib/dpkg/), is another process using it?
Lecture de l'information d'état étendu
Initialisation de l'état des paquets... Fait
Lecture des descriptions de tâches... Fait
W: Impossible de verrouiller le fichier cache : cela est en général dû à une installation simultanée de paquets avec dpkg ou un autre outil comme APT. Ouverture en mode lecture seule : AUCUNE des modifications de l'état des paquets que vous pourrez faire ne sera conservée.
Il n’y a pas quelque chose comme synaptic d’ouvert ou un autre terminal qui utilise aptitude???
Si oui : Tout fermer, sauf le terminal !
Pour vérifier si l’installation s’est bien passée :
aptitude -s full-upgrade
oups… oui j’avais laissé ouvert synaptic…
[code][>aptitude install xserver-xorg-video-intel
Les paquets suivants sont CASSÉS :
xserver-xorg-core xserver-xorg-video-all
xserver-xorg-video-apm{a} xserver-xorg-video-ark{a} xserver-xorg-video-ati{a} xserver-xorg-video-chips{a} xserver-xorg-video-cirrus{a} xserver-xorg-video-cyrix{a} xserver-xorg-video-dummy{a}
xserver-xorg-video-fbdev{a} xserver-xorg-video-glint{a} xserver-xorg-video-i128{a} xserver-xorg-video-i740{a} xserver-xorg-video-i810{a} xserver-xorg-video-imstt{a} xserver-xorg-video-mga{a}
xserver-xorg-video-neomagic{a} xserver-xorg-video-newport{a} xserver-xorg-video-nsc{a} xserver-xorg-video-nv{a} xserver-xorg-video-rendition{a} xserver-xorg-video-s3{a} xserver-xorg-video-s3virge{a}
xserver-xorg-video-savage{a} xserver-xorg-video-siliconmotion{a} xserver-xorg-video-sis{a} xserver-xorg-video-sisusb{a} xserver-xorg-video-tdfx{a} xserver-xorg-video-tga{a} xserver-xorg-video-trident{a}
xserver-xorg-video-tseng{a} xserver-xorg-video-v4l{a} xserver-xorg-video-vesa{a} xserver-xorg-video-vga{a} xserver-xorg-video-via{a} xserver-xorg-video-vmware{a} xserver-xorg-video-voodoo{a}
libdrm2 libxfont1
3 paquets mis à jour, 1 nouvellement installés, 35 à enlever et 1029 non mis à jour.
Il est nécessaire de télécharger 4917ko d’archives. Après dépaquetage, 4604ko seront libérés.
xserver-xorg-video-all: Dépend: xserver-xorg-video-apm mais il n’est pas installable
Dépend: xserver-xorg-video-ark mais il n’est pas installable
Dépend: xserver-xorg-video-ati mais il n’est pas installable
Dépend: xserver-xorg-video-chips mais il n’est pas installable
Dépend: xserver-xorg-video-cirrus mais il n’est pas installable
Dépend: xserver-xorg-video-cyrix mais il n’est pas installable
Dépend: xserver-xorg-video-dummy mais il n’est pas installable
Dépend: xserver-xorg-video-fbdev mais il n’est pas installable
Dépend: xserver-xorg-video-glint mais il n’est pas installable
Dépend: xserver-xorg-video-i128 mais il n’est pas installable
Dépend: xserver-xorg-video-i740 mais il n’est pas installable
Dépend: xserver-xorg-video-i810 mais il n’est pas installable
Dépend: xserver-xorg-video-imstt mais il n’est pas installable
Dépend: xserver-xorg-video-mga mais il n’est pas installable
Dépend: xserver-xorg-video-neomagic mais il n’est pas installable
Dépend: xserver-xorg-video-newport mais il n’est pas installable
Dépend: xserver-xorg-video-nsc mais il n’est pas installable
Dépend: xserver-xorg-video-nv mais il n’est pas installable
Dépend: xserver-xorg-video-rendition mais il n’est pas installable
Dépend: xserver-xorg-video-s3 mais il n’est pas installable
Dépend: xserver-xorg-video-s3virge mais il n’est pas installable
Dépend: xserver-xorg-video-savage mais il n’est pas installable
Dépend: xserver-xorg-video-siliconmotion mais il n’est pas installable
Dépend: xserver-xorg-video-sis mais il n’est pas installable
Dépend: xserver-xorg-video-sisusb mais il n’est pas installable
Dépend: xserver-xorg-video-tdfx mais il n’est pas installable
Dépend: xserver-xorg-video-tga mais il n’est pas installable
Dépend: xserver-xorg-video-trident mais il n’est pas installable
Dépend: xserver-xorg-video-tseng mais il n’est pas installable
Dépend: xserver-xorg-video-vesa mais il n’est pas installable
Dépend: xserver-xorg-video-vga mais il n’est pas installable
Dépend: xserver-xorg-video-via mais il n’est pas installable
Dépend: xserver-xorg-video-voodoo mais il n’est pas installable
Dépend: xserver-xorg-video-vmware mais il n’est pas installable
Dépend: xserver-xorg-video-v4l mais il n’est pas installable
xserver-xorg-core: Est en conflit avec: xserver-xorg-input qui est un paquet virtuel
Est en conflit avec: xserver-xorg-input-wacom (< 0.7.
mais 0.7.4.1-5 est installé et a été conservé
Supprimer les paquets suivants :
Installer les paquets suivants :
x11-xkb-utils [7.4+1 (stable)]
Mettre à jour les paquets suivants :
x11-common [1:7.1.0-19 (now) -> 1:7.3+20 (stable)]
xserver-xorg [1:7.1.0-19 (now) -> 1:7.3+20 (stable)]
xserver-xorg-input-evdev [1:1.1.2-6 (now) -> 1:2.0.8-1 (stable)]
xserver-xorg-input-kbd [1:1.1.0-4 (now) -> 1:1.3.1-1 (stable)]
xserver-xorg-input-mouse [1:1.1.1-3 (now) -> 1:1.3.0-1 (stable)]
xserver-xorg-input-wacom [0.7.4.1-5 (now) -> 0.7.9.3-2 (stable)]
Le score est de 170
Accepter cette solution ? [Y/n/q/?] /code]
