et partie 2 :
[ 0.326176] pci 0000:00:1c.0: PCI bridge to [bus 01]
[ 0.326191] pci 0000:02:00.0: BAR 6: assigned [mem 0xf0480000-0xf048ffff pref]
[ 0.326193] pci 0000:00:1c.3: PCI bridge to [bus 02]
[ 0.326198] pci 0000:00:1c.3: bridge window [mem 0xf0400000-0xf04fffff]
[ 0.326207] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7]
[ 0.326210] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff]
[ 0.326212] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff]
[ 0.326214] pci_bus 0000:00: resource 7 [mem 0xdfa00000-0xfeafffff]
[ 0.326216] pci_bus 0000:00: resource 8 [mem 0xff700100-0xff7001ff]
[ 0.326218] pci_bus 0000:02: resource 1 [mem 0xf0400000-0xf04fffff]
[ 0.326285] NET: Registered protocol family 2
[ 0.326590] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.326686] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 0.326785] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.326814] TCP: reno registered
[ 0.326824] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.326845] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.326934] NET: Registered protocol family 1
[ 0.326955] pci 0000:00:02.0: Video device with shadowed ROM
[ 0.327049] pci 0000:00:14.0: can't derive routing for PCI INT A
[ 0.327051] pci 0000:00:14.0: PCI INT A: no GSI
[ 0.327146] pci 0000:00:14.0: can't derive routing for PCI INT A
[ 0.327169] PCI: CLS 64 bytes, default 64
[ 0.327227] Unpacking initramfs...
[ 0.921333] Freeing initrd memory: 23980K (ffff88003511a000 - ffff880036885000)
[ 0.921370] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 0.921373] software IO TLB [mem 0xd6d3a000-0xdad3a000] (64MB) mapped at [ffff8800d6d3a000-ffff8800dad39fff]
[ 0.921634] RAPL PMU detected, hw unit 2^-14 Joules, API unit is 2^-32 Joules, 4 fixed counters 655360 ms ovfl timer
[ 0.921698] microcode: CPU0 sig=0x40651, pf=0x40, revision=0x1d
[ 0.921709] microcode: CPU1 sig=0x40651, pf=0x40, revision=0x1d
[ 0.921715] microcode: CPU2 sig=0x40651, pf=0x40, revision=0x1d
[ 0.921724] microcode: CPU3 sig=0x40651, pf=0x40, revision=0x1d
[ 0.921793] microcode: Microcode Update Driver: v2.00 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
[ 0.922237] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.922296] audit: initializing netlink subsys (disabled)
[ 0.922316] audit: type=2000 audit(1473968216.912:1): initialized
[ 0.922802] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.922832] zbud: loaded
[ 0.923081] VFS: Disk quotas dquot_6.5.2
[ 0.923102] Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.923171] msgmni has been set to 7732
[ 0.923522] alg: No test for stdrng (krng)
[ 0.923556] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 0.923609] io scheduler noop registered
[ 0.923613] io scheduler deadline registered
[ 0.923660] io scheduler cfq registered (default)
[ 0.924054] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.924076] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.924107] intel_idle: MWAIT substates: 0x11142120
[ 0.924108] intel_idle: v0.4 model 0x45
[ 0.924110] intel_idle: lapic_timer_reliable_states 0xffffffff
[ 0.924457] GHES: HEST is not enabled!
[ 0.924549] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.925120] Linux agpgart interface v0.103
[ 0.925272] i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
[ 0.927795] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 0.927800] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 0.927965] mousedev: PS/2 mouse device common for all mice
[ 0.928020] rtc_cmos 00:01: RTC can wake from S4
[ 0.928177] rtc_cmos 00:01: rtc core: registered rtc_cmos as rtc0
[ 0.928207] rtc_cmos 00:01: alarms up to one month, y3k, 242 bytes nvram, hpet irqs
[ 0.928224] Intel P-state driver initializing.
[ 0.928255] Intel pstate controlling: cpu 0
[ 0.928301] Intel pstate controlling: cpu 1
[ 0.928320] Intel pstate controlling: cpu 2
[ 0.928343] Intel pstate controlling: cpu 3
[ 0.928434] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.928925] AMD IOMMUv2 driver by Joerg Roedel <joerg.roedel@amd.com>
[ 0.928927] AMD IOMMUv2 functionality not available on this system
[ 0.929127] TCP: cubic registered
[ 0.929295] NET: Registered protocol family 10
[ 0.929769] mip6: Mobile IPv6
[ 0.929779] NET: Registered protocol family 17
[ 0.929798] mpls_gso: MPLS GSO support
[ 0.930527] registered taskstats version 1
[ 0.931481] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input0
[ 0.931602] rtc_cmos 00:01: setting system clock to 2016-09-15 19:36:57 UTC (1473968217)
[ 0.931809] PM: Hibernation image not present or could not be loaded.
[ 0.933604] Freeing unused kernel memory: 1204K (ffffffff818ee000 - ffffffff81a1b000)
[ 0.933607] Write protecting the kernel read-only data: 8192k
[ 0.934243] Freeing unused kernel memory: 896K (ffff880001520000 - ffff880001600000)
[ 0.935506] Freeing unused kernel memory: 212K (ffff8800017cb000 - ffff880001800000)
[ 0.955716] systemd-udevd[71]: starting version 215
[ 0.956302] random: systemd-udevd urandom read with 4 bits of entropy available
[ 0.968685] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input2
[ 0.970501] hidraw: raw HID events driver (C) Jiri Kosina
[ 0.971039] sdhci: Secure Digital Host Controller Interface driver
[ 0.971041] sdhci: Copyright(c) Pierre Ossman
[ 0.977828] [drm] Initialized drm 1.1.0 20060810
[ 0.978353] SCSI subsystem initialized
[ 0.979795] libata version 3.00 loaded.
[ 0.980437] ACPI: bus type USB registered
[ 0.980459] usbcore: registered new interface driver usbfs
[ 0.980468] usbcore: registered new interface driver hub
[ 0.980804] ahci 0000:00:1f.2: version 3.0
[ 0.980861] usbcore: registered new device driver usb
[ 0.982672] ACPI: Lid Switch [LID0]
[ 0.982722] ahci 0000:00:1f.2: irq 56 for MSI/MSI-X
[ 0.982752] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input4
[ 0.982758] ACPI: Power Button [PWRB]
[ 0.982762] ahci 0000:00:1f.2: AHCI 0001.0300 32 slots 4 ports 6 Gbps 0x1 impl SATA mode
[ 0.982766] ahci 0000:00:1f.2: flags: 64bit ncq pm led clo only pio slum part deso sadm sds apst
[ 0.982819] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input5
[ 0.982823] ACPI: Power Button [PWRF]
[ 0.985126] ACPI: Invalid active0 threshold
[ 0.985741] thermal LNXTHERM:00: registered as thermal_zone0
[ 0.985744] ACPI: Thermal Zone [TZ00] (0 C)
[ 0.990566] scsi0 : ahci
[ 0.990933] scsi1 : ahci
[ 0.991042] scsi2 : ahci
[ 0.991154] scsi3 : ahci
[ 0.991223] ata1: SATA max UDMA/133 abar m2048@0xf0518000 port 0xf0518100 irq 56
[ 0.991226] ata2: DUMMY
[ 0.991227] ata3: DUMMY
[ 0.991229] ata4: DUMMY
[ 0.991353] xhci_hcd 0000:00:14.0: can't derive routing for PCI INT A
[ 0.991357] xhci_hcd 0000:00:14.0: PCI INT A: no GSI
[ 0.991382] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 0.991388] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 1
[ 1.007284] thermal LNXTHERM:01: registered as thermal_zone1
[ 1.007286] ACPI: Thermal Zone [TZ01] (0 C)
[ 1.173146] xhci_hcd 0000:00:14.0: cache line size of 64 is not supported
[ 1.173162] xhci_hcd 0000:00:14.0: irq 57 for MSI/MSI-X
[ 1.173214] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.173216] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.173217] usb usb1: Product: xHCI Host Controller
[ 1.173218] usb usb1: Manufacturer: Linux 3.16.0-4-amd64 xhci_hcd
[ 1.173219] usb usb1: SerialNumber: 0000:00:14.0
[ 1.173370] hub 1-0:1.0: USB hub found
[ 1.173380] hub 1-0:1.0: 9 ports detected
[ 1.175044] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 1.175048] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
[ 1.175085] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.175086] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.175087] usb usb2: Product: xHCI Host Controller
[ 1.175088] usb usb2: Manufacturer: Linux 3.16.0-4-amd64 xhci_hcd
[ 1.175089] usb usb2: SerialNumber: 0000:00:14.0
[ 1.175222] hub 2-0:1.0: USB hub found
[ 1.175229] hub 2-0:1.0: 4 ports detected
[ 1.176270] [drm] Memory usable by graphics device = 2048M
[ 1.176273] [drm] Replacing VGA console driver
[ 1.177429] Console: switching to colour dummy device 80x25
[ 1.198463] i915 0000:00:02.0: irq 58 for MSI/MSI-X
[ 1.198479] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 1.198480] [drm] Driver supports precise vblank timestamp query.
[ 1.198508] vgaarb: device changed decodes: PCI:0000:00:02.0,olddecodes=io+mem,decodes=io+mem:owns=io+mem
[ 1.225185] [drm] VBT doesn't support DRRS
[ 1.265217] fbcon: inteldrmfb (fb0) is primary device
[ 1.310333] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 1.310732] ata1.00: ACPI cmd f5/00:00:00:00:00:a0 (SECURITY FREEZE LOCK) filtered out
[ 1.310734] ata1.00: ACPI cmd b1/c1:00:00:00:00:a0 (DEVICE CONFIGURATION OVERLAY) filtered out
[ 1.311038] ata1.00: ATA-9: ST500UM001-1EK162, SP13, max UDMA/133
[ 1.311040] ata1.00: 976773168 sectors, multi 0: LBA48 NCQ (depth 31/32), AA
[ 1.311584] ata1.00: ACPI cmd f5/00:00:00:00:00:a0 (SECURITY FREEZE LOCK) filtered out
[ 1.311586] ata1.00: ACPI cmd b1/c1:00:00:00:00:a0 (DEVICE CONFIGURATION OVERLAY) filtered out
[ 1.311918] ata1.00: configured for UDMA/133
[ 1.312086] scsi 0:0:0:0: Direct-Access ATA ST500UM001-1EK16 SP13 PQ: 0 ANSI: 5
[ 1.314576] sd 0:0:0:0: [sda] 976773168 512-byte logical blocks: (500 GB/465 GiB)
[ 1.314578] sd 0:0:0:0: [sda] 4096-byte physical blocks
[ 1.314639] sd 0:0:0:0: [sda] Write Protect is off
[ 1.314641] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.314672] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.315746] sda: sda1 sda2 < sda5 sda6 >
[ 1.316175] sd 0:0:0:0: [sda] Attached SCSI disk
[ 1.316763] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 1.353669] psmouse serio1: alps: Unknown ALPS touchpad: E7=73 03 c8, EC=73 04 13
[ 1.486222] usb 1-5: new high-speed USB device number 2 using xhci_hcd
[ 1.754578] usb 1-5: New USB device found, idVendor=04f2, idProduct=b3df
[ 1.754582] usb 1-5: New USB device strings: Mfr=2, Product=1, SerialNumber=0
[ 1.754584] usb 1-5: Product: FJ Camera
[ 1.754586] usb 1-5: Manufacturer: Chicony Electronics Co.,Ltd.
[ 1.902512] input: ImPS/2 Generic Wheel Mouse as /devices/platform/i8042/serio1/input/input3
[ 1.918007] tsc: Refined TSC clocksource calibration: 2294.689 MHz
[ 1.926033] usb 1-7: new full-speed USB device number 3 using xhci_hcd
[ 2.054941] usb 1-7: New USB device found, idVendor=04c5, idProduct=1330
[ 2.054943] usb 1-7: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.349697] Console: switching to colour frame buffer device 170x48
[ 2.354573] i915 0000:00:02.0: fb0: inteldrmfb frame buffer device
[ 2.354575] i915 0000:00:02.0: registered panic notifier
[ 2.391496] ACPI: Video Device [GFX0] (multi-head: yes rom: no post: no)
[ 2.391686] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input6
[ 2.391720] [drm] Initialized i915 1.6.0 20080730 for 0000:00:02.0 on minor 0
[ 2.401418] PM: Starting manual resume from disk
[ 2.401422] PM: Hibernation image partition 8:5 present
[ 2.401423] PM: Looking for hibernation image.
[ 2.401655] PM: Image not found (code -22)
[ 2.401658] PM: Hibernation image not present or could not be loaded.
[ 2.443867] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 2.793599] [drm] Enabling RC6 states: RC6 on, RC6p off, RC6pp off
[ 2.891283] systemd-udevd[184]: starting version 215
[ 2.917421] Switched to clocksource tsc
[ 2.983318] lp: driver loaded but no devices found
[ 3.014533] ppdev: user-space parallel port driver
[ 3.017487] input: PC Speaker as /devices/platform/pcspkr/input/input7
[ 3.029984] ACPI: AC Adapter [ADP1] (on-line)
[ 3.037925] tpm_tis 00:07: 1.2 TPM (device-id 0xB, rev-id 16)
[ 3.049140] input: Fujitsu FUJ02B1 as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:01/FUJ02B1:00/input/input8
[ 3.049299] fuse init (API version 7.23)
[ 3.049368] fujitsu_laptop: ACPI: Fujitsu FUJ02B1 [FJEX] (on)
[ 3.049948] input: Fujitsu FUJ02E3 as /devices/LNXSYSTM:00/LNXSYBUS:00/FUJ02E3:00/input/input9
[ 3.050007] fujitsu_laptop: ACPI: Fujitsu FUJ02E3 [FEXT] (on)
[ 3.050363] fujitsu_laptop: BTNI: [0x80001]
[ 3.050487] fujitsu_laptop: driver 0.6.0 successfully loaded
[ 3.080731] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 3.086936] ACPI: Battery Slot [BAT1] (battery present)
[ 3.103895] ACPI Warning: SystemIO range 0x000000000000EFA0-0x000000000000EFBF conflicts with OpRegion 0x000000000000EFA0-0x000000000000EFAF (\_SB_.PCI0.SBUS.SMBI) (20140424/utaddress-254)
[ 3.103901] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 3.122577] Guest personality initialized and is inactive
[ 3.122626] VMCI host device registered (name=vmci, major=10, minor=59)
[ 3.122628] Initialized host personality
[ 3.128813] mei_me 0000:00:16.0: irq 59 for MSI/MSI-X
[ 3.165003] iTCO_vendor_support: vendor-support=0
[ 3.229530] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.11
[ 3.229580] iTCO_wdt: Found a Lynx Point_LP TCO device (Version=2, TCOBASE=0x1860)
[ 3.230030] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[ 3.244685] media: Linux media interface: v0.10
[ 3.251049] Linux video capture interface: v2.00
[ 3.257433] uvcvideo: Found UVC 1.00 device FJ Camera (04f2:b3df)
[ 3.279790] Bluetooth: Core ver 2.19
[ 3.279805] NET: Registered protocol family 31
[ 3.279807] Bluetooth: HCI device and connection manager initialized
[ 3.279815] Bluetooth: HCI socket layer initialized
[ 3.279817] Bluetooth: L2CAP socket layer initialized
[ 3.279829] Bluetooth: SCO socket layer initialized
[ 3.282353] usbcore: registered new interface driver btusb
[ 3.283900] usb 1-7: firmware: failed to load ar3k/AthrBT_0x11020100.dfu (-2)
[ 3.283931] usb 1-7: Direct firmware load failed with error -2
[ 3.283933] usb 1-7: Falling back to user helper
[ 3.284385] Bluetooth: Loading patch file failed
[ 3.284421] ath3k: probe of 1-7:1.0 failed with error -12
[ 3.284448] usbcore: registered new interface driver ath3k
[ 3.291336] input: FJ Camera as /devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5:1.0/input/input10
[ 3.291418] usbcore: registered new interface driver uvcvideo
[ 3.291421] USB Video Class driver (1.1.1)
[ 3.306797] AVX2 version of gcm_enc/dec engaged.
[ 3.310339] alg: No test for __gcm-aes-aesni (__driver-gcm-aes-aesni)
[ 3.315982] cfg80211: Calling CRDA to update world regulatory domain
[ 3.316048] alg: No test for crc32 (crc32-pclmul)
[ 3.386717] snd_hda_intel 0000:00:1b.0: irq 60 for MSI/MSI-X
[ 3.395882] snd_hda_intel 0000:00:03.0: irq 61 for MSI/MSI-X
[ 3.410668] ath: phy0: ASPM enabled: 0x42
[ 3.410671] ath: EEPROM regdomain: 0x6a
[ 3.410673] ath: EEPROM indicates we should expect a direct regpair map
[ 3.410674] ath: Country alpha2 being used: 00
[ 3.410675] ath: Regpair used: 0x6a
[ 3.416079] sound hdaudioC1D0: ALC283: SKU not ready 0x909701f0
[ 3.416307] sound hdaudioC1D0: autoconfig: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:speaker
[ 3.416311] sound hdaudioC1D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 3.416314] sound hdaudioC1D0: hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
[ 3.416316] sound hdaudioC1D0: mono: mono_out=0x0
[ 3.416318] sound hdaudioC1D0: inputs:
[ 3.416321] sound hdaudioC1D0: Mic=0x19
[ 3.416323] sound hdaudioC1D0: Internal Mic=0x12
[ 3.416687] intel_rapl: Found RAPL domain package
[ 3.416692] intel_rapl: Found RAPL domain core
[ 3.416693] intel_rapl: Found RAPL domain uncore
[ 3.416695] intel_rapl: Found RAPL domain dram
[ 3.422098] input: HDA Intel HDMI HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:03.0/sound/card0/input11
[ 3.422157] input: HDA Intel HDMI HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:03.0/sound/card0/input12
[ 3.422207] input: HDA Intel HDMI HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:03.0/sound/card0/input13
[ 3.439627] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
[ 3.439947] ieee80211 phy0: Atheros AR9462 Rev:3 mem=0xffffc90015280000, irq=19
[ 3.455795] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1b.0/sound/card1/hdaudioC1D0/input14
[ 3.458822] input: HDA Intel PCH Mic as /devices/pci0000:00/0000:00:1b.0/sound/card1/input15
[ 3.458913] input: HDA Intel PCH Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card1/input16
[ 3.462239] cfg80211: World regulatory domain updated:
[ 3.462243] cfg80211: DFS Master region: unset
[ 3.462245] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 3.462248] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 3.462250] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 3.462252] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 3.462254] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 3.462257] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 3.462259] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 3.462261] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 3.462263] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 3.536275] Adding 8191996k swap on /dev/sda5. Priority:-1 extents:1 across:8191996k FS
[ 3.536612] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
[ 3.645154] EXT4-fs (sda6): mounted filesystem with ordered data mode. Opts: (null)
[ 3.682861] systemd-journald[193]: Received request to flush runtime journal from PID 1
[ 3.801123] random: nonblocking pool is initialized
[ 3.887311] RPC: Registered named UNIX socket transport module.
[ 3.887314] RPC: Registered udp transport module.
[ 3.887316] RPC: Registered tcp transport module.
[ 3.887317] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 3.890635] FS-Cache: Loaded
[ 3.898121] FS-Cache: Netfs 'nfs' registered for caching
[ 3.906764] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 4.032466] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro,data=ordered,commit=360
[ 4.047582] EXT4-fs (sda6): re-mounted. Opts: data=ordered,commit=360
[ 7.715894] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 11.338852] wlan0: authenticate with 20:e5:2a:2d:ae:7e
[ 11.344302] wlan0: send auth to 20:e5:2a:2d:ae:7e (try 1/3)
[ 11.346266] wlan0: authenticated
[ 11.348694] wlan0: associate with 20:e5:2a:2d:ae:7e (try 1/3)
[ 11.352236] wlan0: RX AssocResp from 20:e5:2a:2d:ae:7e (capab=0x401 status=0 aid=3)
[ 11.352278] wlan0: associated
[ 11.352310] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 84.164287] usb 1-1: new high-speed USB device number 4 using xhci_hcd
[ 84.293125] usb 1-1: New USB device found, idVendor=1058, idProduct=0748
[ 84.293129] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=5
[ 84.293132] usb 1-1: Product: My Passport 0748
[ 84.293134] usb 1-1: Manufacturer: Western Digital
[ 84.293136] usb 1-1: SerialNumber: 575835314533325652303831
[ 84.309198] usb-storage 1-1:1.0: USB Mass Storage device detected
[ 84.309268] scsi4 : usb-storage 1-1:1.0
[ 84.309359] usbcore: registered new interface driver usb-storage
[ 106.907899] usb 1-1: reset high-speed USB device number 4 using xhci_hcd
[ 107.036172] xhci_hcd 0000:00:14.0: xHCI xhci_drop_endpoint called with disabled ep ffff8800d3d1d1c0
[ 107.036182] xhci_hcd 0000:00:14.0: xHCI xhci_drop_endpoint called with disabled ep ffff8800d3d1d208
[ 227.216201] usb 1-1: USB disconnect, device number 4
[ 247.677343] usb 1-1: new high-speed USB device number 5 using xhci_hcd
[ 247.805847] usb 1-1: New USB device found, idVendor=1058, idProduct=0748
[ 247.805853] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=5
[ 247.805856] usb 1-1: Product: My Passport 0748
[ 247.805859] usb 1-1: Manufacturer: Western Digital
[ 247.805862] usb 1-1: SerialNumber: 575835314533325652303831
[ 247.807361] usb-storage 1-1:1.0: USB Mass Storage device detected
[ 247.807451] scsi5 : usb-storage 1-1:1.0
root@homijima:/home/matiu#
