Error mounting: mount exited with exit code 1: helper failed with:
Mount is denied because setuid and setgid root ntfs-3g is insecure with the
external FUSE library. Either remove the setuid/setgid bit from the binary
or rebuild NTFS-3G with integrated FUSE support and make it setuid root.
Please see more information at
tuxera.com/community/ntfs-3g-faq/#unprivileged
lorsque je vais là :
voici ce qu’ils disent :
Why do I get “fusermount: option blkdev is privileged” error?
Unprivileged block device mounts work only if all the below requirements are met:
ntfs-3g is compiled with integrated FUSE support
the ntfs-3g binary is at least version 1.2506
the ntfs-3g binary is set to setuid-root
the user has access right to the volume
the user has access right to the mount point
The root user can make an ntfs-3g binary setuid-root as shown below
chown root $(which ntfs-3g)
chmod 4755 $(which ntfs-3g) In such case the driver will also be able
to fix common FUSE kernel module loading problems
to create the required but sometimes incorrectly removed or missing FUSE device file
donc je fais ceci en root :
mais ça ne change rien
pourtant j’étais capable avant-hier de le monté, sur win$ ça fonctionne donc pas le disque qui ne marche pas
