Bonsoir,
Je me suis acheté une nouvelle clef USB, mais je ne parviens pas à la monter. Jusqu’ici, je n’avais jamais eu de problèmes pour monter une clef. D’ailleurs, mes deux autres clefs sont parfaitement reconnues.
Voici le message d’erreur :
[code]root@debian:/home/fab# mount -t vfat /dev/sdd /mnt/clef_1/
mount: wrong fs type, bad option, bad superblock on /dev/sdd,
missing codepage or helper program, or other error
In some cases useful info is found in syslog - try
dmesg | tail or so
root@debian:/home/fab# dmesg | tail
[ 6341.802684] sd 10:0:0:0: [sdd] CDB: Read(10): 28 00 01 bf 60 00 00 00 01 00
[ 6341.802696] end_request: critical target error, dev sdd, sector 29319168
[ 6341.802702] Buffer I/O error on device sdd, logical block 29319168
[ 6343.313985] sd 10:0:0:0: [sdd] Unhandled sense code
[ 6343.313990] sd 10:0:0:0: [sdd] Result: hostbyte=invalid driverbyte=DRIVER_SENSE
[ 6343.313995] sd 10:0:0:0: [sdd] Sense Key : Medium Error [current]
[ 6343.314001] sd 10:0:0:0: [sdd] Add. Sense: Recorded entity not found
[ 6343.314007] sd 10:0:0:0: [sdd] CDB: Read(10): 28 00 01 bf 60 00 00 00 01 00
[ 6343.314019] end_request: critical target error, dev sdd, sector 29319168
[ 6343.314025] Buffer I/O error on device sdd, logical block 29319168
root@debian:/home/fab# [/code]
Merci.
