Impossible d'envoyer et recevoir des emails
Bonjour, suite à l’installation d’un serveur de mail (seulement) sur un VPS via ISPConfig, je ne peut pas envoyer ni recevoir d’emails (même en local), et mon domaine d’adresse n’est pas la bonne. Voici mon Postconf -n
alias_database = hash:/etc/aliases, hash:/var/lib/mailman/data/aliases
alias_maps = hash:/etc/aliases, hash:/var/lib/mailman/data/aliases
append_dot_mydomain = no
biff = no
body_checks = regexp:/etc/postfix/body_checks
broken_sasl_auth_clients = yes
config_directory = /etc/postfix
header_checks = regexp:/etc/postfix/header_checks
html_directory = /usr/share/doc/postfix/html
inet_interfaces = all
inet_protocols = ipv4
mailbox_command = procmail -a "$EXTENSION"
mailbox_size_limit = 0
message_size_limit = 0
mime_header_checks = regexp:/etc/postfix/mime_header_checks
mydestination = localhost, localhost.localdomain, noxe.tk, mailserver.noxe.tk
myhostname = noxe.tk
mynetworks = 127.0.0.0/8 [::1]/128 0.0.0.0/0
myorigin = /etc/mailname
nested_header_checks = regexp:/etc/postfix/nested_header_checks
owner_request_special = no
proxy_read_maps = $local_recipient_maps $mydestination $virtual_alias_maps $virtual_alias_domains $virtual_mailbox_maps $virtual_mailbox_domains $relay_recipient_maps $relay_domains $canonical_maps $sender_canonical_maps $recipient_canonical_maps $relocated_maps $transport_maps $mynetworks $virtual_mailbox_limit_maps
readme_directory = /usr/share/doc/postfix
recipient_delimiter = +
relay_domains = mysql:/etc/postfix/mysql-virtual_relaydomains.cf
relay_recipient_maps = mysql:/etc/postfix/mysql-virtual_relayrecipientmaps.cf
relayhost =
smtp_tls_session_cache_database = btree:${data_directory}/smtp_scache
smtpd_banner = $myhostname ESMTP $mail_name (Debian/GNU)
smtpd_client_message_rate_limit = 100
smtpd_client_restrictions = check_client_access mysql:/etc/postfix/mysql-virtual_client.cf
smtpd_recipient_restrictions = permit_mynetworks, permit_sasl_authenticated, check_recipient_access mysql:/etc/postfix/mysql-virtual_recipient.cf, reject_unauth_destination
smtpd_sasl_auth_enable = yes
smtpd_sasl_authenticated_header = yes
smtpd_sender_restrictions = check_sender_access mysql:/etc/postfix/mysql-virtual_sender.cf
smtpd_tls_cert_file = /etc/postfix/smtpd.cert
smtpd_tls_key_file = /etc/postfix/smtpd.key
smtpd_tls_security_level = may
smtpd_tls_session_cache_database = btree:${data_directory}/smtpd_scache
smtpd_use_tls = yes
transport_maps = proxy:mysql:/etc/postfix/mysql-virtual_transports.cf
virtual_alias_domains =
virtual_alias_maps = proxy:mysql:/etc/postfix/mysql-virtual_forwardings.cf, proxy:mysql:/etc/postfix/mysql-virtual_email2email.cf, hash:/var/lib/mailman/data/virtual-mailman
virtual_gid_maps = static:5000
virtual_mailbox_base = /var/vmail
virtual_mailbox_domains = proxy:mysql:/etc/postfix/mysql-virtual_domains.cf
virtual_mailbox_maps = proxy:mysql:/etc/postfix/mysql-virtual_mailboxes.cf
virtual_transport = maildrop
virtual_uid_maps = static:5000
Pour plus d’infos, mon Skype : nicolas.myre
Merci d’avance,
Nic1101
Je ne connais pas bien postfix mais ton mynetworks me parait restreint. Fais un
netstat -tpl
Je pense que ton postfix n’écoute sur sur lo (127.0.0.0/8)
il faudrait un extrait des logs pour y voir plus clair
netstat -tpl :
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address Foreign Address State PID/Program name
tcp 0 0 :cisco-sccp : LISTEN 30662/master
tcp 0 0 :www : LISTEN 460/apache2
tcp 0 0 :ssh : LISTEN 607/sshd
tcp 0 0 :smtp : LISTEN 28236/smtpd
tcp 0 0 localhost:10025 : LISTEN 30662/master
tcp 0 0 localhost:mysql : LISTEN 740/mysqld
tcp 0 0 :submission : LISTEN 30662/master
tcp6 0 0 [::]:pop3 [::]:
LISTEN 516/couriertcpd
tcp6 0 0 [::]:imap2 [::]:
LISTEN 497/couriertcpd
tcp6 0 0 [::]:ssh [::]:
LISTEN 607/sshd
tcp6 0 0 [::]:imaps [::]:
LISTEN 538/couriertcpd
tcp6 0 0 [::]:pop3s [::]:
LISTEN 542/couriertcpd
Logs :
Sep 23 18:10:10 mailserver pop3d: Connection, ip=[::1]
Sep 23 18:10:10 mailserver pop3d: Disconnected, ip=[::1]
Sep 23 18:10:10 mailserver imapd: Connection, ip=[::1]
Sep 23 18:10:10 mailserver imapd: Disconnected, ip=[::1], time=0
Sep 23 18:10:10 mailserver postfix/smtpd[28236]: warning: database /var/lib/mailman/data/aliases.db is older than source file /var/lib/mailman/data/aliases
Sep 23 18:10:10 mailserver postfix/smtpd[28236]: warning: database /var/lib/mailman/data/virtual-mailman.db is older than source file /var/lib/mailman/data/virtual-mailman
Sep 23 18:10:10 mailserver postfix/smtpd[28236]: connect from localhost[127.0.0.1]
Sep 23 18:10:10 mailserver postfix/smtpd[28236]: lost connection after CONNECT from localhost[127.0.0.1]
Sep 23 18:10:10 mailserver postfix/smtpd[28236]: disconnect from localhost[127.0.0.1]
Ce message se répète très souvent (en ligne)…
Merci encore,
Nic1101
Bon, mon hypothèse s’écroule, tu écoutes sur toutes les interfaces
Cependant ton erreur est sur l’interface lo.
Bon, rectifies tout de même le mynetworks en mettant au moins le LAN où est la machine, i.e le réseau correspondant à ton interface eth.
As tu un antivirus quelconque sur ton serveur?
J’ai rajouté 37.26.241.22/32 à la ligne mynetworks de main.cf et je ne penses pas avoir d’antivirus sur le serveur…
Ton serveur n’est relié qu’à Internet point barre?
J’ai scanné ta machine et le port 25 est actif (Ton uptime serait de 17 jours mais c’est souvent erroné). Un requête sur le port 25 ouvre la connexion mais ça s’arrête là.
Est ce que la résolution de nom est fonctionnelle sur ton serveur
Ouhla jsuis pu sûr de comprendre la… j’ai le domaine mailserver.noxe.tk qui pointe vers mon IP (37.26.241.22) Si jamais tu voudrais me parler plus direct je suis sur IRC (irc.freenode.net Channel #JeTestMonBot) ou sur Skype : nicolas.myre
Simple, donne le résultat de ifconfig sur ta machine.
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
RX packets:11755 errors:0 dropped:0 overruns:0 frame:0
TX packets:11755 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:902076 (880.9 KiB) TX bytes:902076 (880.9 KiB)
venet0 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
inet addr:127.0.0.2 P-t-P:127.0.0.2 Bcast:0.0.0.0 Mask:255.255.255.255
UP BROADCAST POINTOPOINT RUNNING NOARP MTU:1500 Metric:1
RX packets:106323 errors:0 dropped:0 overruns:0 frame:0
TX packets:99026 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:42985234 (40.9 MiB) TX bytes:32641310 (31.1 MiB)
venet0:0 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
inet addr:37.26.241.22 P-t-P:37.26.241.22 Bcast:0.0.0.0 Mask:255.255.255.255
Houla, c’est une machine virtuelle… Ça complique un chouïa, retire 37.26.241.22/32 de mynetwork, effectivement, 127.0.0/8 seul est logique.
Du coup je m’intéresserais plus aux règles de routage et au parefeu de la machine hote.
Je ne peux plus regarder en détails, la machine semble être HS…
T’a Skype ? Je vais t’envoyer le mot de passe pour la machine, ca serais moins compliqué… :slightly_smiling:
Je suis aussi sur IRC (irc.freenode.net #debian-fr)
