Impossible d'installer de nouveau packet
depuit quelque temp je peut pas installer de nouveau packet et synaptic me donne comme log
Paramétrage de initscripts (2.88dsf-13.1+squeeze1) …
insserv: warning: script ‘K01vmware’ missing LSB tags and overrides
insserv: warning: script ‘S50vmware-USBArbitrator’ missing LSB tags and overrides
insserv: warning: script ‘vmware-workstation-server’ missing LSB tags and overrides
insserv: warning: script ‘vmware’ missing LSB tags and overrides
insserv: warning: script ‘vmware-USBArbitrator’ missing LSB tags and overrides
insserv: There is a loop at service rmnologin if started
insserv: There is a loop between service rmnologin and mountnfs if started
insserv: loop involving service mountnfs at depth 6
insserv: loop involving service nfs-common at depth 5
insserv: Starting vmware-USBArbitrator depends on rmnologin and therefore on system facility $all' which can not be true! insserv: Starting vmware-USBArbitrator depends on rmnologin and therefore on system facility$all’ which can not be true!
insserv: Starting vmware-USBArbitrator depends on rmnologin and therefore on system facility $all' which can not be true! insserv: Max recursions depth 99 reached insserv: loop involving service portmap at depth 4 insserv: There is a loop between service rmnologin and pcmcia if started insserv: loop involving service pcmcia at depth 2 insserv: loop involving service udev at depth 1 insserv: There is a loop at service vmware-USBArbitrator if started insserv: There is a loop between service rmnologin and checkroot if started insserv: loop involving service checkroot at depth 2 insserv: loop involving service keyboard-setup at depth 1 insserv: loop involving service alsa-utils at depth 10 insserv: loop involving service atd at depth 10 insserv: There is a loop between service rmnologin and mountall if started insserv: loop involving service mountall at depth 5 insserv: loop involving service checkfs at depth 4 insserv: loop involving service mtab at depth 3 insserv: loop involving service networking at depth 7 insserv: loop involving service kbd at depth 11 insserv: There is a loop between service rmnologin and ifupdown-clean if started insserv: loop involving service ifupdown-clean at depth 1 insserv: loop involving service hwclockfirst at depth 4 insserv: loop involving service hostname at depth 5 insserv: loop involving service module-init-tools at depth 7 insserv: There is a loop between service rmnologin and ifupdown if started insserv: loop involving service ifupdown at depth 8 insserv: There is a loop between service rmnologin and mountdevsubfs if started insserv: loop involving service mountdevsubfs at depth 3 insserv: loop involving service vmware-USBArbitrator at depth 1 insserv: There is a loop between service rmnologin and mountall-bootclean if started insserv: loop involving service mountall-bootclean at depth 1 insserv: exiting now without changing boot order! update-rc.d: error: insserv rejected the script header dpkg : erreur de traitement de initscripts (--configure) : le sous-processus script post-installation installé a retourné une erreur de sortie d'état 1 configured to not write apport reports Des erreurs ont été rencontrées pendant l'exécution : initscripts E: Sub-process /usr/bin/dpkg returned an error code (1) Échec de l'installation d'un paquet. Tentative de récupération : Paramétrage de dahdi (1:2.2.1.1-1) ... insserv: warning: script 'K01vmware' missing LSB tags and overrides insserv: warning: script 'S50vmware-USBArbitrator' missing LSB tags and overrides insserv: warning: script 'vmware-workstation-server' missing LSB tags and overrides insserv: warning: script 'vmware' missing LSB tags and overrides insserv: warning: script 'vmware-USBArbitrator' missing LSB tags and overrides insserv: There is a loop at service rmnologin if started insserv: There is a loop between service rmnologin and mountnfs if started insserv: loop involving service mountnfs at depth 6 insserv: loop involving service nfs-common at depth 5 insserv: Starting vmware-USBArbitrator depends on rmnologin and therefore on system facility$all’ which can not be true!
dpkg : erreur de traitement de dahdi (–configure) :
le sous-processus script post-installation installé a retourné une erreur de sortie d’état 1
Paramétrage de hal (0.5.14-3) …
Reloading system message bus config…done.
insserv: Starting vmware-USBArbitrator depends on rmnologin and therefore on system facility $all' which can not be true! insserv: Max recursions depth 99 reached insserv: loop involving service portmap at depth 4 insserv: There is a loop between service rmnologin and pcmcia if started insserv: loop involving service pcmcia at depth 2 insserv: loop involving service udev at depth 1 insserv: There is a loop at service vmware-USBArbitrator if started insserv: There is a loop between service rmnologin and checkroot if started insserv: loop involving service checkroot at depth 2 insserv: loop involving service keyboard-setup at depth 1 insserv: loop involving service alsa-utils at depth 10 insserv: loop involving service atd at depth 10 insserv: There is a loop between service rmnologin and mountall if started insserv: loop involving service mountall at depth 5 insserv: loop involving service checkfs at depth 4 insserv: loop involving service mtab at depth 3 insserv: loop involving service networking at depth 7 insserv: loop involving service kbd at depth 11 insserv: There is a loop between service rmnologin and ifupdown-clean if started insserv: loop involving service ifupdown-clean at depth 1 insserv: loop involving service hwclockfirst at depth 4 insserv: loop involving service hostname at depth 5 insserv: loop involving service module-init-tools at depth 7 insserv: There is a loop between service rmnologin and ifupdown if started insserv: loop involving service ifupdown at depth 8 insserv: There is a loop between service rmnologin and mountdevsubfs if started insserv: loop involving service mountdevsubfs at depth 3 insserv: loop involving service vmware-USBArbitrator at depth 1 insserv: There is a loop between service rmnologin and mountall-bootclean if started insserv: loop involving service mountall-bootclean at depth 1 insserv: exiting now without changing boot order! update-rc.d: error: insserv rejected the script header dpkg : erreur de traitement de hal (--configure) : le sous-processus script post-installation installé a retourné une erreur de sortie d'état 1 Paramétrage de fancontrol (1:3.1.2-6) ... insserv: warning: script 'K01vmware' missing LSB tags and overrides insserv: warning: script 'S50vmware-USBArbitrator' missing LSB tags and overrides insserv: warning: script 'vmware-workstation-server' missing LSB tags and overrides insserv: warning: script 'vmware' missing LSB tags and overrides insserv: warning: script 'vmware-USBArbitrator' missing LSB tags and overrides insserv: There is a loop at service rmnologin if started insserv: There is a loop between service rmnologin and mountnfs if started insserv: loop involving service mountnfs at depth 6 insserv: loop involving service nfs-common at depth 5 insserv: Starting vmware-USBArbitrator depends on rmnologin and therefore on system facility$all’ which can not be true!
dpkg : erreur de traitement de fancontrol (–configure) :
Paramétrage de rsync (3.0.7-2) …
update-rc.d: using dependency based boot sequencing
insserv: Starting vmware-USBArbitrator depends on rmnologin and therefore on system facility $all' which can not be true! insserv: Max recursions depth 99 reached insserv: loop involving service portmap at depth 4 insserv: There is a loop between service rmnologin and pcmcia if started insserv: loop involving service pcmcia at depth 2 insserv: loop involving service udev at depth 1 insserv: There is a loop at service vmware-USBArbitrator if started insserv: There is a loop between service rmnologin and checkroot if started insserv: loop involving service checkroot at depth 2 insserv: loop involving service keyboard-setup at depth 1 insserv: loop involving service alsa-utils at depth 10 insserv: loop involving service atd at depth 10 insserv: There is a loop between service rmnologin and mountall if started insserv: loop involving service mountall at depth 5 insserv: loop involving service checkfs at depth 4 insserv: loop involving service mtab at depth 3 insserv: loop involving service networking at depth 7 insserv: loop involving service kbd at depth 11 insserv: There is a loop between service rmnologin and ifupdown-clean if started insserv: loop involving service ifupdown-clean at depth 1 insserv: loop involving service hwclockfirst at depth 4 insserv: loop involving service hostname at depth 5 insserv: loop involving service module-init-tools at depth 7 insserv: There is a loop between service rmnologin and ifupdown if started insserv: loop involving service ifupdown at depth 8 insserv: There is a loop between service rmnologin and mountdevsubfs if started insserv: loop involving service mountdevsubfs at depth 3 insserv: loop involving service vmware-USBArbitrator at depth 1 insserv: There is a loop between service rmnologin and mountall-bootclean if started insserv: loop involving service mountall-bootclean at depth 1 insserv: warning: script 'K01vmware' missing LSB tags and overrides insserv: warning: script 'S50vmware-USBArbitrator' missing LSB tags and overrides insserv: warning: script 'vmware-workstation-server' missing LSB tags and overrides insserv: warning: script 'vmware' missing LSB tags and overrides insserv: warning: script 'vmware-USBArbitrator' missing LSB tags and overrides insserv: Starting vmware-USBArbitrator depends on stop-bootlogd and therefore on system facility$all’ which can not be true!
insserv: Starting vmware-USBArbitrator depends on stop-bootlogd and therefore on system facility $all' which can not be true! insserv: Starting vmware-USBArbitrator depends on stop-bootlogd and therefore on system facility$all’ which can not be true!
insserv: There is a loop between service vmware-USBArbitrator and stop-bootlogd if started
insserv: loop involving service stop-bootlogd at depth 24
insserv: Starting vmware-USBArbitrator depends on stop-bootlogd and therefore on system facility $all' which can not be true! insserv: exiting now without changing boot order! update-rc.d: error: insserv rejected the script header dpkg : erreur de traitement de rsync (--configure) : le sous-processus script post-installation installé a retourné une erreur de sortie d'état 1 Paramétrage de at (3.1.12-1+squeeze1) ... insserv: warning: script 'K01vmware' missing LSB tags and overrides insserv: warning: script 'S50vmware-USBArbitrator' missing LSB tags and overrides insserv: warning: script 'vmware-workstation-server' missing LSB tags and overrides insserv: warning: script 'vmware' missing LSB tags and overrides insserv: warning: script 'vmware-USBArbitrator' missing LSB tags and overrides insserv: Starting vmware-USBArbitrator depends on stop-bootlogd and therefore on system facility$all’ which can not be true!
insserv: Starting vmware-USBArbitrator depends on stop-bootlogd and therefore on system facility $all' which can not be true! insserv: exiting now without changing boot order! update-rc.d: error: insserv rejected the script header dpkg : erreur de traitement de at (--configure) : le sous-processus script post-installation installé a retourné une erreur de sortie d'état 1 Paramétrage de lm-sensors (1:3.1.2-6) ... insserv: warning: script 'K01vmware' missing LSB tags and overrides insserv: warning: script 'S50vmware-USBArbitrator' missing LSB tags and overrides insserv: warning: script 'vmware-workstation-server' missing LSB tags and overrides insserv: warning: script 'vmware' missing LSB tags and overrides insserv: warning: script 'vmware-USBArbitrator' missing LSB tags and overrides insserv: Starting vmware-USBArbitrator depends on stop-bootlogd and therefore on system facility$all’ which can not be true!
insserv: Starting vmware-USBArbitrator depends on stop-bootlogd and therefore on system facility $all' which can not be true! insserv: exiting now without changing boot order! update-rc.d: error: insserv rejected the script header dpkg : erreur de traitement de lm-sensors (--configure) : le sous-processus script post-installation installé a retourné une erreur de sortie d'état 1 Paramétrage de initscripts (2.88dsf-13.1+squeeze1) ... insserv: warning: script 'K01vmware' missing LSB tags and overrides insserv: warning: script 'S50vmware-USBArbitrator' missing LSB tags and overrides insserv: warning: script 'vmware-workstation-server' missing LSB tags and overrides insserv: warning: script 'vmware' missing LSB tags and overrides insserv: warning: script 'vmware-USBArbitrator' missing LSB tags and overrides insserv: Starting vmware-USBArbitrator depends on stop-bootlogd and therefore on system facility$all’ which can not be true!
insserv: Starting vmware-USBArbitrator depends on stop-bootlogd and therefore on system facility $all' which can not be true! insserv: exiting now without changing boot order! update-rc.d: error: insserv rejected the script header dpkg : erreur de traitement de initscripts (--configure) : le sous-processus script post-installation installé a retourné une erreur de sortie d'état 1 dpkg : des problèmes de dépendances empêchent la configuration de asterisk : asterisk dépend de dahdi ; cependant : Le paquet dahdi n'est pas encore configuré. dpkg : erreur de traitement de asterisk (--configure) : problèmes de dépendances - laissé non configuré Paramétrage de avahi-daemon (0.6.27-2+squeeze1) ... Reloading system message bus config...done. insserv: warning: script 'K01vmware' missing LSB tags and overrides insserv: warning: script 'S50vmware-USBArbitrator' missing LSB tags and overrides insserv: warning: script 'vmware-workstation-server' missing LSB tags and overrides insserv: warning: script 'vmware' missing LSB tags and overrides insserv: warning: script 'vmware-USBArbitrator' missing LSB tags and overrides insserv: Starting vmware-USBArbitrator depends on stop-bootlogd and therefore on system facility$all’ which can not be true!
insserv: Starting vmware-USBArbitrator depends on stop-bootlogd and therefore on system facility $all' which can not be true! insserv: exiting now without changing boot order! update-rc.d: error: insserv rejected the script header dpkg : erreur de traitement de avahi-daemon (--configure) : le sous-processus script post-installation installé a retourné une erreur de sortie d'état 1 Paramétrage de smartmontools (5.39.1+svn3124-2) ... insserv: warning: script 'K01vmware' missing LSB tags and overrides insserv: warning: script 'S50vmware-USBArbitrator' missing LSB tags and overrides insserv: warning: script 'vmware-workstation-server' missing LSB tags and overrides insserv: warning: script 'vmware' missing LSB tags and overrides insserv: warning: script 'vmware-USBArbitrator' missing LSB tags and overrides insserv: Starting vmware-USBArbitrator depends on stop-bootlogd and therefore on system facility$all’ which can not be true!
insserv: Starting vmware-USBArbitrator depends on stop-bootlogd and therefore on system facility `$all’ which can not be true!
dpkg : erreur de traitement de smartmontools (–configure) :
dpkg : des problèmes de dépendances empêchent la configuration de libopenr2-3 :
libopenr2-3 dépend de dahdi ; cependant :
Le paquet dahdi n’est pas encore configuré.
dpkg : erreur de traitement de libopenr2-3 (–configure) :
dpkg : des problèmes de dépendances empêchent la configuration de gsmartcontrol :
gsmartcontrol dépend de smartmontools ; cependant :
Le paquet smartmontools n’est pas encore configuré.
dpkg : erreur de traitement de gsmartcontrol (–configure) :
dpkg : des problèmes de dépendances empêchent la configuration de libnss-mdns :
libnss-mdns dépend de avahi-daemon (>= 0.6.16-1) ; cependant :
Le paquet avahi-daemon n’est pas encore configuré.
dpkg : erreur de traitement de libnss-mdns (–configure) :
dahdi
hal
fancontrol
rsync
at
lm-sensors
initscripts
asterisk
avahi-daemon
smartmontools
libopenr2-3
gsmartcontrol
libnss-mdns
comment je peut regler le probleme
Ça ressemble à ce problème: communities.vmware.com/message/1875412
Comment es-tu arrivé à ce “désastre” ?
Qu’as-tu installé (et comment) qui a provoqué ça ?
Un historique nous permettrait de comprendre un peu mieux et éventuellement de t’aider.
Synaptic ne te sera pas d’une grande aide sur ce coup, passe par la console (apt-get, aptitude, dpkg…)
tant que tu y est tu peux aussi poster tes rapports entre les balises [code]…
Enfin moi je préfère. :slightly_smiling:
merci les gars
je vai eseiller avec ça
merci les gars
c’est bien http://communities.vmware.com/message/1875412 la solution
[quote=“bravvve”]merci les gars
c’est bien http://communities.vmware.com/message/1875412 la solution[/quote]
:smiley: C0ntent d’être tombé dessus du premier coup…
Résolu ? => Coche verte! Merci.
