Je n’arrive pas à installer le driver Intel sur ma debian 6 2.6.32-5-amd64.
/e1000e-1.9.5/src# make
make -C /lib/modules/2.6.32-5-amd64/build SUBDIRS=/root/e1000e-1.9.5/src modules
make[1]: Entering directory `/usr/src/linux-headers-2.6.32-5-amd64'
CC [M] /root/e1000e-1.9.5/src/netdev.o
/root/e1000e-1.9.5/src/netdev.c: In function âe1000_runtime_resumeâ:
/root/e1000e-1.9.5/src/netdev.c:6606: error: âstruct dev_pm_infoâ has no member named âruntime_autoâ
/root/e1000e-1.9.5/src/netdev.c: At top level:
/root/e1000e-1.9.5/src/netdev.c:7500: error: implicit declaration of function âSET_RUNTIME_PM_OPSâ
/root/e1000e-1.9.5/src/netdev.c:7502: error: initializer element is not constant
/root/e1000e-1.9.5/src/netdev.c:7502: error: (near initialization for âe1000_pm_ops.suspend_noirqâ)
make[4]: *** [/root/e1000e-1.9.5/src/netdev.o] Error 1
make[3]: *** [_module_/root/e1000e-1.9.5/src] Error 2
make[2]: *** [sub-make] Error 2
make[1]: *** [all] Error 2
make[1]: Leaving directory `/usr/src/linux-headers-2.6.32-5-amd64'
make: *** [default] Error 2
J’ai même essayer de faire l’install du driver via dkms mais toujours avec une erreur similaire :
DKMS make.log for e1000e-1.9.5 for kernel 2.6.32-5-amd64 (x86_64)
jeudi 26 janvier 2012, 11:19:38 (UTC+0100)
make: entrant dans le répertoire « /var/lib/dkms/e1000e/1.9.5/build/src »
make -C /lib/modules/2.6.32-5-amd64/build SUBDIRS=/var/lib/dkms/e1000e/1.9.5/build/src modules
make[1]: entrant dans le répertoire « /usr/src/linux-headers-2.6.32-5-amd64 »
CC [M] /var/lib/dkms/e1000e/1.9.5/build/src/netdev.o
/var/lib/dkms/e1000e/1.9.5/build/src/netdev.c: In function âe1000_runtime_resumeâ:
/var/lib/dkms/e1000e/1.9.5/build/src/netdev.c:6606: error: âstruct dev_pm_infoâ has no member named âruntime_autoâ
/var/lib/dkms/e1000e/1.9.5/build/src/netdev.c: At top level:
/var/lib/dkms/e1000e/1.9.5/build/src/netdev.c:7500: error: implicit declaration of function âSET_RUNTIME_PM_OPSâ
/var/lib/dkms/e1000e/1.9.5/build/src/netdev.c:7502: error: initializer element is not constant
/var/lib/dkms/e1000e/1.9.5/build/src/netdev.c:7502: error: (near initialization for âe1000_pm_ops.suspend_noirqâ)
make[4]: *** [/var/lib/dkms/e1000e/1.9.5/build/src/netdev.o] Erreur 1
make[3]: *** [_module_/var/lib/dkms/e1000e/1.9.5/build/src] Erreur 2
make[2]: *** [sub-make] Erreur 2
make[1]: *** [all] Erreur 2
make[1]: quittant le répertoire « /usr/src/linux-headers-2.6.32-5-amd64 »
make: *** [default] Erreur 2
make: quittant le répertoire « /var/lib/dkms/e1000e/1.9.5/build/src »
Une idée
