Je souhaite installer ia32-libs sous squeeze pour faire fonctionner flash en 64 bits.
Et lors de l’installation, j’obtiens:
#aptitude install
The following NEW packages will be installed:
ia32-libs
0 packages upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 0 B/34,2 MB of archives. After unpacking 84,5 MB will be used.
Do you want to continue? [Y/n/?] y
(Reading database ... 94456 files and directories currently installed.)
Unpacking ia32-libs (from .../ia32-libs_20101117_amd64.deb) ...
dpkg: error processing /var/cache/apt/archives/ia32-libs_20101117_amd64.deb (--unpack):
trying to overwrite '/usr/lib32/libcurl.so.4.2.0', which is also in package ia32-libs-workaround-499043 0.0.1+squeeze1
configured to not write apport reports
dpkg-deb: subprocess paste killed by signal (Broken pipe)
Errors were encountered while processing:
A package failed to install. Trying to recover:
Une idée?
Merci.
