Impossible d'installer ia32libs
Bonsoir à tout le monde.
J’ai besoin d’installer ia32-libs sur l’ordi [Squeeze 64] d’un ami - encore plus nul que moi - via ssh.
Voici ce qui se passe:
[code]francesco@debian-desktop:/etc/apt$ sudo apt-get install ia32-libs
Reading package lists… Done
Building dependency tree
Reading state information… Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
ia32-libs : Depends: lib32gcc1 (>= 1:4.1.1) but it is not going to be installed
Depends: lib32stdc++6 (>= 4.1.1) but it is not going to be installed
Depends: lib32v4l-0 (>= 0.5.0) but it is not going to be installed
E: Broken packages
et voici le sources.list:
[code]#############################################################
################### OFFICIAL DEBIAN REPOS ###################
Debian Main Repos
deb http://ftp.fr.debian.org/debian/ squeeze main contrib non-free
deb-src http://ftp.fr.debian.org/debian/ squeeze main contrib non-free
Debian Update Repos
deb http://security.debian.org/ squeeze/updates main contrib non-free
deb http://ftp.fr.debian.org/debian/ squeeze-proposed-updates main contrib non-free
deb-src http://security.debian.org/ squeeze/updates main contrib non-free
deb-src http://ftp.fr.debian.org/debian/ squeeze-proposed-updates main contrib non-free
##################### UNOFFICIAL REPOS ######################
3rd Party Binary Repos
Debian Multimedia - http://www.debian-multimedia.org/
Run this command: apt-get update && apt-get install debian-multimedia-keyring && apt-get update
deb http://www.debian-multimedia.org/ squeeze main[/code]
J’ai lu le post [http://www.debian-fr.org/impossible-d-installer-ia32-libs-t30757.html] avec intervention résolutive de fran.b mais je ne crois pas être dans le même cas de figure.
Merci pour votre aide!
Que te donne l’installation de lib32gcc1, visiblement il y a des pbms d’incompatibilité
Voilà ce que ça me donne:
[code]francesco@debian-desktop:~$ sudo apt-get install lib32gcc1
lib32gcc1 : Depends: gcc-4.4-base (= 4.4.5-8) but 4.4.5-10 is to be installed
E: Broken packages
Je devrais essayer d’installer “gcc-4.4-base”?
Tu as un problème de versions avec gcc-4.4-base…
Je te conseille de commencer par enlever le depot squeeze-proposed-updates qui dans mes souvenirs n’est pas prévu pour une utilisation classique de la Squeeze.
Si ça ne suffit pas à régler ton problème, c’est que ce sont les dépôts multimedia qui prennent le dessus sur les dépôts officiels pour la version de gcc-4.4-base ! Dans ce cas il va falloir que tu crées un fichier preferences attribuant aux dépôts multimedia un priorité inférieure aux dépôts officiels (ex : 400)…
