Bonjour !
Voila, j’ai besoin d’installer PDO que j’avais sans souci installer sur un ancien serveur ubuntu mais depuis debian, impossible
Voila le log:
pecl install pdo_mysql
WARNING: "pecl/PDO_MYSQL" is deprecated in favor of "channel://http://svn.php.net/viewvc/php/php-src/trunk/ext/pdo_mysql//ext/pdo_mysql"
WARNING: "pecl/PDO" is deprecated in favor of "channel://http://svn.php.net/viewvc/php/php-src/trunk/ext/pdo//ext/PDO"
downloading PDO_MYSQL-1.0.2.tgz ...
Starting to download PDO_MYSQL-1.0.2.tgz (14,778 bytes)
.....done: 14,778 bytes
downloading PDO-1.0.3.tgz ...
Starting to download PDO-1.0.3.tgz (52,613 bytes)
...done: 52,613 bytes
12 source files, building
running: phpize
Configuring for:
PHP Api Version: 20090626
Zend Module Api No: 20090626
Zend Extension Api No: 220090626
building in /var/tmp/pear-build-root/PDO-1.0.3
running: /tmp/pear/temp/PDO/configure
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for a sed that does not truncate output... /bin/sed
checking for cc... cc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether cc accepts -g... yes
checking for cc option to accept ISO C89... none needed
checking how to run the C preprocessor... cc -E
checking for icc... no
checking for suncc... no
checking whether cc understands -c and -o together... yes
checking for system library directory... lib
checking if compiler supports -R... no
checking if compiler supports -Wl,-rpath,... yes
checking build system type... x86_64-unknown-linux-gnu
checking host system type... x86_64-unknown-linux-gnu
checking target system type... x86_64-unknown-linux-gnu
checking for PHP prefix... /usr
checking for PHP includes... -I/usr/include/php5 -I/usr/include/php5/main -I/usr/include/php5/TSRM -I/usr/include/php5/Zend -I/usr/include/php5/ext -I/usr/include/php5/ext/date/lib
checking for PHP extension directory... /usr/lib/php5/20090626
checking for PHP installed headers prefix... /usr/include/php5
checking if debug is enabled... no
checking if zts is enabled... no
checking for re2c... no
configure: WARNING: You will need re2c 0.13.4 or later if you want to regenerate PHP parsers.
checking for gawk... gawk
checking whether to enable PDO support... yes, shared
checking for a sed that does not truncate output... (cached) /bin/sed
checking for fgrep... /bin/grep -F
checking for ld used by cc... /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... yes
checking for BSD- or MS-compatible name lister (nm)... /usr/bin/nm -B
checking the name lister (/usr/bin/nm -B) interface... BSD nm
checking whether ln -s works... yes
checking the maximum length of command line arguments... 1572864
checking whether the shell understands some XSI constructs... yes
checking whether the shell understands "+="... yes
checking for /usr/bin/ld option to reload object files... -r
checking for objdump... objdump
checking how to recognize dependent libraries... pass_all
checking for ar... ar
checking for strip... strip
checking for ranlib... ranlib
checking command to parse /usr/bin/nm -B output from cc object... ok
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking for dlfcn.h... yes
checking for objdir... .libs
checking if cc supports -fno-rtti -fno-exceptions... no
checking for cc option to produce PIC... -fPIC -DPIC
checking if cc PIC flag -fPIC -DPIC works... yes
checking if cc static flag -static works... yes
checking if cc supports -c -o file.o... yes
checking if cc supports -c -o file.o... (cached) yes
checking whether the cc linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes
checking whether -lc should be explicitly linked in... no
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... no
configure: creating ./config.status
config.status: creating config.h
config.status: executing libtool commands
running: make
/bin/sh /var/tmp/pear-build-root/PDO-1.0.3/libtool --mode=compile cc -I. -I/tmp/pear/temp/PDO -DPHP_ATOM_INC -I/var/tmp/pear-build-root/PDO-1.0.3/include -I/var/tmp/pear-build-root/PDO-1.0.3/main -I/tmp/pear/temp/PDO -I/usr/include/php5 -I/usr/include/php5/main -I/usr/include/php5/TSRM -I/usr/include/php5/Zend -I/usr/include/php5/ext -I/usr/include/php5/ext/date/lib -DHAVE_CONFIG_H -g -O2 -c /tmp/pear/temp/PDO/pdo.c -o pdo.lo
libtool: compile: cc -I. -I/tmp/pear/temp/PDO -DPHP_ATOM_INC -I/var/tmp/pear-build-root/PDO-1.0.3/include -I/var/tmp/pear-build-root/PDO-1.0.3/main -I/tmp/pear/temp/PDO -I/usr/include/php5 -I/usr/include/php5/main -I/usr/include/php5/TSRM -I/usr/include/php5/Zend -I/usr/include/php5/ext -I/usr/include/php5/ext/date/lib -DHAVE_CONFIG_H -g -O2 -c /tmp/pear/temp/PDO/pdo.c -fPIC -DPIC -o .libs/pdo.o
/bin/sh /var/tmp/pear-build-root/PDO-1.0.3/libtool --mode=compile cc -I. -I/tmp/pear/temp/PDO -DPHP_ATOM_INC -I/var/tmp/pear-build-root/PDO-1.0.3/include -I/var/tmp/pear-build-root/PDO-1.0.3/main -I/tmp/pear/temp/PDO -I/usr/include/php5 -I/usr/include/php5/main -I/usr/include/php5/TSRM -I/usr/include/php5/Zend -I/usr/include/php5/ext -I/usr/include/php5/ext/date/lib -DHAVE_CONFIG_H -g -O2 -c /tmp/pear/temp/PDO/pdo_dbh.c -o pdo_dbh.lo
libtool: compile: cc -I. -I/tmp/pear/temp/PDO -DPHP_ATOM_INC -I/var/tmp/pear-build-root/PDO-1.0.3/include -I/var/tmp/pear-build-root/PDO-1.0.3/main -I/tmp/pear/temp/PDO -I/usr/include/php5 -I/usr/include/php5/main -I/usr/include/php5/TSRM -I/usr/include/php5/Zend -I/usr/include/php5/ext -I/usr/include/php5/ext/date/lib -DHAVE_CONFIG_H -g -O2 -c /tmp/pear/temp/PDO/pdo_dbh.c -fPIC -DPIC -o .libs/pdo_dbh.o
/tmp/pear/temp/PDO/pdo_dbh.c: In function ‘pdo_stmt_instantiate’:
/tmp/pear/temp/PDO/pdo_dbh.c:410: error: ‘zval’ has no member named ‘refcount’
/tmp/pear/temp/PDO/pdo_dbh.c:411: error: ‘zval’ has no member named ‘is_ref’
/tmp/pear/temp/PDO/pdo_dbh.c: In function ‘pdo_stmt_construct’:
/tmp/pear/temp/PDO/pdo_dbh.c:435: error: ‘zend_fcall_info’ has no member named ‘object_pp’
/tmp/pear/temp/PDO/pdo_dbh.c:458: error: ‘zend_fcall_info_cache’ has no member named ‘object_pp’
/tmp/pear/temp/PDO/pdo_dbh.c: In function ‘zim_PDO_setAttribute’:
/tmp/pear/temp/PDO/pdo_dbh.c:752: error: ‘zval’ has no member named ‘refcount’
/tmp/pear/temp/PDO/pdo_dbh.c: In function ‘zim_PDO_getAttribute’:
/tmp/pear/temp/PDO/pdo_dbh.c:818: error: ‘zval’ has no member named ‘refcount’
/tmp/pear/temp/PDO/pdo_dbh.c: In function ‘pdo_hash_methods’:
/tmp/pear/temp/PDO/pdo_dbh.c:1122: warning: assignment discards qualifiers from pointer target type
/tmp/pear/temp/PDO/pdo_dbh.c:1126: warning: assignment discards qualifiers from pointer target type
make: *** [pdo_dbh.lo] Erreur 1
ERROR: `make' failed
7 source files, building
running: phpize
Configuring for:
config.m4:104: warning: AC_CACHE_VAL(pdo_inc_path, ...): suspicious cache-id, must contain _cv_ to be cached
../../lib/autoconf/general.m4:2019: AC_CACHE_VAL is expanded from...
../../lib/autoconf/general.m4:2040: AC_CACHE_CHECK is expanded from...
aclocal.m4:2739: PHP_CHECK_PDO_INCLUDES is expanded from...
config.m4:104: the top level
building in /var/tmp/pear-build-root/PDO_MYSQL-1.0.2
running: /tmp/pear/temp/PDO_MYSQL/configure
checking for MySQL support for PDO... yes, shared
checking for mysql_config... /usr/bin/mysql_config
checking for mysql_query in -lmysqlclient... yes
checking for mysql_commit... yes
checking for mysql_stmt_prepare... yes
checking for mysql_next_result... yes
checking for mysql_sqlstate... yes
checking for PDO includes... checking for PDO includes...
configure: error: Cannot find php_pdo_driver.h.
ERROR: `/tmp/pear/temp/PDO_MYSQL/configure' failed
Désole pour la longueur.
Merci d’ava,ce
