J’ai installé debian 6 sur un pc , mais quand je lance en console et en root que ce soit : konqueror, nautilus, dolphin, …
Impossible
Voici les réponses :
root@debian:/home/cdtx# konqueror
QGtkStyle was unable to detect the current GTK+ theme.
Qt: Session management error: None of the authentication protocols specified are supported
konqueror(9220): Session bus not found
KCrash: Application 'konqueror' crashing...
sock_file=/root/.kde/socket-debian/kdeinit4__0
Warning: connect() failed: : Aucun fichier ou dossier de ce type
KCrash cannot reach kdeinit, launching directly.
drkonqi(9221): Session bus not found
root@debian:/home/cdtx# dolphin
<unknown program name>(9219)/: KUniqueApplication: Cannot find the D-Bus session server: "Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken."
<unknown program name>(9218)/: KUniqueApplication: Pipe closed unexpectedly.
